17-08-2007, 02:14 AM
#301 (permalink)
Rebooting
Re: Basic Guide Purchase a new System
Well Not really, PAE and 3GB Switch will allow x86 platform too access more than 4GB RAMs,
take a look in these links,
Physical Address Extension
Some more detailed Tech Stuff http://www.microsoft.com/whdc/system...AE/pae_os.mspx
But personally I would say yeah when running 4GB + 1GB Video Memory, opt for x64 platform !!!!
rebooting
ChotoCheeta.com
17-08-2007, 02:46 AM
#302 (permalink)
tech mighty
Originally Posted by Choto Cheeta
OK... Here we go with 1 Lack Budget... note Its my personal thinking that one can use this bellow as for best use !!! we will have difference in openion for sure... so, please wait for other to reply...
My shot..
Intel Q6600 @ 12900/- + TAX
ASUS P5N32-E Sli (680i) @ Rs. 11500/- + TAX
Kingstone Performance 4 x 1 GB DDR-II @ Rs. 12000/- + TAX
ThermalRight Ultra 120 eXtreme @ Rs. 4500/- + TAX
320 GB SATA-II 16 MB Buffer @ Rs. 3400/- + TAX
WinFast TV Tuner Card with Remote supporting Vista @ Rs. 2500/- + TAX
2 x 8800 GTS 320 MB @ Rs. 27400/- + TAX
DVD RM Liton @ Rs. 1350/- + TAX
Any Large well Ventilated Cabinet I would say @ Rs. 2200/- + TAX
Cooler Master eXtreme 600 watts @ Rs. 3500/- + TAX
Dell 22" LCD E228WFP @ Rs. 19000/- + TAX
Creative 2.1 will do I suppose when you don’t have space @ Rs. 1000/- + TAX
Microsoft Desktop Pro wired can do the job well @ Rs. 750/- + TAX
TAX @ 4% 4080
Total 10,6080 ex Kolkata Price incl TAX
This is what I thought would be good... !!!
1,P35 works better than 650i/680i with quads...so u may replace the MB with ASUS P5k deluxe (future proof also-works with 45nm also without any bios update)....
2,As quads can't be overclocked much,we can go for ordinary RAM rather than High performance ones (2~3% performance increase for double the price is not necessary)
3,instead of 320sli u may suggest 8800GTX...
4,E228WFP is available for 17k...
5,Definately a better Speaker for 1L PC...
17-08-2007, 04:02 AM
#303 (permalink)
Rebooting
Tell me which P35 based ASUS board is SLi Supported ??
I didnt suggested Kingstone option.. 667 MFz 4GB would have costed Rs. 8k where as the Performace ones is Rs. 12k they are good for Ocing the Quads...
Author wants SLi
mention the source... and thnx for the update...
once again u missed the authors post... He doesnt need better than 2.1 !!!
rebooting
ChotoCheeta.com
17-08-2007, 08:04 AM
#304 (permalink)
According to tomshardware,
E6750 has a better gaming performance than Q6600 and has a better price/performance ratio also. I am not that into video editing or applications that require a 'Quad' Core.
As for the speakers, I already have a ATP3, I am looking for something with stronger bass and more rms output.
No intrested in 'low latency' RAM modules. Too costly for their performance.
GPU: Buying later after 2-3 months, after the price of 8800 GTX reduces a bit.
Another thing, since I am based in Bangalore, should I get the parts locally or from some other place? Where is it cheaper: Mumbai, Chennai or Delhi (sorry don't have contacts in Kolkata)? Any good online dealers(I am aware of itwares and itdepot)?
Any way thanks for the response.
Deven
17-08-2007, 10:23 AM
#305 (permalink)
tech mighty
Author wants SLi
hi choto cheeta why r u getting tensed???
i am just advising him only....thats all.....nobody can deny the fact that u are helping others in a big way....just a discussion yar...(anyway i din't reed the authors post ya---thats why...)
17-08-2007, 11:36 AM
#306 (permalink)
shadow hunter
look for klipsh promedia 2.1 or altec mx-5021
here is my review
a review of speakers and tv tuners
knowledge can be shared & must be BUT intelligence CAN'T be
17-08-2007, 10:19 PM
#307 (permalink)
Dhishum
I have a very old desktop PC with the following config.
1. Normal mouse-keyboard
2. CRT 14" monitor (NEC MultiSynch A500+), capable of 1280x1024 60Hz 32-bit
3. 40GB IDE HDD, little slow, but manageable
4. 154MB RAM (24MB Shared for Video, 130MB Usable)
5. HP Vectra VL, Intel P2 based system
+ Onboard phone modem, 10MB LAN, and sound card
+ CD-ROM drive + 3.5" Floppy Drive
+ 2 USB ports + 1 Free PCI slot
I want to upgrade this desktop to a system, with at least the following config.
1. 512 MB RAM
2. Wireless Internet 802.11g (54Mbps)
I want to do the upgrade with minimal possible cost. But, at the same time, I am wondering, is it worth it, to continue with a P2 based system, at today's date? I would be using this mainly for doing some testing of the in-house developed software, so slow machine with minimum bells and whistles may be good!
Please advise.
17-08-2007, 10:24 PM
#308 (permalink)
Rebooting
USB Device sells for around Rs. 900/- in Kolkata... but for that you would need one 2.0 USB Port ...
I guess for u its wise to opt for Wifi PCI Card Rs. 1200/- in Kolkata....
That would be really hard to find... I think u wont be able to digg up a 512 MB Stick and may be ur P-II Motherboard may not support 512 stick...
So best would be buying 2 256MB SD RAM modules... No real good idea about the SD RAM price... as really hard to find new ones now days... !!!
rebooting
ChotoCheeta.com
17-08-2007, 11:04 PM
#309 (permalink)
Dhishum
Thanks Choto_Cheeta for the advise. I was also thinking, if I could re-use the following from the old system
1. CRT Monitor 14"
2. HDD 40GB
3. Keyboard/Mouse
4. CD-ROM Drive
5. Floppy Drive
6. Cabinet with whatever SMPS it has, must be at least 250W (Though it is HP branded one, but I believe any ATX mobo should fit, right?)
... and build a new system, with some OK processor, and mobo, then? Again cost is the concern.
Please advise.
17-08-2007, 11:10 PM
#310 (permalink)
Google Bot
dude there s no juice left in ur p2.. I wd say that u get a new pc altogether
Reason: Automerged Doublepost
17-08-2007, 11:12 PM
#311 (permalink)
Dhishum
That's exactly why I made the second post. I was thinking of getting a new procy, a new mobo, and a wireless card, and re-use the rest of the peripherals... Can you please suggest any good cheap combination of Mobo, and procy, and also the prices in Kolkata? Thanks in advance.
17-08-2007, 11:14 PM
#312 (permalink)
Rebooting
@niladrisde
Tell us ur Budget... what I can see is P-II not up to the mark, but as u would just run Coding job in it.. i would say run it as long as possible..
rebooting
ChotoCheeta.com
17-08-2007, 11:20 PM
#313 (permalink)
Dhishum
My budget is around 7k/8k. In that P2 machine, sometimes it feels hopelessly slow, and the software being developed wouldn't probably be used by anyone running less than P4, considering the product would be launched another year later. That's why I was thinking of buying something dual core type, with some OK processor. In fact, if I have to throw out the procy, and mobo, why not get AMD/ASUS, at least better performance/cost ratio...
17-08-2007, 11:27 PM
#314 (permalink)
offtopic : ^^ so its basically for your work ??
when its for business never regret !! buy a new comp !! excel in your business !
Sony Ericsson Flashing, Modding, Patching, Hacking And More !
http://www.akshayy.com/sonyericsson/
17-08-2007, 11:34 PM
#315 (permalink)
Rebooting
8k..
tough.... Very tough...
See what u can Manage is,
AMD Sempron 3000+ / 2800+ @ Rs. 1200/- + TAX
Cheap VIA Chipset based Motherboard @ Rs. 1500/- + TAX
512 MB DDR-II 667 MHz @ Rs. 1000/- + TAX
Cabi + SMPS (as ur old one will not going to do) Rs. 1200/- + TAX
Total @ Rs. 6500/- incl TAX 4%
But really tell me, is that worth of update to u ??
rebooting
ChotoCheeta.com
17-08-2007, 11:50 PM
#316 (permalink)
Dhishum
I completely agree Choto_Cheeta, and add the wireless card on top of that, and it easily becomes 8k+ with tax. Plus as because it's for business, I have to buy Windows XP Home license, which is 6k?
I believe I have to raise my hardware budget to 10k/11k. If that still sounds not descent, please suggest, as because I don't have much idea about different mobos, and their prices, and compatibility with the processors...
And just to quickly reply to aks_win, yes budget hurts, when you know you have to run from your pocket, for another year...
18-08-2007, 12:01 AM
#317 (permalink)
Rebooting
well in that Budget range you dont need to know much about Better Config, its just asking the Vendor to give u some thing which will allow you to go as low as possible..
what we can do from here is just advicing you to select the type  thats it...
Windows XP SP2 Pro is Rs. 6.5k + TAX
rebooting
ChotoCheeta.com
18-08-2007, 12:09 AM
#318 (permalink)
Dhishum
First of all, thanks.
But, you think, even if I have to buy just the mobo, procy, RAM, and the wireless card, it is not possible within 10k/11k? In an earlier post you only mentioned a complete system, for just 16k odd with tax...? I am naive, and just asking...
18-08-2007, 12:11 AM
#319 (permalink)
Rebooting
Exclude the Windows XP from that Budget, we can suggest and compile pretty decent config under that then
AMD X2 3600+ 1MB L2 Socket AM2 @ Rs. 2700/-
MSI K9AMG2 (AMD 690v Chipset with ATi x1200 onboard) @ Rs. 2400/-
1 GB DDR-II @ Rs. 1900/-
Cabi + SMPS @ Rs. 1200/-
Total Rs. 9932/- incl 4% VAT Kolkata...
rebooting
ChotoCheeta.com
18-08-2007, 12:14 AM
#320 (permalink)
Dhishum
Oh, sorry of course, as I mentioned 10k/11k is just the Hardware budget, Win XP I have budgeted for, separately... Sorry I should have mentioned it clearly.
I just want decent mobo, procy, RAM, Wireless card, and a cabbi, if possible under 10k range....
18-08-2007, 12:15 AM
#321 (permalink)
Rebooting
I have Edited the Post so U missed it  anyway its 9932/- all incl but yeah U need to add another 1k either for the PCI Wifi Card or for the USB Wifi adapter !!!
rebooting
ChotoCheeta.com
18-08-2007, 12:23 AM
#322 (permalink)
Dhishum
Excellent!! I can't really thank you enough choto_cheetah!
In fact I already bought a system by following your advice from your first post in this thread (AMD X2 64 4000+/AMD M2A-VM/250GB Sata2/Kingston 1GB DDR2 800/LG DVD-RW/Colorsit 450 + Cabi/PCI Wireless Card/Logitech Wireless Kb-M/Local UPS), for 32.5k incl. Tax. Lots of thanks for your valuable advices.
18-08-2007, 12:26 AM
#323 (permalink)
Rebooting
Welcome...
and It would be helpful you if please break that config up with detailed pricing product by product here, Post your latest Purchase
thnkx
rebooting
ChotoCheeta.com
18-08-2007, 12:28 AM
#324 (permalink)
Dhishum
Surely will do... (didn't know such a thread existed)
18-08-2007, 03:03 AM
#325 (permalink)
AMD user for 9 yrs!!
Hey,
Just today I got a PC assembled for my friend,
basic config, simple usage, and occasionally Oracle, 3D Max usage.
AMD X2 4000+ & Gigabyte GA-MA69VM-S2 ( Specs) - Rs. 6350
512*2 Transcend 667 - 2100
Sony DVD Writer - 1500
Viewsonic 19" WideScreen - 9200
Hitachi 160SATA2
FDD, normal cabinet & powersupply
Logitech Combo - 680
My question is .. I had a option of MSI nvidia 6100 board and this Gigabyte AMD 690 board. . gigabyte 400rs expensive
and ASUS with nvidia chipset was more expensive.
I went for gigabyte bcoz it had 4 RAM slots not 2, (better in case of upgrade)
and shared video support upto 256mb.
> Was that correct decision? ya I have taken it, but want to know whats right.
> Which one has upper hand nvidia or AMD chipset?
Regards
18-08-2007, 10:22 AM
#326 (permalink)
amd 690G has the advantage . the nvidia chipset is quite old
18-08-2007, 05:36 PM
#327 (permalink)
Treatment in progress...
well guys.. i need to BUY a new display for my pc.
my config is:
c2d e6420
xfx 650i ultra
2gigs ddr2 667
xfx 8600gt 256
cm 500 extreme
300gb sata 2 +all other bla bla....
i am confused whether to buy a flat crt or an lcd(budget-max 10-12k)
i will be playing games,all the latest ones(with some eye candy on,of cous!  ).
now pushing my rig to 1280*1024(native resolution of 17'' lcd)gaming wud send the frame rates skyrocketting earthwards....well dats wat i think!
now what should i get? a 17'' crt or a 15''/17'' lcd??
can the 17'' lcd support 1024*768 gaming without compromise on visual quality?
now for an lcd, it must have 5ms response time and high contrast ratio(>500:1) EDIT::i need gud brightness too..>300cd/m^2 and low dot pitch....i think that will be good for gaming.
now tell me,wat shud i do?
PC: Core i7 2600K||Z68V Pro||Noctua U12P SE2
Vengeance 1600Mhz 8GB||GTX560Ti HAWK
CM Elite 430||1TB+300GB
VX550||G110||G1 mouse||Razer Goliathus Ω
Photography: Nikon D5100||Nikon 55-300 VRII
Canon Powershot SX220HS||Tamrac Velocity 9x
Audio Gear: Brainwavz M4||Meelec A151|| EP630
PX100 II||Fiio E5||AudioTechnica ATH-T500
18-08-2007, 07:01 PM
#328 (permalink)
9437077259
Just read in PC World that Intel Q6600 is now available for Rs.11000/-. Is that true... Moreover, there is a lot of gush about the new 45nm processors that are about to release by this year end. Is this going to be quite superior to the present 65nm on grounds of performance. I actually want to buy a PC but if the upcoming technology is going to be way better, I would better wait rather buying something that is about to die...
Win 7 Ultimate
Abit IP35-E Mobo,C2Q 6600,4GB DDR2 RAM,XFX 8600GT 256MB DDR3 Gfx ,Seagate 1TB HDD,Sony DVD RW,500w SMPS,19" Viewsonic VX922 TFT,Logtech G5 Mouse,Altec Lancing 2:1 Speakers.
18-08-2007, 09:00 PM
#329 (permalink)
Rebooting
My suggestion View Soniq VX1932WM available at Rs. 10050/- + TAX Kolkata....
They are available but not actually Rs. 11k here at Kolkata some 12.7k + TAX...
rebooting
ChotoCheeta.com
19-08-2007, 12:01 AM
#330 (permalink)
Monster Truck
Buddies,
I have sold off my old dinosaur a few months back and need ur assistance and guide on my next purchase.
I did do a bit of digging and with my limited knowledge came up with this list:
AMD X2 5200~2.6Ghz~2MB L2 Cache :: The Cheapest AMD with 2MB L2 Cache
Asus M2N-E (non SLI) :: Cheapest ASUS Mobo with a thermal pipe design+nforce 570 Ultra+8channel audio
Transcend 1GB DDR II 800Mhz :: Plan to add another one later for going dual channel
Seagate 160GB SATA II
ASUS DVD RW
Zeb Bijli+Zeb Platinum 400W PSU (or probably CoolerMaster Extreme 500W if I can afford it )
Viewsonic 19" Wide VA1912wb with DVI input.
Budget is 30k(+-3K)
 Eagerly awaiting comments and suggessions
