Go Back   Digit Technology Discussion Forum > Hardware > PC Components / Configurations
PC Components / Configurations Questions about configurations go here. Strictly Buying Advice - No troubleshooting here. Go through each and every sticky thread of this section and other sections before posting.
Old 07-08-2006, 10:47 PM   #1 (permalink)
Default Laptop Lan Config error work only with laptop not with pc
Hi
I just brought campaq laptop
wndering that it is not able to connect with win2k3 server
it is showing that lan connected but i cant see netowk & browse files
One wonder is that Laptop to Laptop is connecting without any problem & browsing
I called my reseller he tried it with sahara Laptop
sahara Laptop & my Laptop is working fine
but sahara Laptop & my Laptop is not connecting with any other PC
WinxP & 98 is also not connecting
is there is any other setting for laptop to pc ?
i have winxp in laptop
Im using cross cable
means peer to peer i think
no hub switch etc.
I runned repair ,setup wizard & caompaq online chat system
notthing work
no error is raised
thanks
minniawochat is offline
Old 07-08-2006, 10:58 PM   #2 (permalink)
Laptoping
Sourabh's Avatar
Default Re: Laptop Lan Config error work only with laptop not with pc
Make sure they dont have similar computer names on the laptop-desktop and a common workgroup name.
Sourabh is offline
Old 07-08-2006, 11:25 PM   #3 (permalink)
shashank4u's Avatar
what ip address u have given , cross cable is right choice.
make a new connection wizard,
make workgroup name same.
give ip's 192.168.1.1 and 192.168.1.2 (other one).
use some lan messenger to see if they r able to connect.
like softros will do.
Be like a postage stamp-stick to one thing until you get there.
shashank4u is offline
Old 09-08-2006, 12:51 AM   #4 (permalink)
hi guys
thanks for reply
my PC which have internet sharing have 192.168.0.1
& laptop is 192.168.0.4
I m not using any lan manager just win2k3 ICS
thanks
Old 19-09-2006, 03:21 PM   #5 (permalink)
Any One Please Help
I searched Net Every One is Finding Solution .
Please Help
