16-11-2005, 09:09 PM
HELP FOR CONFIGURATION
HI FRIENDS,
I WANT TO UPGRADE MY PC SO I'LL BUY INTEL CELERON 2.4 GHZ. PROCESSOR AND I WANT TO KNOW WHICH CHIPSET MOTHERBOARD SHOULD I BUY WHETHER INTEL OR VIA OR ANYOTHER AND WHICH COMPANY'S MOTHERBOARD SHOULD I BUY I RESIDE IN DELHI SO PLEASE TELL ME THE RATES ALSO.
17-11-2005, 12:04 AM
it really depends on what ur budget is and what ur going to use the computer for....what are ur other specs.
Nitin Garg...
17-11-2005, 01:19 AM
Hi Friend
The best Mother board to go for is Intel or Asus,Both should be availiable in delhi.Check with the local computer hardware and stationary shop.
17-11-2005, 06:54 PM
I'VE A BUDGET OF LESS THAN 8K INCLUDING 256 RAM AND CABINET SO PLEASE TELL ME WHICH SHOULD I BUY AND HOW MUCH.
17-11-2005, 11:39 PM
well buddy it will b hard to get thse stuff for 8k but lets try.
1-Celeron 2.53D GHz 533MHz, 256kb, 478Pin-3k
2- D845GVSR-L-3.1k
3-256MB ram-1k
this is wat u shud go for i guess.
lets c wat others hav to say...
18-11-2005, 01:54 AM
better if u can buy a Pentium 4 2.66 ghz with Asus P5GL-MX motherboard
18-11-2005, 03:02 AM
Laptoping
Resort to AMD solutions. Get hold of Asus k8v-mx (2.8k) and 64 bit semprons. s754 Sempron 2500+ cost about 2.5k. You can add the 256Mb Ram stick and select a cabinet of your choice and return home saving 1k. And all the components are readily available.
18-11-2005, 12:08 PM
THANKS FRIENDS FOR UR OPINIONS IS THE AMD SAMPRON 64-BIT IS GREATER THAN INTEL CELRON PROCESSOR. I WANT TO PLAY THE NEW GAMES SO WHICH IS BETTER PLEASE SUGGEST FRIENDS.
18-11-2005, 01:01 PM
yea ofcourse sempron is betta than celeron.yups i guess sempron is gonna perform better then celeron while playing games,but mind it dont expect this rig to play all the games in medium to high settings.
18-11-2005, 01:30 PM
THANKS FOR SUGGESTION BUT I WANT TO PLAY GAMES AND WANT THE RIG UNDER 7K OF AGP SLOT MOBO SO WHICH SHOULD I BUY AMD OR INTEL AND FROM WHERE IN DELHI.
18-11-2005, 11:15 PM
under 7k or over 7k in my opinion ,AMD sempron 2500+ is better than ne celeron.
celeron r worse performin , less value fr money, n higher heatin issues.
longing for 7800gtx
Hai,
You can go for intel P4 2.66 (4.5K), Intel Original 915GAV MB (4.5K) with PCI Express AGP slot.
18-11-2005, 11:30 PM
@padikkal plz read the post properly before posting.his budget is less than 8k for processor,motherboard,ram,and cabinet.juz proc & mobo u hav suggested will coe around 9k.
19-11-2005, 12:23 PM
Thanks guys for ur opinion my friend had a celeron 2.53 ghz d processor and ATI9100 chipset motherboard with agpslot and 256mb ddr ram is his configuration ok. I like it so should I try it or not please give suggestion.
19-11-2005, 02:20 PM
Laptoping
You would have a tough time finding a motherboard with 9100IGP as they are phased out. Getting the sempron with k8v-mx is the best option. If you wanna game, increse your budget further and get a geforece 6200. Its that simple
19-11-2005, 03:04 PM
and if u can increase ur budget y not go fr amd 64 2800+(939) with ati rs482 chipset. on board gpu ati x200 equivalent 2 a pci-e x300. both ll come around 10000. the motherboard ll b future proof fr some time. and budget wise it wont b very far frm celeron 2.53D + ati9100+ 6200
and this ll b agp. certainly gettin outdated. wha say.
longing for 7800gtx
19-11-2005, 04:14 PM
Laptoping
There is no s939 amd 64 2800+. Probably u meant 3000+ which along with MSI RS 482 would cost 11k.
19-11-2005, 04:51 PM
sorry my mistake, i meant socket 754 2800+ with msi rs482 fr socket 754. this ll b cheaper around 10000.
longing for 7800gtx
