Go Back   Digit Technology Discussion Forum > Hardware > PC Components / Configurations
PC Components / Configurations Questions about configurations go here. Strictly Buying Advice - No troubleshooting here. Go through each and every sticky thread of this section and other sections before posting.
Old 27-11-2007, 12:44 PM   #1 (permalink)
Lost in LOST
sagardani's Avatar
Default will LCD monitor work on my config?
Hi friends, currently I've BPL 15" CRT (don't laugh). So I want to buy new LCD TFT monitor under 15k. But I havn't upgraded my pc since 4 years. I've following main config-
Pentium 4- 2.4 GHz processor
Gforce FX 5200 128mb card
512mb ddr2 ram
I want best & largest (inches) possible LCD/TFt monitor under 15k. I expect best possible build quality, descent looks, wide screen and other technical features that will come under 15k (like dvi i/p). What I just want to know is, will it run on my pc having given config? And I mostly want for movies watching and animation, special effects, etc.....
Throw your suggestions......
Cybernetic, biological A.I, genetically engineered specially to survive in Earth's atmosphere.
sagardani is offline
Old 27-11-2007, 01:22 PM   #2 (permalink)
Fast 'N' Furious
topgear's Avatar
Default Re: will LCD monitor work on my config?
Nvidia Geforce Fx 5200 Supports resolution upto 2048*1536 @85Hz
So I think you cak hook up 22 or 22 inch monitor.
but 1st do check your graphics card manual for maximum supported resolution
you could get a 22 inch LCD TFT within your budget.
ToPsPeEeD = FaSt BuT StEaDy
topgear is online now
Old 30-11-2007, 11:02 AM   #3 (permalink)
Lost in LOST
sagardani's Avatar
Hi, but which company, model, how much?
Old 01-12-2007, 04:59 PM   #4 (permalink)
Fast 'N' Furious
topgear's Avatar
You Could try Viewsonic models at your place. Also dell is another good one.
See this thread :
Post your latest Purchase
I would Recomend Viewsonic
Old 01-12-2007, 05:10 PM   #5 (permalink)
Rising ApocalypsE
keith_j_snyder2's Avatar
Yes u can but tell me this.
How come u have DDR2 RAM since u haven't upgraded for last 4 years?
I mean 4 years back there was no sign of DDR2 RAM modules!
For 15K u can easily get a 19" or may be 22" LCD!
Go have fun!
keith_j_snyder2 is offline
Old 02-12-2007, 07:22 PM   #6 (permalink)
Go have fun!
Obviously it's DDR
@sagardani, any LCD monitor should work, just take care to check the max resolution your card supports. Even if it doesnt support the max resolution supported by the LCD, u can still use it at a lower resolution. Newer monitors can work well at non-native resolutions also.
But keep in mind that ur system is quite old, so if u r not planning to upgrade soon or buy additional devices that can connect to ur monitor, all those extra features (DVI/HDMI..blah blah) will just be wasted, so dont pay a premium for those. I would suggest that you get a decent value for money 19" widescreen monitor, LG or Samsung.
gulgulumaal is offline
Old 02-12-2007, 07:56 PM   #7 (permalink)
dOm1naTOr's Avatar
+1 for 19" widescreen. Its more than enough for desktop use, unless u haf a gud GFX card nd is a serious gamer.
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 21-04-2008, 03:48 PM   #8 (permalink)
Lost in LOST
sagardani's Avatar
Hey folks.... Its been long time I didn't appear on this thread because I had dropped that plan. Now again I want to start discussion on this thread as Im thinking a LCD monitor..
My budget is now reduced to 10-11k ! So there will be a 19" Ws monitor in this range. But problem is- my gfx card has VGa out and all the monitors come with DVI i/p. So what I want to know is- is there VGA to DVI converter available? Once I buy monitor, Im not gonna change it atleast for 3 years. Meanwhile I may upgrade other hardware. But right now my gfx card has VGA o/p. Can I connect LCD to it? The monitors come only with DVI-D or they do have VGA also? VGA i.e analog is compramise and will reduce quality? How to solve this problem?
Waiting for reply...
(Note- resloution won't be an issue since card supports max 2048 by 1536)
Old 21-04-2008, 05:23 PM   #9 (permalink)
Alter Bridge=GOD
nish_higher's Avatar
well certain tfts come with both inputs- afaik samsung does have some models.
though i'd suggest Dell ..otherwise samsung.just dont go for a viewsonic one
Apple Macbook Pro 17
nish_higher is offline
Old 21-04-2008, 06:08 PM   #10 (permalink)
Lost in LOST
sagardani's Avatar
But will analog be compramise ? Or is there an AGP card I can buy? Don't think of p7n here. Have postponed those plans. Suggest me a good suitable AGP card around 2.5k (cheaper is preffered as I just want to connect LCD monitor). How is Sapphire X1300 series?
someone reply man....
Old 21-04-2008, 07:11 PM   #11 (permalink)
Fast 'N' Furious
topgear's Avatar
Is viewsonic that bad ?
@ sagardani
Your gfx card in enough to connect lcd monitor as lcd monitors comes with vga ( must ) & dvi ( majority nowdays ) connector.
As I've connected a lcd with my 5200 gfx card.
Will PRO STREET work on this config?? revisankar Gamerz 2 21-09-2007 03:43 PM
AMD Config for Rs 15k W/O Monitor &.... ArZuNeOs PC Components / Configurations 1 08-06-2007 09:15 PM
config for 50k without monitor supersaiyan PC Components / Configurations 6 08-02-2006 11:18 AM
Will this Config work ? zodiac_511 PC Components / Configurations 6 04-07-2005 02:30 PM
