Go Back   Digit Technology Discussion Forum > Hardware > PC Components / Configurations
PC Components / Configurations Questions about configurations go here. Strictly Buying Advice - No troubleshooting here. Go through each and every sticky thread of this section and other sections before posting.
Old 18-04-2007, 01:31 AM   #1 (permalink)
gsmsikar's Avatar
Default see this configuration and suggest a HDD
i have to assemble a PC , the configuration which i have decided is as below :-
CPU = AMD Athlon 64 X2 3800+
MOTHERBOARD = ASUS M2NPV-VM
RAM = Kingston 2* 512MB 667mhz
Optical Drive = Asus DRW-1608P3S 16X DVD Writer
HDD = this is what i am unable to decide until now ...
please help me decide a HDD...
i need 160GB, but should i go for IDE or SATA , i have heard that SATA HDD are of very high failure rates .. but are of high speed while IDE HDD are slow compared to SATA but less failure rates ..
which one should i go for ?
i like samsung as i have one which is of high speed compared to seagate , is that true ?
i heard that WD is giving good support ?
what will BUFFER SIZE do to me ?
so i am confused ...
samsung or seagate or WD?
IDE or SATA ?
which model ?
please help me ..
thanks
gsmsikar is offline
Old 18-04-2007, 01:41 AM   #2 (permalink)
Default Re: see this configuration and suggest a HDD
samsung or seagate ?
IDE or SATA ?
which model ?
please help me ..
thanks
Go for Seagate
Close your eyes n go for SATA
160GB SATA 2 7900.9 rpm
kooldude is offline
Old 18-04-2007, 01:44 AM   #3 (permalink)
gsmsikar's Avatar
Originally Posted by kooldude
Go for Seagate
please mention the model no of this HDD & is this of 2MB buffer size ?
gsmsikar is offline
Old 18-04-2007, 01:48 AM   #4 (permalink)
Model No - ST3160212A & yes 2 MB Buffer
kooldude is offline
Old 18-04-2007, 03:05 AM   #5 (permalink)
well what i think is that you should go for a seagate sata 7200rpm 250gb hdd...as it offers the best price per gb ratio... its available for 3375 at the itwares.com
primitive_trash is offline
Old 19-04-2007, 12:43 AM   #6 (permalink)
gsmsikar's Avatar
tis HDD is not a SATA it is an ATA drive ...
http://www.seagate.com/support/disc/ata/st3160212a.html
gsmsikar is offline
Old 19-04-2007, 01:24 AM   #7 (permalink)
Look for this then - http://www.newegg.com/Product/Produc...82E16822148163
kooldude is offline
Old 19-04-2007, 01:27 AM   #8 (permalink)
gEttIn 0uT@@@ BOXX
abhi1301's Avatar
i wld have gone for seagate 250 GB SATA .. RPM & model u can decide upon does not make real much of diff .. if money is not a big issue then go for a SCSI drive .. they are even faster
Koi CHAKAR NAHI HAI >> SAB JUGAAD HAI
abhi1301 is offline
Old 19-04-2007, 06:54 AM   #9 (permalink)
Try to get 160GB SATA model with 8 MB buffer... They will offer better performance
Arun
sakumar79 is offline
suggest configuration. kamblemilind PC Components / Configurations 3 06-11-2006 02:44 PM
please suggest a configuration bhabendrasaikia PC Components / Configurations 12 24-10-2006 09:11 PM
Please suggest a configuration bhabendrasaikia PC Components / Configurations 5 17-10-2006 03:29 PM
Suggest me a pc configuration biswarup QnA (read only) 1 13-07-2005 08:49 PM
Suggest Me a new PC configuration beauty66 QnA (read only) 8 02-11-2004 03:01 PM
