| Forum |
| PC Components / Configurations Questions about configurations go here. Strictly Buying Advice - No troubleshooting here. Go through each and every sticky thread of this section and other sections before posting. |
#1 (permalink) |
(i know i have posted this earlier in another thread but it seems no is replying) |
#2 (permalink) |
Posts: n/a
hmm, both are quite different,
Imac g5 will run Mac OS while Intel/AMD will run Windows/Linux To compete with a Dual PowerMac G5 while still being afordable I would say Athlon64 4200+ X2 1 GB DDR400, low latency from OCZ, Kingston or other such brand Geforce 7800GT, should be enough for any kind of gaming, or even a 6800 GT HD according to your need rest u can find from looking at the other posts in hardware section |
#3 (permalink) | |
Walking, since 2004.
Macs come in a package. The OS blends beautifully with the hardware to offer one complete package. If you want to consider the Photoshop CS2 benchmarks, the G5 1.8 ghz beats an Athlon 64 3200+ with the same amount of RAM in the system. I have been using my Mac Mini since 3 months now and I don't see how I can go back to windows. The scaleable icons, the brilliant GUI and the power of UNIX underneath.. makes a very good package.. oh btw.. did i mention it had Apache, PHP and an FTP server pre-installed.. all of which can be activated with the click of a button. Anyways, I wouldn't go beyond this.. I guess goobi would have a say here too
Mumbai, I miss you. |
#5 (permalink) | |
#6 (permalink) |
I think it all depends on usage. If your friend is a gamer, then Macs are a strict no-no. Otherwise, Macs are a good alternative to Windows-based PCs. If your friend has very basic needs, then a cheap, Windows/Linux PC or laptop will do well too.
| Bookmarks |
| Thread Tools | |
| Display Modes | |
