Go Back   Digit Technology Discussion Forum > Hardware > PC Components / Configurations
PC Components / Configurations Questions about configurations go here. Strictly Buying Advice - No troubleshooting here. Go through each and every sticky thread of this section and other sections before posting.
Old 19-01-2007, 10:47 AM   #1 (permalink)
Ðèåd Måñ Wå£KîÑG
bad_till_bones's Avatar
Default Please help in Configuration
Planning to buy a new computer. Hve decided on Intel D102 GGC2 (ATI X200 onboard) , 2 x 512 MB DDR2 RAM, 160GB HDD.
Just want to know -
1. Is this board capable of playing 3d games without an additional AGP card? Specially, Fifa 06.
2. I can also go for G965 instead of D102, which one is better in terms of 3d gaming quality?
(BTW: Ya, I know installing an AGP card wud b better, but rite now planning to go with out it.... )
Please help urgently....
bad_till_bones is offline
Old 19-01-2007, 10:58 AM   #2 (permalink)
Stalker's Avatar
Default Re: Please help in Configuration
102ggc2 has a pci-e slot....not agp ( correct me if i'm wrong)
if it has an agp slot, u shud get a newer board
x200 is a shader model 2 chip.....u shud be able to play most of the games @ low quality
u can get a palit x1600pro for 4 k & its pretty gud (dx 9.0c & sm 3)
| C2Q Q6600 G0 | Intel DG33FB | 4 GB Corsair 6400C5G DDR2-800Mhz | XFX 8800GTX | CM Extremepower 600W | 250GB Seagate HDD | Lite-ON 1635S DVD RW | Logitech MX-518 | Zalman RS6F | APC RS 800 |
Stalker is offline
Old 19-01-2007, 11:08 AM   #3 (permalink)
The High 5 Flyer
sam9s's Avatar
Just want to know -
Why are you going for AGP. AGP is an outdated technology, and you would hardly get a board and a card to support that. Anyhow boards with PCIE are pretty affordable. 3D games is a vague term, all are 3D games these days unless you are talking about PACMAN. Its the level of quality and the resolution for the game that would decide what kind of system you wanna built.
sam9s is offline
Old 19-01-2007, 11:08 AM   #4 (permalink)
Google Bot
Pathik's Avatar
if u plan to get a GC soon... then go 4 dg965ry....
otherwise d102ggc2.... btw the onboard gfx of d102 r neday better than 965...
Pathik is offline
Old 19-01-2007, 12:12 PM   #5 (permalink)
Ðèåd Måñ Wå£KîÑG
Yeah D102-GGC2 has a PCI - Express slot. Anyways, I just want to know, whether the integrated display card in D102 capable of playing games smoothly (especially like Fifa 06) and which motherboard is better without an additional Graphics card (installed on PCI-E slot) - G965 or D102, in respect of playing games?
Old 19-01-2007, 12:17 PM   #6 (permalink)
Google Bot
Pathik's Avatar
d102... and fifa 06 ll play nice on d102 wit all eye candy on..
Pathik is offline
Old 19-01-2007, 12:27 PM   #7 (permalink)
Stalker's Avatar
u can play FIFA06 / 07 on x200 @ 1024 high damn smoothly
onboard gfx of 102 r better than those of 965
but 965 is a better mobo.....core2duo support, better audio etc..
__________
also 965 has support ddr2 800 & sata2(i think)
Stalker is offline
Old 19-01-2007, 12:34 PM   #8 (permalink)
The High 5 Flyer
sam9s's Avatar
I would say 965 are far better boards than D102, the only drawback is there is no on board graphic solution, except Gigabyte DS3 and its the best option for people opting for 965 with onboard graphics.
sam9s is offline
Old 19-01-2007, 10:24 PM   #9 (permalink)
Ðèåd Måñ Wå£KîÑG
As I said, rite now I am only going 4 on board graphics card.....so by keeping graphics card in mind which one leads????
__________
Guys, any difference btw D101 and D102 motherboard.....
Last edited by bad_till_bones; 19-01-2007 at 10:24 PM. Reason: Automerged Doublepost
Old 19-01-2007, 10:40 PM   #10 (permalink)
Romeo + Lucifer = ME
codename_romeo's Avatar
D101-------DDR ram
D102-------DDR2 Ram
Sony Vaio CW26FG
Nokia E 63 + Iphone 3GS
codename_romeo is offline
Old 20-01-2007, 12:16 AM   #11 (permalink)
Google Bot
Pathik's Avatar
yeah thats the only diff... And sam i never said d102 is d better one.. But it defi has the better onboard gfx btw the 2
Pathik is offline
Old 21-01-2007, 01:51 AM   #12 (permalink)
premsharma's Avatar
Gigabyte DS3 has which graphics onbaord i.e Intel GMA something or SOmething from ATI or Nvidia.
Otherway arround, is there any mobo in 965 chipset with onboard graphics of other than intel GMA.
premsharma is offline
Old 21-01-2007, 02:45 PM   #13 (permalink)
The High 5 Flyer
sam9s's Avatar
DS3 has Intel GMA X3000. Checkout the link...
http://www.gigabyte.com.tw/Products/...me=GA-965G-DS3
sam9s is offline
