Go Back   Digit Technology Discussion Forum > Hardware > PC Components / Configurations
PC Components / Configurations Questions about configurations go here. Strictly Buying Advice - No troubleshooting here. Go through each and every sticky thread of this section and other sections before posting.
Old 29-04-2006, 11:20 PM   #1 (permalink)
Default Need a Configuration for 40 K
Hi,
I need the best config for 40K
Please give me ur suggestions...
*need AMD 64 bit processor
*need a 6600 GT Card
* dont want UPS and SPEAKER
Give me the price list plzzzz....
Thnx in advance
anilthomas26 is offline
Old 30-04-2006, 01:50 AM   #2 (permalink)
Learner
Kniwor's Avatar
Default Re: Need a Configuration for 40 K
AMD Athlon 64 3200+-----------7500
ASUS A8N-E--------------------5500
XFX nVidia 6600GT--------------8000
1Gb Corsat Value Select Ram----5500
Colorsit 450W SMPS------------1500
Seagate SATA 160Gb-----------3500
Any cabinet---------------------600
Any KB&M----------------------1000
DVD RW Sony------------------2400
Samsung Synchmaster 793DF---6300
Total --------------------------41800
if ur buget is strictly 40k u can get smaller HDD or compromise on RAM
places where u dont compromise ......... SMPS.....
Kniwor is offline
Old 30-04-2006, 02:26 AM   #3 (permalink)
hi i need only 80 Gb Hard disk ,Hynix Ram,Ordinary 17 inch Samsung monitor..and a bit more low cost SMPS
Old 30-04-2006, 03:52 AM   #4 (permalink)
Learner
Kniwor's Avatar
then get a 80Gb HDD
get Hynix 1 Gb
but i suggest get the smps i suggested.....
if u dont want to get this smps at all then odyssey 400W for 650 is available and is working good in 1 of my friends machine...
Kniwor is offline
Old 30-04-2006, 07:05 AM   #5 (permalink)
Originally Posted by Kniwor
then get a 80Gb HDD
get Hynix 1 Gb
Better follow advice given by Knivor regarding SMPS and try to get the best within your budget.
In case you are particular about Hynix, make sure that it is genuine. It is generally believed that brands like Corsair, Transcend, Kingston etc. are more reliable.
V.Prem Kumar
janitha is offline
