| Forum |
| PC Components / Configurations Questions about configurations go here. Strictly Buying Advice - No troubleshooting here. Go through each and every sticky thread of this section and other sections before posting. |
#1 (permalink) |
ASRock Conroe945G mobo 512X2MB of DDR2 667MHz RAM SATA I 80GB hard disk nvidia 8500 GT Graphic card I am currently using Intel P4 2.66GHz processor 1. I have a budget of around 5K. My mobo already supports a core2duo but not the upcoming quadcore. 2. Which will be the best option for me. Will it give a significant performance boost considering the fact that my current processor has an FSB of just 533 while my mobo supports 1066 3. Is it any use saving up more money for a better processor considering that I have a mediocre system over all? Note that only thing I may upgrade anytime soon is my RAM. 4. I will need this system for Gaming and may even overclock. My current processor falls below minimum requirement of latest games. 5. How much should i charge for the current processor ?That money will go into the upgrade budget.
Appreciate me now and avoid the rush!! i5 2500K || 8GB DDRIII 1600 MHz RAM || Zotac GTX560Ti || Samsung 2233sw || Corsair GS600 |
#2 (permalink) |
TechTin.com
Go for core 2 duo E4400
Price 5k Best option for you.
www.9zap.com/forums -> Indian Webmaster Forum whost.in - Web Hosting Offers thinkdigit.com/forum/showthread.php?t=109137 TechTin.com |
#3 (permalink) |
OK thanks....... anything about point no 3?
And I just found it has a bus speed of 800 MHz. My mobo also supports 1066 MHz. And RAM is 667MHz. I am running in dual channel so RAM is effectively functioning at twice that speed. So shouldn't I go for a processor with more FSB to extract the max out of this mobo. And the upgrade may last longer. I can wait longer and save more money if it's worth it.
Appreciate me now and avoid the rush!! i5 2500K || 8GB DDRIII 1600 MHz RAM || Zotac GTX560Ti || Samsung 2233sw || Corsair GS600 Last edited by baccilus; 23-09-2007 at 05:19 PM. |
#4 (permalink) |
TechTin.com
It depend on you.If you want to wait...you cant wait for few more months..to find few more cheap processor.
But i dont think processor C2D price is going to fall in ear future.So go for E4400 best deal for you.
#7 (permalink) | |
TechTin.com
#8 (permalink) | |
http://forums.techpowerup.com/showthread.php?t=32888
He too suggests E4400 is a better choice. But this is not in relation to games. Quote:
Appreciate me now and avoid the rush!! i5 2500K || 8GB DDRIII 1600 MHz RAM || Zotac GTX560Ti || Samsung 2233sw || Corsair GS600 Last edited by baccilus; 23-09-2007 at 06:43 PM. Reason: Automerged Doublepost |
#10 (permalink) |
Alter Bridge=GOD
cool..!!!!
any ideas about Q6600 and E6850 on that overclocking issue?i m buying one of them.along with a below 8k board.that means i can too overclock it to a gr8 extent??
Apple Macbook Pro 17 |
#11 (permalink) |
TechTin.com
No, idea of over clocking.Prefer Q6600
#12 (permalink) |
@nish_higher get the Q6600 instead of E6850 cuz Q6600 being a quad will help in future apps and games.Q6600 G0 stepping is a gr8 overclocker.u can easily reach 3GHz and go beyond.there has been reports of ppl crossing 4GHz using 3rd party cooling solutions.
in 8k u'll get Asus P5N-E SLi which is a good oc'ier |
#13 (permalink) |
Alter Bridge=GOD
thanks.just one more question--asus crash free bios.does it mean that if i go beyond my proc's ovrclocking capabilites it will automatically reset and prevent from toasting?
all my overclocking experience is today's only-i oc'd my friend's x2 3800+ on a m2n-mx to 2.54ghz and my fx55 to .1ghz more (2.7 now)
#14 (permalink) |
^^^ crash free bios wont save u from a fried proccy.all it wud do is save u from having to reset the bios by taking out the battery if ur bios crashes due to some wrong vals in bios.
#15 (permalink) |
well if u can wait for sometime, then save some money and get a Proccy+mobo. lets say it wud be arnd 12K to 15K. but if u go in for a decent mobo, like the P5N ultra, u will get overclocking+support for later processors.
it wud be gud for u as u dont have to spend on Ram or graphics card or HDD... |
#16 (permalink) | |
TechTin.com
#17 (permalink) |
Moshel, was that for me or nish?
And how will E4400 perform in comparison to my current processor in 3D games, considering that latest games are known to be CPU intensive.
#19 (permalink) | |
tech mighty
#20 (permalink) |
But i think this asrock mobo will manage well. It has got untied overclocking feature and crashfree BIOS. See that mobo link. I even overclocked my current processor to 2.82GHz once without any problem but had to pull back when I got my graphic card as it wouldn't give any display on an overclocked system. That's because of overheating problems in my 8500GT( It's quite common I have heard). Hope I don't face this problem when i get my new procy.
E4400, here I come
#21 (permalink) | |
die blizzard die! D3?
C2Ds are made for overclocking.
Stealing your women and horses since 1843. |
#22 (permalink) | |
as for E4400 i have heard that u can overclock it to the speeds of a Quad Core. I do currently own E4400 with 8500GT and although i dont get the best graphics, i can play all games easily. |
#23 (permalink) | |
@Moshel: I too think I should wait and see how the quad core of both Intel and AMD turn up. Till then I can collect more money and play some low graphic games. If I am not able to save enough money by then, E4400 seems to be a good option. Thanks everyone. This thread was really helpful for me.
Appreciate me now and avoid the rush!! i5 2500K || 8GB DDRIII 1600 MHz RAM || Zotac GTX560Ti || Samsung 2233sw || Corsair GS600 Last edited by baccilus; 27-09-2007 at 10:43 PM. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Core2Duo or Core2Quad??? | go4saket | Hardware Q&A | 29 | 26-08-2007 03:30 AM |
| win xp home on core2duo ?? | great_manish | Software Q&A | 7 | 28-04-2007 01:32 PM |
| core2duo comp. for 25k- !!!! | jz2linkinpark | Hardware Q&A | 7 | 31-08-2006 05:39 PM |
| want to buy core2duo with 965motherboard!! | h_phalak | Hardware Q&A | 16 | 30-08-2006 05:39 PM |
