Results 1 to 22 of 22
Thread: suggest config for friend..
08-06-2007, 10:03 AM #1Wise Old Owl
- Join Date
- Sep 2005
- Posts
- 1,486
hello,
my friend wants to buy a pc . his budget is not exactly fixed . he wants it for C , solid edge / CAD and engg stuff and absolutely no games . Plz suggest a config.
08-06-2007, 10:08 AM #2
Re: suggest config for friend..
Without Budget, it makes difficult to decide
http://www.host4cheap.org/
08-06-2007, 12:49 PM #3Wise Old Owl
- Join Date
- Sep 2005
- Posts
- 1,486
i know .its his first comp buy ( he didnt even know how much it might cost ) . he hates games . thats all he says .
08-06-2007, 12:51 PM #4
Just tell the approx. rate like 20k or 30k. <20k is impossible for a branded one. If he wants in 10k or <10k, he will have to go for 2nd hand comps.
Nilesh Govindrajan
http://nileshgr.com
08-06-2007, 03:11 PM #5
dont need duo core.....p4 will work
graphic card will be not high spec.......
tbcTo follow the path:
look to the master,
follow the master,
walk with the master,
see through the master,
become the master. -Zen
08-06-2007, 05:14 PM #6
Now who are you. Are you sagargv's friend?
Originally Posted by ashisharya
Nilesh Govindrajan
http://nileshgr.com
08-06-2007, 06:08 PM #7Wise Old Owl
- Join Date
- Sep 2005
- Posts
- 1,486
he has max budget of 40k.
08-06-2007, 06:30 PM #8
C2D 15k
HDD 80GB abt.... 5k
Mobo abt..... 5k
BOX 3k (cheap also available)
Keyb .5k
Rat .5k
GPU 3k
SPU-- i don't know estimating 2.5k
Win (pirated) 0.05k
Total: 34.55kLast edited by nileshgr; 08-06-2007 at 06:59 PM.
Nilesh Govindrajan
http://nileshgr.com
08-06-2007, 06:33 PM #918 Till I Die............
- Join Date
- Jul 2004
- Location
- India, Mumbai, Marine Lines
- Posts
- 5,792
Huh. 15K for CPU when you spend 3K for mobo. That would give you crappy performance and a 40GB hard disk?
08-06-2007, 07:00 PM #10
Now?
Originally Posted by mehulved
Nilesh Govindrajan
http://nileshgr.com
08-06-2007, 07:26 PM #11
why price is this
Originally Posted by The Unknown
80GB for 5K
u can get 160GB PATA for 2500
use a good mobo atleas of 8K if proc is 15K
Box 3K
use simple one 1.5K
08-06-2007, 07:29 PM #12
^^ thats as general as it can be... atleast give a specific config...
Core2Duo E6300 1.66Ghz
Intel DG965RY
2* 512MB Transcend DDR2 533 MHZ Ram
Sony DRU-830A
Seagate 160GB SATAII
Microsoft Kbd+ mouse
Any case + 400watts SMPS
LG 17" CRT
08-06-2007, 07:37 PM #13Wise Old Owl
- Join Date
- Sep 2005
- Posts
- 1,486
thanks , i wud like a config that way ( prathiks ), cud u mention the prices as well .thanks .i think for his budget and needs , he can choose tft monitor and he wants a ups as well in the same budget.and why does he need and separate gfx card ? wont onboard do ?
08-06-2007, 07:56 PM #14
Core 2 Duo E6320 + DG965RY - 13000
2GB Kingston Ram 667 - 3700
250GB HDD - 3000
DVD Writer - 1500
Logitech Mouse and Keyboard combi - 800
500VA UPS - 2100
BenQ TFT 19inch Widescreen - 11500
Cabinet - 1500★ Want to start your Website, No worries - here is how ★
08-06-2007, 10:46 PM #15Wise Old Owl
- Join Date
- Sep 2005
- Posts
- 1,486
thanks.
18-06-2007, 01:01 PM #16
thanx 4 the prices @sukhdeepsinghkohli ...........
Sony DRU-830A is agood choice bt havent they released a 20x ritter ?
18-06-2007, 01:13 PM #17
What kinda config u all sugest dude.. There should be balance ...
Here what you should look for cheap and best price performance
AMD X2 3600+ 3.5k
Biostar 690 MG Board 4k
1 Gigs of Ram DDR 667 Kingston 2k
Segate 160 GB Hdd 2.4k
LG H42N DVD RW 1.7k
Cabby 2k any Chieftec
PSU any in budget but make sure its better 1 else system will get kaput
Reast normal
This 1 gr8 for programming and daily stuf will beat E4300 at stock as AMD X2 beat every C2D at stock did not beleive me read review
Me Myself and My Tux Blog :- http://tuxenclave.wordpress.com/
18-06-2007, 01:24 PM #18In The Zone
- Join Date
- Jan 2006
- Location
- Thrissur
- Posts
- 371
^^^ Sony DRU-835A is d latest but dunno if it supports 20x... Heu but then no medias fer dat....
Ther's also DRU-170C dat supp 18x...iE6850 + TRU-120 + Antec120mm Trilite. ASUS P5K Deluxe Wi-Fi AP. 2Gb G.Skill DDR2 PC2-6400 (4-4-3-5). Sgt 250GB 7200.10... XFX 8800GTX 768MB. Corsair HX620. MX518. CM Cavalier. DELL SE198WFP. EP630.
18-06-2007, 01:48 PM #19
Er.. SOny drives are nothing the drive is of Lite o itself the RMA and all are of Lite on so no points in recommending Sony and Lite On get LG H42 N
18-06-2007, 11:22 PM #20Banned
- Join Date
- Apr 2007
- Location
- delhi
- Posts
- 187
40K PC
Intel E6420 + msi neo ---13.5K
2gb Kingston Ram ---- 4K
zebronics cabinet + powersafe 400w ----2.5K
dvd rw - lite on / lg h42n ----1.65K
seagate sata 250 gb ----3K
keyboard samung pleomax --- 0.21K
mouse logitech optical ---0.35K
speakers atp3 / philps 2.1 ---2.5K
17" lcd samsung / lg / viewsonic ---9K
sparkle nvidia 7100gs graphics card --- 2K
Approx. 39K
19-06-2007, 09:41 AM #21
Originally Posted by pathiks
knowing cad/cam softs.. mm..
u need high ram.. as much as u can.. coz all those complexities in ur design really sucks every MB of ur ram..1GB is ok.. 2GB is good
19+ TFT wide screen is recomended
n gfx card.. atleast a 7600GS if poss..
m tellin frm ma personal experience of cad softs..Last edited by spynic; 19-06-2007 at 09:42 AM. Reason: Automerged Doublepost
23-06-2007, 12:09 AM #22Is actually a real word..
- Join Date
- Jun 2007
- Location
- cEhnEHdEH
- Posts
- 443
Yeah umm if he is using CAD, Will definatley need a Gfx card, I have ACAD 2007 and I have a ATI 256 MB card in there, which is either minimum or recommended, and I have a 3GHz proc with 1GB RAM and running the 3D models, well it chugs and is kind of choppy at times, I even try to disable as many non essential startup/services items as well. The most important thing CAD needs is a vid card So add that into your price tag, I have been told to buy a 512MB vid card, but They ain't that cheap here....
40K config for my friend
By nilgtx260 in forum PC Components / ConfigurationsReplies: 75Last Post: 22-07-2011, 10:19 AM -
check this config my friend given me for 38k!!!!!!!!!!!!!!!!!!
By manojkrishnaks in forum PC Components / ConfigurationsReplies: 2Last Post: 04-01-2009, 07:37 PM -
[Urgent] Suggest the best Config for my friend for Rs 42K
By GeekyBoy in forum PC Components / ConfigurationsReplies: 9Last Post: 27-06-2007, 05:19 PM -
By sagargv in forum PC Components / ConfigurationsReplies: 7Last Post: 09-03-2007, 01:44 PM -
By sagargv in forum PC Components / ConfigurationsReplies: 2Last Post: 08-03-2007, 10:50 AM
LinkBack URL
About LinkBacks
