| Forum |
| PC Components / Configurations Questions about configurations go here. Strictly Buying Advice - No troubleshooting here. Go through each and every sticky thread of this section and other sections before posting. |
#2 (permalink) |
amd 3000+ venice & mobo asus A8NVM : 8400rs ( onboard 6100 not bad for occasional gaming@low settings )
ram : 512mb 1900rs ( atleast hynix.. think transcend costs more...) atx : 800rs (with 350watt smps more than enough) mouse /kbd : 800rs logitech combo ups : intex 600va platinum 1500rs, monitor : samsung 15" 4000rs optical : dvd cd combo lg/lite on : 1400rs sata : 80gb sgt/western digital 2400rs (not sure) TOTAL : 20,400rs Last edited by rskbug; 16-07-2006 at 10:36 PM. |
#5 (permalink) |
In Pursuit of "Happyness"
Windows 98 wont work properly on any new PC. Probably you will have to buy a second hand PC for that. Why do you want to run windows 98 on it, any specific reason?
#6 (permalink) | |
V.Prem Kumar |
#7 (permalink) | |
#8 (permalink) | |
Does amd processor support 8086/8088 assembly language? Hope it should not.
#9 (permalink) |
AMD Athlon64 is fully x86 architecture compatible not sure 'bout 8088.
You could always run your programs in a virtual machine loaded with a DOS os in windows xp. It emulates an old hardware so shouldn't be a problem. You can even load win 98 easily on a virtual machine, and it will run FORTRAN and GW basic fine. I dont think you would be using assembly code in these languages, are you ? I yes then also i think it should work.
AMD Athlon64 2800+, MSI K8N Neo3(NForce4), 1GB Kingston DDR400, MSI Geforce 7600GT PCIe, Viewsonic VA702b 17" LCD, Creative SB Live! 5.1, Logitech Z-5300 5.1 THX Speakers, Seagate 200GB SATA HDD |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
