Go Back   Digit Technology Discussion Forum > Hardware > PC Components / Configurations
PC Components / Configurations Questions about configurations go here. Strictly Buying Advice - No troubleshooting here. Go through each and every sticky thread of this section and other sections before posting.
Old 09-02-2006, 11:28 PM   #1 (permalink)
Gaurav's Avatar
Default wat configuration ??
Hi all,
I want a new PC with good speed and graphics (assembled). please suggest some configurations under 25k. I know it sounds foolish to ask for everything but i am totally a stupid when it comes of hardware matters. Please help me build everything.
I already have a monitor, mouse, keyboard, printer, speakers, DVD ROM, CD Writer. Please suggest a durable harddisk (7200 rpm)
Gaurav is offline
Old 10-02-2006, 12:17 AM   #2 (permalink)
unvisible
Posts: n/a
25K is not enough
The config is already given by praveen.SO im just copy pasting it
AMD64 Athlon 3000+ (Socket 939) - Rs 6300
ASUS A8N-E - Rs 5600
Leadtek Geforce 6600 128MB Graphics card - Rs 6500
Seagate 80GB SATA - Rs 2800
i-Ball Cabinet with 400W Real power supply - Rs 1500
Transcend 2x512MB (1GB) DDR 400 - RAM - Rs 5000 (overclockable to 210 Mhz clock freq)
Total - 27.7 x 1000
If u r out of budget then get only 512 MB RAM.Its enough.
Get Altec Lansing ATP 3 speakers also if budget permits.They rock
Old 10-02-2006, 11:04 AM   #3 (permalink)
the above config is good, but i suggest a vip cabinet and vip 400w smps there are cooling problems with i ball
915g not enough to comfortably play any new game.....even with a 3.0 ghz p4 and 1024mb ram....does anyone know a solution(plz dont tell me to add a graphics card...)
the mihir is offline
Old 10-02-2006, 12:21 PM   #4 (permalink)
sagar_coolx's Avatar
how much will dat cost?which cabby?
sagar_coolx is offline
Old 10-02-2006, 06:08 PM   #5 (permalink)
SNIST Screamer !!
vijay_7287's Avatar
there are cheaper alternatives frm kobian for around 500 bucks
i.e. cabinet only
vijay_7287 is offline
Old 10-02-2006, 08:40 PM   #6 (permalink)
Gaurav's Avatar
Thanks a lot. But What about this motherboard "MSI 915G Combo" is it good? and is it compatible with AMD.
Please tell me what config will be better with this mainboard (including the power supply and cabinet)
Gaurav is offline
Old 14-02-2006, 01:15 AM   #7 (permalink)
sorry gaurav
i do not support AMD proccy
it has a LGA 775 socket for proccy
the board only support intel proccy that to only 5XX or celeron 3XX
u can go for ASUS A8N-VM (integrated graphics controller available)
or
ASUS A8N-E (don't have onboard graphics controller)<-good if ur buying a GFX card anyway.
nd4spd is offline
Old 15-02-2006, 07:36 PM   #8 (permalink)
Gaurav's Avatar
Thinking of buying the following please help me in selecting the best one or if you have something better config please tell...
Graphics Card:
Ennyah GeForce FX 5700 256 MB DDR II
Mainboard:
MSI 915G NEO 2 Platinum with DDR 533
or
MSI 915G Combo DDR-II 533
Processor:
Pentium 4 920 CPU
one thing i am not able to understand what does the processor "Pentium 4 920 CPU" mean? what actually is it's speed or whether it's compatible with the boards i have mentioned.
I picked the configuration from digit (best ones only)
Gaurav is offline
