Go Back   Digit Technology Discussion Forum > Hardware > PC Components / Configurations
PC Components / Configurations Questions about configurations go here. Strictly Buying Advice - No troubleshooting here. Go through each and every sticky thread of this section and other sections before posting.
Old 25-01-2006, 11:29 PM   #1 (permalink)
Default need latest configration help?- urgent
hi,
i wanted latest hardware config of pc for my cousin. budget is 50-56000.
system is definately neither for gaming, nor for high graphic application.
processor - should be intel - ( wht abt 3.2ghz ht or any other good).
motherboard- best one....prefered with on board graphics(nt very necesary).
dvd wriiter - dual layer , with decent format support.
hard drive - minimum 250 gb, sata,sata2
Ram - which is good-ddr,ddr2
cabinet, ups, tft/Lcd screen - (suggest best).
please suggest best brands with model no....n price (if posible). Its urgent
sanjeev choudhary is offline
Old 26-01-2006, 12:49 AM   #2 (permalink)
Learner
Kniwor's Avatar
u have a very good budget.... i srongly request u get an AMD, u can make a very good machine with AMD.....
i have recently purchsed AMD 3200+ and is running as 3800+
my processor can easily beat at this setting Intel P4 3.73 Ghz EE ( Extreme Edition ), and i said EASILY,
AMD is the way to go friend...
Think about it......
I got this, i had budget just a little less than u, u can have some modifications to this....
http://www.thinkdigit.com/forum/viewtopic.php?t=36674
Kniwor is offline
Old 26-01-2006, 06:02 AM   #3 (permalink)
invisible
Posts: n/a
Yes go for AMD
Old 26-01-2006, 06:33 AM   #4 (permalink)
Learner
Kniwor's Avatar
and now finally after having time to overclock i am running my procy at 2.8Ghz stable...
now boy, hardly any intel can overclock this will in stock HSF....
Kniwor is offline
Old 26-01-2006, 02:03 PM   #5 (permalink)
thanks for reply, kniwor!
well dude, i dont know abt Amd much. How it is bettter then intel? i heard that amd has heating problem - is this true?.
R u realy sure Amd is better, coz i need the best in this budget so plese give details. how Amd cpu speed can be count in Ghz, wht does 3200+ , 3800+ states,is it equilent to 3.2 ghz , 3.8 ghz ?
reply pls!
Old 26-01-2006, 07:04 PM   #6 (permalink)
Learner
Kniwor's Avatar
reply pls!
this was the case in 2000-01...
Now AMD's are cooler than intel..
present day intel consume more heat than AMD's and have heating problems...
so basically it's the other way round..
Here's the proof..
http://www.tomshardware.com/2005/06/...est/page2.html
http://www.eweek.com/article2/0,1895,1852524,00.asp
sorry, these are very poor links, cant find good ones but i have seen benchmarks....
Kniwor is offline
Old 26-01-2006, 10:58 PM   #7 (permalink)
ok, dude
give me best config within 60,000 pls. I need the best !
if u want, i can extend my limit a bit more.
reply....waiting!
Old 27-01-2006, 03:38 AM   #8 (permalink)
Learner
Kniwor's Avatar
ok, dude
reply....waiting!
Ok, i could not get an opteron because i had budget problems... but u can get an opteron or an Athlon X2 3800+,
what would u prefer a dual core which is future proof or an opteron which is good for present but in future X2's are the kings...
just let me know and i will tell u the best possible cinfig based on that system...
I'll suggest a a dual core since u have the budget....
Kniwor is offline
Old 27-01-2006, 06:07 AM   #9 (permalink)
Yes dude, go for the AMD X2 Dual core processor, I have it and its really awesome. I think it retails in India for 19K so. You have the budget so dont look anywhere else. Go for the Asus A8N-E mobo if yu want a non SLI board or otherwise get only a 16x16x SLi based mobos like the ASUS A8N-SLI32 Deluxe.
The trick is to get a good base system config that includes the Processor, Mobo, Power Supply and the Graphics card. Spend more of yur budget over this as you can change/upgrade anything else later in the future at your convinience and you dont have to worry about yur core performance of the system for a few years. Thats the idea of a future proof PC.
hotdogXP is offline
Old 27-01-2006, 06:29 PM   #10 (permalink)
thaks, to you both.
well if AMD x2 Dual Core processor is good, then i wil go for it.
now tell which - processor 3800+,or any other better n one thing more are these processor 64 bit, wht abt cache memory(how much)? Wht is SLI? which mobo is best with SLI or without SLI to be future proof. Is Asus A8N-SLI32deluxe has sata2.0 ports & support ddr2?Wht abt Ram - which one & how much(mb, dd2,etc), Is Graphic card necessary? if yes suggest good one.
Don't wait, just post wht should i buy.(no need to ask again)
waiting....
Old 27-01-2006, 11:25 PM   #11 (permalink)
Learner
Kniwor's Avatar
yeah we are suggesting 3800+ and both cores are 64bit.... 512 KB L2 cache for each core, a total of 1Mb
ok here's my suggesion
AMD Athlon 64 X2 3800+
ASUS A8N-E motherboard
XFX Geforce 6600GT
2x512 Mb Corsair value select ram CL=2.5
200Gb Seagate SATA Barracuda
Colorsit 450 W SMPS
case of your choice
Kniwor is offline
