OK... Guys please take a Look that this bellow config as I am going add this to the main page...
SO please post ur views and suggestion on the Config...
________________________Start_____________________ _____________
Media Center PCs
Purpose, Simply entertainment movies and music and some gaming
Budget
Well there can be 2 catagories only Higher Midrage of Rs. 35k to 45k and High range of more than 55 or even more than that....
I am going to suggst some options and then will present one config as Mid range and one as High range...
Processors
Well the PC will be playing some ultra High defination content... But still i guess any X2 or C2D or new Dual Cores will be enough to play those !!!!
AMD X2 3600+
AMD X2 4400+
AMD X2 4800+
Intel Dual Core E2140
Intel Dual Core E2160
Core 2 Duos (Any i suppose) E4300 up to the highest of them all, but as user
Kniwor suggests dont buy 1066 FSB models and for new ones press on buying G0 Stepping ones...
Motherboards
This is quite tricky, as those who plans to run on board will have any few options, I think only boards which can play ultra High definations would be AMD690G based or new X3100 ones... but those who wants to go for grfx card can get any 8xxx ones of Nvidia which will be able to play without any issue
AMD
ASUS M2A-VM (AMD 690G / ATi x1250 / DVI out / Onboard 1 GB Share) < This one can run on board quite fine
MSI K9AGM2 (AMD 690v)
MSI / ASUS / Biostar Nvidia 6150 based boards
Combo Pack which comes with VIA Based boards and AMD 3600+ Procys
Intel
Please refer bellow (Right now its in the 1st page)
RAMs
Ones again refer to
Kinwors posts for the RAM details.
Transcend or Kingstone DDR-II 667 Rs. 1900/- + TAX each Module
Transcend or Kingstone DDR-II 800 Rs. 2600/- + TAX each Module
HDDs
In this segment people are expected to store tons of Videos and Music on the PC, Bigger is better
160 GB SATA-II @ Rs. 2000/- + TAX
250 GB SATA-II @ Rs. 2700/- + TAX (16mb buffer) WD
320 GB SATA-II @ Rs. 3400/- + TAX (16mb buffer) WD
Grfx Card
Not a very highfy is needed though those who wants to run vista with DX10, for them its 8xxx ones
XFX / Zebronics 8400 Not sure yet !!!
XFX / Zebronics 8500 Zebronics is at Rs. 4400/- + TAX for the 256MB model
XFX / Zebronics 8600 XFX is at Rs. 6800/- + TAX for the 256MB model
XFX / Zebronics 8800 XFX one is at Rs. 13700/- + TAX for the 256MB model
TV Tuner Card
Cheap Local Brand like Frontech or Techcom sales around ar Rs. 650 to 850/-
Pinnacle FM+TV Tuner Supporting WinVista and WinXP + MCE is Rs. 2100/- + TAX
All comes with Remote control...
Cabby
As it would be one show off PC, so i guess
http://www.zebronics.net/cabinets.asp or iBall cabbys can be think off...
But personally I like those local made Large Cabbis and they save a lot of money too
u can get one well ventilated large Cabbi for Rs. 1200 to 1800 MAX
PSU
I would say in Kolkata brand like ColorSit, 450watts or 500 watts would be enough, find one like that one in ur places !!! as for Mid range
Cooler Master 600 watts is at Rs. 3500/- Kolkata...
Display
This is the main part of the PC u are buying, try to spend as much possible here, i would say even go for GB RAM to buy a good display...
I would only list LCDs as they are the future now in big screens... allways opt for DVI out ones
View Sonic VG1930WM 19" Wide Screen Rs. 11900/- + TAX
Dell 22"
E228wfp Rs. 19000/- + TAX
Peope I am open for suggestion here, not so good on LCDs so please suggest some 17" models and some more budget 22"
Speaker
5.1 would be minimum, any Onboard sound will allow High Defination 5.1
Creative 5.1 Inspire @ Rs. 3600/- + TAX
Once agian guyss please suggest some 7.1 options under 7k and more
Keyboard Mouse
My Personal fav Keyboard TVS Gold @ Rs. 1000/- + TAX (not multimedia)
Now there as Logitech and Microsoft Combo options out there
Wireless and non-wireless go for one which u can afford....
Full Config I would suggest
X2 4400+ @ Rs. 4000
ASUS M2A-VM @ Rs. 3800
2GB DDR-II 667MHz @ Rs. 3800
250 GB SATA-II WD 16mb Buffer @ Rs. 2700
DVD RW @ Rs. 1500
Pinnacle TV Tuner Card @ Rs. 2100/- + TAX
Cabby + ColorSit 500 SMPS @ Rs. 2200
22" Dell @ Rs. 19000
Creative 5.1 @ Rs. 3600
Microsoft Combo @ Rs. 750
Total Rs. 45188 incl 4% TAX stay onboard now add one GRfx Card later on
_________________________END______________________ _________
Waiting for ur views
1 last question what about the warranty does it really matter coz my i hv never had problems with my intel CPU till date...so that means No need of warranty right ?? coz nothing will happen to CPU ?? right ??
Well really dont mind, but i find it ulta
I am every now and then sending CPUs / Mobos / HDDs / RAM allmost every thing for warrenty from our cafe !!!!
they do break but thats the fun u can relax for 3 yrs unless u hardwarelly break some thing... like Overclocking and Burning the CPU or Mobo or RAM will mean no warrenty at all
hey choto cheeta can u create a thread about C2D overclocking ?? in there tell about how to over clock it !!
Well even I am getting quite a few Pms to refer to the Cooler threads that I should write step by step info, but guys, I am not a pro overclocker for sure.. !!
I have still lot to learn, but yes, I would love to share what ever little I know about the Stuff
