Go Back   Digit Technology Discussion Forum > Hardware > PC Components / Configurations
PC Components / Configurations Questions about configurations go here. Strictly Buying Advice - No troubleshooting here. Go through each and every sticky thread of this section and other sections before posting.
Old 11-04-2007, 07:13 PM   #1 (permalink)
shyamno's Avatar
Question Configuration Required ----Budget 35-40k
..Hi friends...I searched the forum for the similar query but didn't found any..so ..please help me out..
Platform ----ANY one INTEL or AMD..
so..please give each and every detail of the rig...budget is around 35-40k..
Motherboard suggestion required ..with both onboard and ..*without graphics (*then specify a descent graphics Card)..
shyamno is offline
Old 11-04-2007, 09:14 PM   #2 (permalink)
Default Re: Configuration Required ----Budget 35-40k
Can you specify if you need gaming? Also, specify if budget includes cost of UPS, any 2.1/5.1 speaker set...
Arun
sakumar79 is offline
Old 11-04-2007, 09:28 PM   #3 (permalink)
Host4Cheap.org
Sukhdeep Singh's Avatar
Hope This helps
Intel Core 2 Duo E6300 - 8500
Intel DG965RY (onboard gfx) - 6000
17inch TFT Samsung 740N - 10000
2GB Ram 667Mhz Kingston - 6600
Seagate/Samsung 250GB SATA II - 3500
Microsoft/Logitech Mouse And Keyboard Combo - 1000
Altec Lancing ATP3 - 2500
Samsung/LG/ Song DVD Burner - 2000
Zebronics 450W PSU and Cabinet - 2000
Operating System - FREE DOS/Linux
Exact Rs42100 if the prices i quoted are right
http://www.host4cheap.org/
Sukhdeep Singh is offline
Old 11-04-2007, 10:21 PM   #4 (permalink)
shyamno's Avatar
Arun
Mid level gaming..and a descent 2.1 speaker set..and yeah it includes UPS
Originally Posted by sukhdeepsinghkohli
Hope This helps
17" Flat CRT...and 1 GB RAM...and 160 GB SATA2....can u ..add up the prices for the above ..all are ok..
Can the motherboard be ..changed to something else ..???
shyamno is offline
Old 11-04-2007, 11:37 PM   #5 (permalink)
assasin's Avatar
MSI P965 Neo if u want to buy in that range.if u want better then buy Asus P5B Dlx or P5N-E Sli,
but for all of the above mentioned mobos u'll hav to buy a separate gfx card as they dont hav onboard gfx.
assasin is offline
Suggest Gaming PC configuration budget 75k MaxBombay PC Components / Configurations 5 31-01-2007 03:15 AM
Configuration Help Required - Gaming Rig premsharma PC Components / Configurations 24 18-01-2007 12:59 AM
plz help to get a good configuration for assemling a computer my budget is 40k. crazywolf PC Components / Configurations 2 05-09-2006 12:03 PM
Low budget PC under 15K montylee Hardware Q&A 19 29-08-2006 09:14 AM
configuration suggestion budget 1.25 deepakd QnA (read only) 15 09-06-2005 10:22 AM
