if u have a process called libsymgr.exe or ntsysmgr.exe or a file called cool.exe placed in the locations as described in my previous post the download the removal tools.
OR
if any task named "Netstatt" is running,or if u have a file netstatt.exe (with 2 t's at the end) in the \Windows\System32 directory, not to be confused with netstat.exe,if it is,then it's a Trojan.Try terminating Netstatt.exe and then run Msconfig.Update ur AV and check for viruses.
Removal instructions here:-
http://www.pestpatrol.com/pestinfo/b...r_spyboter.asp
OR
Get urself Webroot Spysweeper.
