Go Back   Digit Technology Discussion Forum > Hardware > PC Components / Configurations
PC Components / Configurations Questions about configurations go here. Strictly Buying Advice - No troubleshooting here. Go through each and every sticky thread of this section and other sections before posting.
Old 18-07-2007, 05:37 PM   #1 (permalink)
<KNighTed>
Question help with pc config..
hey guys,iam planning to get an Asus EN8800GTS(320MB)card..Kindly let me know the pros and cons..also the complete specs of the card..
2 doubts regarding the card:
Wat amount of PSU do i need for the config below incl. the card?
Will it work with 945GM chipset?(confused if its x8 or x16 pci=e slot)
I have another doubt also...iam giving my rig spec below which iam planning 2 build.let me know if its ok for the graphic card setup..
Intel Core 2 duo 2.24Ghz
945GM chipset
2*160gb Sata2 Seagate Barracuda
Lg 16X Dvd-writer
2 gb ddr2 RAM
Cooler Master Case
450w psu
Samsung 19inch Syncmaster
Microsoft Combo
Altec Lansing 4.1 setup
Vista Home Premium
thanx a lot..quick replies needed...
If winning isn't everything,why waste TIME trying!!!!
ashwin_ka is offline
Old 18-07-2007, 06:10 PM   #2 (permalink)
Default Re: help with pc config..
wait till july 22 for the intel price cuts.
1) eVGA Geforce 8800GTS 320MB KO ACS (15.5K)
2) XFX 650i ultra mobo (5K)
3) Coolermaster 600W extreme / Antec 500W ( suggest) (4-5K?)
4) Intel E6750 proccy 8K
5) 2GB 800MHz Transcend RAM Dual Channel 4.5K
rest is OK
kooabs03 is offline
Old 18-07-2007, 06:31 PM   #3 (permalink)
UbuntuUser
cynosure's Avatar
^^ This eVGA card is available in India??
cynosure is offline
Old 18-07-2007, 06:31 PM   #4 (permalink)
<KNighTed>
hey man,thnx for the info..i have a doubt regarding the psu..which brands are gud?also how much power shud i have as total for this rig?thanx a lot..
Old 18-07-2007, 09:23 PM   #5 (permalink)
NP : Crysis
xbonez's Avatar
go in for brands such as antec or coolemaster PSUs. make sure u don't take an unbranded PSU. they're dirt cheap but perform terribly. they give much less wattage than the rated wattage as well as pose stability issues especially if u plan to use a 8800
xbonez is offline
Plz suggest new config.. (update on already referred config) xsreality PC Components / Configurations 48 02-06-2007 04:08 PM
Best Config Under Rs. 40,000 navino87 PC Components / Configurations 39 29-12-2006 09:13 PM
c2d config plz hingepradeep PC Components / Configurations 6 06-10-2006 03:34 AM
wp-config saurabh.sauron PC Components / Configurations 5 29-05-2006 09:25 AM
Amd Config ! Help techiways PC Components / Configurations 1 24-03-2006 05:06 PM
