Go Back   Digit Technology Discussion Forum > Hardware > PC Components / Configurations
PC Components / Configurations Questions about configurations go here. Strictly Buying Advice - No troubleshooting here. Go through each and every sticky thread of this section and other sections before posting.
Old 28-11-2007, 05:25 PM   #1 (permalink)
High without substance...
chicha's Avatar
Default how is this system config...
i am buying this pc by the end of dec
AMD 64 X2 Athlon 6000+
Asus M2A-VM
1*2 GB Trancend 633\800?
Asus EN8600GT 256 MB..
now is this pc good enough to play all the post HL2 games? at settings not more than 1024*768.
and if i add 1 or 2 GB RAM will it cause bottleneck?
thank you
I am Acrophobic, Entomophobic, Melissophobic. :).
chicha is offline
Old 28-11-2007, 05:46 PM   #2 (permalink)
dá ûnrêäl Kiñg
zyberboy's Avatar
Default Re: how is this system config...
since amd 6000 uses 125w and also not much speed gain,at that level its better to go for c2d
so i wud say
Amd 5200 + 2.7 brisbane or amd 5000 black edition
asus M2N-E or MSI K9N ultra
2gb 800mhz ram
My Stomach pains:D:D
http://tinyurl.com/32jj4m
zyberboy is offline
Old 28-11-2007, 06:22 PM   #3 (permalink)
ArZuNeOs's Avatar
try this question in hardware section
& also look at Basic Guide Purchase a New System by choto cheeta
ArZuNeOs is offline
windows/system 32/ config/system files corrupted or missing ? mkmkmk Software Q&A 9 02-04-2009 02:55 PM
New system CONFIG... HELP NEEDED naveen_reloaded PC Components / Configurations 2 09-07-2007 01:08 AM
Pls Compair these 2 system config.. n7610 PC Components / Configurations 8 03-01-2007 12:10 AM
Config On 50k System Needed m-jeri QnA (read only) 2 01-10-2005 08:30 PM
My System Box Config.... debasis_7012005 QnA (read only) 4 22-04-2005 07:23 PM
