Go Back   Digit Technology Discussion Forum > Hardware > PC Components / Configurations
PC Components / Configurations Questions about configurations go here. Strictly Buying Advice - No troubleshooting here. Go through each and every sticky thread of this section and other sections before posting.
Old 21-01-2007, 09:44 PM   #1 (permalink)
Default Help Reg : Motherboard For my config
Please help me regarding buying a new motherboard for the following config...
Intel C2D E6300
XFX PCIe - GeForce 7600 GT
Transcend Ram 2*512MB Ram
Segate 120GB SATA2 HDD
LiteOn DVD Writer
Samsung 17" CRT
Iam not very specific about its price. I am thinking Buying a new pc with a budget of 40000 - 45000.
navino87 is offline
Old 22-01-2007, 04:01 AM   #2 (permalink)
Default Re: Help Reg : Motherboard For my config
Intel C2D E6300
LiteOn DVD Writer
Samsung 17" CRT
Best suited motherboard is DG965WH. But if you can wait till Feb new MSI motherboards with ATi onboard graphics card (RX 1300se) is coming.
Read this
Best Onboard Graphics Motherboard in 965 Chipset is coming in Feb 2007
abhipal is offline
Old 22-01-2007, 05:37 AM   #3 (permalink)
shantanu's Avatar
X1300 is the card onboard but the pricing is as high as rs. 14000/- onwards as with IL-integrated lan or IWIFI support takes it somewhat more high.. if you are on intel Proccy go for intel mobo with DDr2 800 or 1ghz support and sataII .. thats would be far more better for C2d , rather then to wait as waiting never ends
shantanu is offline
Old 22-01-2007, 04:34 PM   #4 (permalink)
Does intel mobo support nvidia gfx cards???
Also what is the price of intel DG965WH mobo??? Can i go for intel D965RY mobo??? Which one is best preferable???
navino87 is offline
Old 22-01-2007, 05:48 PM   #5 (permalink)
Thumbs up Re: Help Reg : Motherboard For my config
I would suggest MSI P965-NeoF or G965M-FI.
monkey is offline
Old 22-01-2007, 07:30 PM   #6 (permalink)
^^ Please mention its price so tat it will be easy for me to select it...
BTW, is there any good mobo which does't have onboard gfx, as iam going to buy gfx card separately...
navino87 is offline
Old 22-01-2007, 08:43 PM   #7 (permalink)
shantanu's Avatar
YEAH EVERY MOBO SUPPORTS NVIDIA GFX THAT SUPPORTS AGP8X or PCIe architecture.. WELL YOU CAN HAVE COMPATIBLITY PROBLEMS IN ATI CHIPSETS , if you install a NVIDIA GFX ON THEM..
shantanu is offline
Old 22-01-2007, 08:45 PM   #8 (permalink)
Google Bot
Pathik's Avatar
dg965ry... 6.4k i think
Pathik is offline
Old 22-01-2007, 08:48 PM   #9 (permalink)
shantanu's Avatar
its 6.2k @ delhi
shantanu is offline
Old 22-01-2007, 09:09 PM   #10 (permalink)
MSI G965M-FI: Rs. 7895/- + tax
MSI P965-NeoF: Rs. 6700/- + tax
Intel DG965RY: Rs. 6820/-
GIGABYTE GA-965P-DQ6: Rs. 16,500/-
GIGABYTE 965P-DS3: Rs. 12,500/-
GIGABYTE GA-965G-DS3: Rs. 12750/-
Asus P5B Deluxe WiFi: Rs. 13,900/-
monkey is offline
Old 22-01-2007, 10:02 PM   #11 (permalink)
does all the above mentioned mobo has onboard gfx card???any good mobo which does't have onboard gfx???
navino87 is offline
Old 22-01-2007, 10:34 PM   #12 (permalink)
shantanu's Avatar
ya all of them has onboards
shantanu is offline
Old 22-01-2007, 10:44 PM   #13 (permalink)
Please recommend me a best mobo available under 8000 for this config...
navino87 is offline
Old 23-01-2007, 01:20 AM   #14 (permalink)
Only G965 chipset supports onboard graphics.
I would recommend MSI G965M-FI. Its better to have onboard graphics as a backup.
monkey is offline
Old 23-01-2007, 11:09 AM   #15 (permalink)
What about MSI P965 Platinum mobo??? Is it beter than MSI G965M-FI???
Please also tell me the price of MSI P965 Platinum mobo... Does MSI P965 Platinum has onboard gfx???
If so, then Please tell me the spec of Video card in both mobo...
Also is XFX PCIe - GeForce 7600 GT supported by both mobo???
Thnx
navino87 is offline
Old 23-01-2007, 11:17 AM   #16 (permalink)
Learner
Kniwor's Avatar
ASUS P5B would be ur best choice, equally good is Gigabyte GA-965P-DS3 if u are not planning on setting up raid, infact second one would be better if not setting up raid, P5B is around 8500/-
Kniwor is offline
Old 24-01-2007, 03:55 PM   #17 (permalink)
Post Re: Help Reg : Motherboard For my config
Now confused a lot
I have following mobo in mind and dono which to select...
Can any one tell me the price of all mobo (Preferably chennai price). Also recommend me a good mobo...
MSI P965 Platinum
MSI G965M-FI
MSI P965-NeoF
MSI G965MDH
MSI Q965MDO
MSI 975X Platinum PowerUp Edition
Asus P5WDH Deluxe
Intel DG965RY
intel DG965WH
navino87 is offline
Old 24-01-2007, 04:09 PM   #18 (permalink)
MSI P965-NeoF. I would definitely buy this if I were in your position. It will allow you to overclock to a moderate extent and is seriously great value for money.
The Platinum is too expensive and not worth it unless you want to seriously overclock.
G965 is not nearly as good as P965.
The Asus mobo's are too expensive
975 is worthless uless you want a Crossfire setup.
Intel is ruled out because it sucks compared to MSI.
drvarunmehta is offline
Old 24-01-2007, 04:42 PM   #19 (permalink)
You gave been GXified
gxsaurav's Avatar
Where are you guys getting your info from???????
There is no such thing
@ navino87
You have already mentioned that you will be buying a graphics card at the time of getting the computer. So onboard graphics does not matter.
Gigabyte DS3 is something i would also support, if u plan to overclock. However, for no overclocking usage & solid stability intel D965RY is best
about.me/gxsaurav
gxsaurav is offline
Old 24-01-2007, 10:48 PM   #20 (permalink)
Security Exp
47shailesh's Avatar
Go for:
NVIDIA nForce 680i
intel socket 775; 1333 Mhz FSB
2x16 SLi; third PCIe expanson slot;
supports DDR2 800 MHz; 46 PCIe lanes and 9 links; 6xSATAII;
2xPATA; RAID:0,1,0+1,5,
DUAL Gigabit ethernet;
10 USB 2.0
5xPCI; HAD(Azalia) audio..
NEWS:: U can overclock 2.66GHz C2Q to 3.45GHz(amazing na)
We Love Once, And When We do We do it Well
47shailesh is offline
Old 24-01-2007, 11:47 PM   #21 (permalink)
shantanu's Avatar
@saurav !!! I THINK THAT YOU DONT KNOW ABOUT CHIPSET COMPATIBILTY
THE MSI TEAM LET ME KNEW THAT IF I INSTALL A NVIDIA GPF CARD THEN COMPATIBILITY ISSUES MAY OCCUR ON ATi Chipset...
SO FIRST RESEARCH on the topic and then tell it here...
JUST DONT COME SIT AND WRITE
AND Firstly BRING SOME RESPECT IN YOUR WORDS...
HOW CAN YOU SAY WITHOUT KNOWING THAT THERE ARE NO SUCH THINGS....
I have used Ati chipsets in the past and have encounterd problems in using Nvidia cards.... IF YOU WANT A PROOF then google by writing MSI RS482m2 problems with nvidia graphics..
and dude TEll me a thing on how many Ati chipset boards have you tried installing NVIDIA GPU...
SO DO A RESEARCH AND THEN SAY ANYTHING...
shantanu is offline
Old 24-01-2007, 11:55 PM   #22 (permalink)
Romeo + Lucifer = ME
codename_romeo's Avatar
Check this thing......it supports what shantanu says:
http://club.cdfreaks.com/showthread.php?t=188647
Sony Vaio CW26FG
Nokia E 63 + Iphone 3GS
codename_romeo is offline
Old 25-01-2007, 11:54 AM   #23 (permalink)
Thanks a lot for every one replied to my post...
Now i am planning to get a comp for my office with similar config. Since it is fully for working with multiple documents at same time and nothing to do with graphics, i want a board which has a decent onboard gfx card.
Also a board which support quadcore for future upgradability is best recomended...
MSI P965 Platinum
MSI G965M-FI
MSI P965-NeoF
MSI G965MDH
MSI Q965MDO
Asus P5WDH Deluxe
Intel DG965RY
intel DG965WH
Can any one please mention which of the above mentioned mobo has onboard gfx card in it.
navino87 is offline
Old 25-01-2007, 01:04 PM   #24 (permalink)
Just buy any mobo based on G965. It has onboard graphics as well as support for Quadcore.
Old 25-01-2007, 01:15 PM   #25 (permalink)
Security Exp
47shailesh's Avatar
NVIDIA 680i Nforce is a good option for your needs
have a look to this
Old 25-01-2007, 01:50 PM   #26 (permalink)
I would hardly recommend the nForce 680i for an office rig.
Old 25-01-2007, 01:52 PM   #27 (permalink)
@47shailesh Does this mobo has onboard gfx??? What is its coat??? And will it be easily available here in chennai???
@drvarunmehta does Intel DG965RY, intel DG965WH support quad core??? Do you mean tat nForce 680i in best suited for office purpose???
Any other good mobo with onboard gfx card???
navino87 is offline
Old 25-01-2007, 02:05 PM   #28 (permalink)
The nForce 680i is an ultra high-end gaming mobo with SLI. It costs as much as a low end PC. Don't even bother enquiring about the price. It will be in excess of 15k minimum.
Check this site for a list of Quad core supporting mobo's
http://www.intel.com/cd/channel/rese...ech/299987.htm
Both Intel DG965RY and Intel DG965WH are on the list.
Old 25-01-2007, 04:10 PM   #29 (permalink)
The High 5 Flyer
sam9s's Avatar
I would go with kniwor, except may be GA-965P-DS3, I'd go for 965G instead of 965P which does not have onboard graphics.
Ok this is how I feel it should be if price is not much of a concern....
1. ASUS P5B delux........If OC is in your book and you can go without the on board graphic solution. P5B is a ROCK solid board with awsome tweaking options and oodles of features.
You can go for any P5B varient board based on 965 and you have one good board.
Linki
http://in.asus.com/products2.aspx?l1=3&l2=11
2. GA-965G-DS3 ........Again if OC is your game but you need an on board graphic solution as a back up maybe. DS3 is an awsome board as well again with loads of features.
Linki
http://www.gigabyte.com.tw/Products/...me=GA-965G-DS3
3. DG965WH/DG965RY.......If OC is not your cup of tea. Intel boards have the least almost no tweaking options.....and limited (rest assured all essential) features.
4. MSI Q965/G965......If you wanna go for an inexpensive solution with onboard graphics with all the features of 965 chipset. Cant comment on OC as not much idea about how much tweaking MSI Q965/G965 allows.
Linki....
http://www.pcstats.com/articleview.c...id=2049&page=2
EDIT: I 'd like to add that all P5B series 965 chipset support quad core with a simple bios update......
sam9s is offline
Old 25-01-2007, 04:27 PM   #30 (permalink)
Google Bot
Pathik's Avatar
my vote too lies wit either the GA-965G-DS3 or DG965RY
Pathik is offline
