Go Back   Digit Technology Discussion Forum > Hardware > PC Components / Configurations
PC Components / Configurations Questions about configurations go here. Strictly Buying Advice - No troubleshooting here. Go through each and every sticky thread of this section and other sections before posting.
Old 30-12-2005, 11:58 PM   #1 (permalink)
jay4u's Avatar
Default Which config to go for....
i have two options... which one should i go for....
1. p4 1 mb cache 2.4 ghz 478 pin
intel 865gbf D
transcend 512 mb 400mhz ram
2. amd 3000+ (dont know porcessor... but budget for it is 6k... can u sugest one.. is my choice right)
msi rs 482 mobo
transcend 512 mb 400 mhz ram
Constraints are :
1. more emphasis on performance than gaming
2. keep my pc on for almost 10 hrs a day
3. least amount of noise from system
4. casual gamer
5. running for windows xp
6. future pcie graphics card will be added...
can u brief me out on the amd processor... is it ok.. means what are the different cores like venice core.. sempron etc.. plz i am new to amd...
Passwords are like underwear... Change them often...
jay4u is offline
Old 31-12-2005, 12:59 AM   #2 (permalink)
The Hardware Labs
mohit's Avatar
go for the amd config buddy. get an amd athlon 64 3000+ socket 939 processor. it will cost under 6k.
reasons,
64 bit processor
no issues of heating and noise
msi rs482 board has pci express architecture whereas intel 865 has agp.
it will perform much better in games due to the very good onboard grpahics of the msi rs482 board which is any day better than intel extreme graphics.
mohit is offline
Old 31-12-2005, 06:55 AM   #3 (permalink)
@jay4u
AMD is the thing of the future...Go for the 3000+ proccy with the MSI RS 482 board. Ya, its on-board graphix solution is very good for moderate gaming & other graphix-intensive applications. If possible go in for 2*512 MB RAm.....& u shall have a future proof system..(Atleast for the next 2-3 years)....Enjoy!
HK
h_kunte is offline
Old 31-12-2005, 11:46 AM   #4 (permalink)
No pain....No gain
john_the_ultimate's Avatar
I had bought amd64 3000+ venice core recently for Rs. 5700/-. And if ya don't want onboard gfx but want to buy a seperate pci-e gfx card then u can go for ASUS A8N-E, it costs around Rs. 5600/-.
john_the_ultimate is offline
Old 31-12-2005, 12:19 PM   #5 (permalink)
Location: formerly black mesa resarch center,now city 17,india
intel 865 has only agp 8x. go for amd.thers no point on an intel unless u plan to do video encoding 24/7. amd runs cooler. my 3000+ runs under 50.C most of the time.
ur best options would be a
amd 3000+
msi rs-482/gigabyte nforce 410 chipset
512mb ram.
I\'ll give u my rigs config once u give me the rig!
asdf1223 is offline
Old 31-12-2005, 03:01 PM   #6 (permalink)
jay4u's Avatar
okie guys... thanx a lot... will go for the amd solution... but which one is better msi rs482 or asus a8ne... in terms of features and performance other than gaming.....
Also if i want to buy a low end graphic card which shoud be the choice.. budget around 4k... i am thinking of xfx 6200 pcie.... i do not want to go for turbocache versions as i have heard that they uses system ram for performing.... what say guys...
jay4u is offline
Old 31-12-2005, 03:51 PM   #7 (permalink)
Manchester United
abhijit_reddevil's Avatar
Please also make sure that the graphics card memory has 128-bit interface.
Also as has been repeated many times Asus A8N-E wins hands down in terms of price vs. performance under 6k. It is the best if you invest in a separate graphics card. The MSI RS 482 has on-board ATI graphics in addition to a separate PCI-ex slot.
PS3-Ipod Touch 4G-Samsung Galaxy Ace-Sapphire HD 6870 Twin Frozer-Creative Zen:cloud9:
abhijit_reddevil is offline
Old 02-01-2006, 08:57 PM   #8 (permalink)
jay4u's Avatar
okie.. but can any one then sugest me a nice and budget pcie card... may be under 4k or 3.5k... just moderate gaming....
then i can go for asus a8ne as it is marginally higher than msi rs482
jay4u is offline
Old 03-01-2006, 10:30 AM   #9 (permalink)
No pain....No gain
Go for XFX/Leadtek 6200 256mb non turbo cache card. The non-TC card will perform much better than the one with TC. It should be within ur budget.
Old 03-01-2006, 11:14 PM   #10 (permalink)
jay4u's Avatar
how much will xfx 6200 non TC cost in mumbai....
jay4u is offline
Old 04-01-2006, 12:55 AM   #11 (permalink)
No pain....No gain
XFX 6200 pci-e 128mb may cost around 3500/- and 256mb may cost around 4000-4500/- don't know exactly. Plz do conform at ur local shop.
Old 04-01-2006, 01:26 AM   #12 (permalink)
invisible
Posts: n/a
TC cards will be cheaper XFX 128MB TC card will Rs 3000/- and they will be 64-bit or 32bit.
Its hard to find non-TC XFX cards.
For all XFX cards check this site http://www.rptechindia.com/rashib2c/...=2&Pagesize=10
My suggestion would be to get Leadtek WinFast PX6200 TD model card with 128MB and 128bit memory interface
Check this link http://leadtek.com/3d_graphic/winfast_px6200_td_2.html
U can get this card easily @ Rs 4000/- and also check the games which u are getting free with eitehr XFX or Leadtek
and also read this page http://www.thinkdigit.com/forum/view...3761&start=900
Old 04-01-2006, 05:46 PM   #13 (permalink)
jay4u's Avatar
i want to recomfirm the things.... i know amd is any day better than corresponding intel... but will amd 3000+ 64 venice core perform on par with intel 2.66 ghz 1 mb l2 cache prescott ready 478 pin processor....
i guess asus a8ne beats intel 915 gav.. but does it supports sata II standard....
jay4u is offline
Old 05-01-2006, 01:20 AM   #14 (permalink)
No pain....No gain
Amd64 3000+ venice is certainly perform better than intel 2.66 prescott, no doubt. And yes A8N-E supports SATA II.
Old 05-01-2006, 09:15 AM   #15 (permalink)
shariq_pj's Avatar
AMD... Hands down...
Sh@riq
<size=24>P R ! V ! L E G E</size>
shariq_pj is offline
Old 06-01-2006, 10:36 PM   #16 (permalink)
jay4u's Avatar
Thanks buddy.. can some one give me the rate.....
jay4u is offline
Old 07-01-2006, 01:44 AM   #17 (permalink)
No pain....No gain
Amd64 3000+ @ Rs.5700/- approx.
Asus a8n-e @ Rs.5600/- approx.
Pls confirm with ur local vendor.
Old 08-01-2006, 01:57 PM   #18 (permalink)
jay4u's Avatar
at mumbai i am getting asus a8ne for 6500 rs dude... and my dealer is sugesting to go for xfx 5300 PCIe 128 bit for 3100... is it a good graphic card for casual gaming... at low or med resolutions.......
jay4u is offline
Old 08-01-2006, 03:00 PM   #19 (permalink)
No pain....No gain
Rs.6500/- is too high for a8n-e, I myself bought it for Rs.5600/-. Don't know about 5300 so no comment.
Old 08-01-2006, 03:03 PM   #20 (permalink)
SNIST Screamer !!
vijay_7287's Avatar
i think u can go for XFX 6200 256mb
cost= Rs 3500
vijay_7287 is offline
Old 08-01-2006, 08:56 PM   #21 (permalink)
jay4u's Avatar
but vijay_7287 is xfx 6200 256 mb a non TC version... because a friend of mine brought a 6200 TC version and it sucks.. it really sucks...... and also can someone give me the shop name at mumbai laminton road where i can get Asus mobo a8ne undeer 5800 bucks.... even their url will do....
jay4u is offline
