Go Back   Digit Technology Discussion Forum > Hardware > PC Components / Configurations
PC Components / Configurations Questions about configurations go here. Strictly Buying Advice - No troubleshooting here. Go through each and every sticky thread of this section and other sections before posting.
Old 20-01-2007, 03:49 PM   #1 (permalink)
Smile pc configuration ...
Guys i need 2 assemble a a core 2 based system ...
& my budget is 30-35k and i'm not 2 specific about a graphics card .
Plz.. dont just give me a motherbord+graphics+processor combo ...a detailed configuration (including 2.1 speakers ,mouse+keybd combo,cabinet etc....)would be more helpful.
And if any of u guys Frm Navi Mumbai , knws of a good assembler(not the 1 who cant distinguish betn ide & SATA) plz let me knw............
waitin... ...adios!!
digster is offline
Old 20-01-2007, 03:59 PM   #2 (permalink)
Google Bot
Pathik's Avatar
Default Re: pc configuration ...
i dont u ll get a c2d config in 30k...
Core2Duo E6300 1.66Ghz @ 8900/- OR Core2Duo E6400 1.8Ghz @ 8900/-
Intel DG965RY @ 4550/-
1* 1GB Transcend DDR2 Ram @ 52o0/-
Sony DRU-830A @ 2050/-
Seagate 160GB SATAII @ 3800/-
MS Internet Keyboard
Iball Laser Precise Mouse
Any case + 400watts SMPS @ 1000/-
Creative 2.1 speakers @ 1050/-
Samsung 17" CRT @ 4800/-
Pathik is offline
Old 20-01-2007, 04:48 PM   #3 (permalink)
GUNNING DOWN TEAMS
wizrulz's Avatar
ABovb config is just perfect...make the rams 512 * 2....
wizrulz is offline
Old 20-01-2007, 07:39 PM   #4 (permalink)
digiFriend's Avatar
good configuration given by Pathiks. make sure you buy 17" flat monitor.
once you finalise your list, get final prices of all parts.
add total and compare total prices with the price of local assembler/shop.
if you find that prices are nearly equal then buy from them as you will get one year warranty from them.
(shop keeper always charges premium prices from end user. if your couldn't find proper delear then you might also end up paying higher prices by assembling yourself than local delear.)
also check and compare prices of your with "zenith" core 2 duo pc with lcd monitor.
you never know what you can do until you try
digiFriend is offline
Old 20-01-2007, 08:11 PM   #5 (permalink)
Host4Cheap.org
Sukhdeep Singh's Avatar
Hey,
you wrote same price for E6400 and E6300. Also are you sure Dg965RY is for 4550 ?? Few Days back someone quoted it for 6500
http://www.host4cheap.org/
Sukhdeep Singh is offline
Old 20-01-2007, 08:17 PM   #6 (permalink)
Tech Geek's Avatar
Originally Posted by sukhdeepsinghkohli
Hey,
you are right
INTEL D965RY Rs6600
E6300 (2MB L2 cache 1.87Ghz 1066MHz FSB 65nm) Rs8300
E6400 (2MB L2 cache 2.13Ghz 1066MHz FSB 65nm) Rs10400
1 month old prices
Tech Geek is offline
Old 20-01-2007, 08:34 PM   #7 (permalink)
Google Bot
Pathik's Avatar
hey that was a typo.. And i m not sure abt the prices.. Sorry
Pathik is offline
