Go Back   Digit Technology Discussion Forum > Hardware > PC Components / Configurations
PC Components / Configurations Questions about configurations go here. Strictly Buying Advice - No troubleshooting here. Go through each and every sticky thread of this section and other sections before posting.
Old 13-12-2006, 08:35 PM   #1 (permalink)
shyamno's Avatar
Wink Suggest Me the best Config upto Rs. 30000
Please suggest me a good and descent gamming config between Rs.28000 maximun Rs. 30000..I want to go with Intel processors ....
shyamno is offline
Old 14-12-2006, 06:50 PM   #2 (permalink)
rajaryan_13's Avatar
Default Re: Suggest Me the best Config upto Rs. 30000
Just assembled one under 30000 though wud go for a PSU change which will cost atleast 1500 more, its a budget PC but if u have bit more to spend go for C2D, I 965 based mb & DDE2 ram
specs:
D101 mb : 3750/-
Proc: Intel 3.06 mhz (HT) 3600/-
Zion DDR 512 MB 2800/-
iBall Cabinet, with iBall 400W PSU (it sucks) 1275/-
HP DVD-RW 16X 2100/-
FDD 3.5": 250/-
MS Basic mouse+kb combo 700/-
ATI radeon 1300Pro PCI-E 16X w 512MB DDR2 ram 6400/-
local 120mm xtra fan 40/-
Frontech Headphone 100/-
Samsung SyncMaster794mg 17'' : 4300/-
Hitachi 250GB HDD SATA : 3700/-
UPS APC 500 : 2000/-
rajaryan_13 is offline
Old 14-12-2006, 09:54 PM   #3 (permalink)
Romeo + Lucifer = ME
codename_romeo's Avatar
change the mobo to d 102ggc2 it supports ddr2 so its betterr
Sony Vaio CW26FG
Nokia E 63 + Iphone 3GS
codename_romeo is offline
Old 14-12-2006, 11:27 PM   #4 (permalink)
TechTin.com
ravi_9793's Avatar
go for flat CRT moniter..it will cost u 6k (lg or samsung)
ravi_9793 is offline
Old 16-12-2006, 08:15 AM   #5 (permalink)
shyamno's Avatar
Guys I want to have the following compulsary parts...
1)Core 2 Duo
2)1 GB RAM or 2x512 MB which would be better
3)120 or 160 GB HDD
4)17" CRT
Now I have a question regarding the Core 2 Duo...My local shop called me that if do many multitasking jobs on the computer then Core 2 Duo is meant for me..But if not then I can have Dual or Pentium 4....and they also said that there is no upgrade option from Core 2 Duo to Quad Core in future ...Is there any motherboard for that...
Also tell me what will be best suited for me..I want to spend more time on gaming and multimedia..So rather I sould go for a Dual core and have a motherboard with the compatibilty of upto core 2 duo..please suggest for such motherboards...
shyamno is offline
Old 16-12-2006, 10:25 AM   #6 (permalink)
18 Till I Die............
Not within your budget at all.
C2D e6300 + mobo should come to around 15K
1GB RAM to about 6K
120/160GB hard disk would cost 3/4K not so sure
17"CRT will be 6K
that in itself comes to 30K. And what's the use of even having a gaming PC without a half decent graphics card and a good SMPS.
So either you will have to increase your budget a lot or settle for nothing more than Core Duo 2.8 GHz.
http://www.bash.org/?258908
mehulved is offline
Old 17-12-2006, 01:11 PM   #7 (permalink)
shyamno's Avatar
Please answer this..forget the configuration..and help me in deciding this...
shyamno is offline
