Go Back   Digit Technology Discussion Forum > Hardware > PC Components / Configurations
PC Components / Configurations Questions about configurations go here. Strictly Buying Advice - No troubleshooting here. Go through each and every sticky thread of this section and other sections before posting.
Old 31-03-2006, 04:55 PM   #1 (permalink)
sagar_coolx's Avatar
Default LOw end config.
my cuz needs a low end pc,.
this will be his 1st pc,s he wont need a powerful one,just enough to learn daily computing and alll.
also the budget is 20k+ and the proccy should be intel.
pls suggest a gud config.
sagar_coolx is offline
Old 31-03-2006, 06:49 PM   #2 (permalink)
The pWnster
Vyasram's Avatar
Intel Celeron 2.13D GHz 2500
Asus P4V8X-MX 2500
512 mb ram 2000
40 gb hdd seagate 1800
sony/liteon combo frive rs. 1800
zebronics cabinet with 300w ps 1000
samsung 15' monitor 4000
logitech kb and mouse 500
creative speakers 240 300
sony fdd 300
costs abt 17000,
reduce to 256 mb ram(not recommended) and buy cd-rom instead of combo drive if price concious
and ups - wipro/apc/powersafe 500w rs 2500/2500/1700
Sigs suck
Vyasram is offline
Old 31-03-2006, 07:10 PM   #3 (permalink)
abhishek_sharma's Avatar
why? intel dude....amd sempron will offer much better performance than celeron...
plz try to change ur decision, most tests are won by the sempron..although it is lower priced.
abhishek_sharma is offline
Old 31-03-2006, 07:47 PM   #4 (permalink)
Your Maker.
MysticHalo's Avatar
Intel Pentium D 2.66 Ghz =>4.5k
ASUS P5WD2/motherbrd =>approx. 4-5k
Seagate 80 GB SATA HDD =>approx 4k
PSU of 400W =>1.5k
512 MB DDR2 RAM=> 3k
Keyboard+OpticalMouse=>1.5k
Cabinet=>2k
Cooling Fan+Heatsink=> 1k
Monitor=> SAMSUNg Syncmaster 5k
Combo drive=>3k
PS: these r the minimum requirements to run a PC.All addons r based on ur needs
“Talent is a flame, but genius is a fire.”
MysticHalo is offline
Old 31-03-2006, 08:12 PM   #5 (permalink)
darklord's Avatar
Dude where do you get Asus P5WD2 board for 4.5k ???????
That board is based on 955X chipset and i can vouch that no brand has board on that chipset that cheap.
80GB SATA HDD costs max - 2,600 or may be 2,800 not more than that.
512MB DDR2 = 2200/- max
darklord is offline
Old 31-03-2006, 08:22 PM   #6 (permalink)
Your Maker.
MysticHalo's Avatar
Oh right ! Thx for pointing that out. It was meant to be ASUS P5RD1 motherboard
Old 01-04-2006, 11:59 AM   #7 (permalink)
Default REPLY
i wonder whether 512 RAM is needed when the requirement is Lowend.
Even 256 is much more given the kind of Application the PC is going to be used.
As far as i am concerned 128 Mb RAM + CDROM.
If more RAM is desired then that can be included as and when needed.
Andyiz is offline
Old 01-04-2006, 12:18 PM   #8 (permalink)
This is the best low end config by intel
Intel Pentium 4 506 2.66 Ghz => 4600
Intel original 101 motherboard (ATI xpress 200 chipset) => 3500
Hynix 512 Mb Ram => 1700
Seagate 80 Gb SATA => 2600
Samsung sync master (some model no. ) 17" =>4100
LG Cd writer => 1300
Creative spaakers (basic) => 400
Logitech mouse + keyboard => 600
Cabinet + PSU => 1500
. If you can afford a bit more go for a better speaker like cretive inspire 2.1
cyrux is offline
Old 01-04-2006, 01:52 PM   #9 (permalink)
The pWnster
Vyasram's Avatar
remember , he asker for sometin around 15k
Sigs suck
Vyasram is offline
Old 01-04-2006, 09:33 PM   #10 (permalink)
ymhatre's Avatar
If u r saying P5RD!1 thenit cost 3250... If u were saying p5Rd2 then 3700 RS
DusT = ME
Rate me if was clear to you
ymhatre is offline
