Go Back   Digit Technology Discussion Forum > Hardware > PC Components / Configurations
PC Components / Configurations Questions about configurations go here. Strictly Buying Advice - No troubleshooting here. Go through each and every sticky thread of this section and other sections before posting.
Old 02-11-2005, 05:17 PM   #31 (permalink)
Crazy_Eddy's Avatar
The Asus A8N-E costs around 6.4K. The Asus A8V-E costs 6K. I would definately opt for the A8N-E over the A8V-E.
The Asus A8V is next to impossible to find, and even then i would assume it to be priced around 6K as well.
Crazy_Eddy is offline
Old 10-11-2005, 04:31 PM   #32 (permalink)
Default Changing my budget
Actually my plan is to get a computer under 35,000 and now i have planned to increace my budget to 40,000. I asked my dad he said let us see at the time when v buy the comp. So i have planned to build an config under 40,000.
If my budget is 35,000 then my config is :
CPU-AMD Athlon 64 3200+( 939 ) venice core
Mother Board-MSI RS480M2-IL (939 socket)
Ram-Hynix 2*512 MB DDR 400 MHz
Hard disk-Seagate 80 gb Sata hdd
Monitor-Samsung SyncMaster 793s (black)
Optical drive-Lite-on DVD-Writer 16x drive (black)
Floppy Drive-Sony (black)
Keyboard-Logitech (black)Multimedia
Mouse-Logitech optical (black)
Power Supply-ANTEC 400 Watts (24 pins)
Cabinet-Any cabinet (black)
TV Tuner Card-Compro VideoMate PVR/FM
Please tell me a config under 40,000. I think changing the motherboard and getting a good graphics card will work out. also I think all the price has came down a lot.
Note: look for latest price @ http://www.deltapage.com/
navino87 is offline
Old 10-11-2005, 09:23 PM   #33 (permalink)
Learner
Kniwor's Avatar
Originally Posted by gxsaurav
U better check if nvidia Geforce 6100 or 6150 chipset based motherboards are available or not, they are good Onboard gfx capable motherboard with PCI-E slot for future upgrade
let me also tell u that the RS480 grahics and nVidia 6100 are the same as far as performance is concerned...only difference can be the overclocking features in nVidia 6100 chipset based boards...this is because the BIOS that was designed to encorporate overclocking features in RS480 did not allow it good performance in graphics at stock speeds...so ATI decided to scrap overclocking features...
Kniwor is offline
Old 11-11-2005, 10:15 AM   #34 (permalink)
Default Finalise
Can any one finalise my configuration and tell me the price of all the components under budget 40k.
Tell me a good mobo(With all features such as glan, good sound card, PCIe slot, and others) and a good graphics card which will come under my budget.
Thanks in advance..
navino87 is offline
Old 11-11-2005, 10:55 AM   #35 (permalink)
Aniruddh's Avatar
@navino pal ur config is quiet decent,but u can make few changes as now u hav increased ur budget and u will b goin for a external gpu.
1:-instead of MSI RS482M2 u go for ASUS A8NE mobo.
2:-go for atleast 160GB SATA2(hitachi),price diff between SATA and SATA2 is marginal so betta go for sata2 instead of that sata.
3:-Lite-on is gud but i'll suggest u to go for either sony or benq DVD-RW.
4:-Leadtek,XFX,BIG 6600GT.BIG 6600GT will b the cheapest amongs other brand.at the same time BIG is a gud performer according to most people in this forum so u can opt for that.
5:-go for KINGSTON,TRANSCEND DDR 400MHz ram.hynix is also gud D43 chip but other 2 r betta.
Aniruddh is offline
Old 11-11-2005, 11:23 AM   #36 (permalink)
Default mobo
Ok. Let me go for ASUS A8NE mobo. Tell me a graphics card which will come under my budget and it should have good performance.Also tell me the price of all the components.
navino87 is offline
Old 11-11-2005, 04:25 PM   #37 (permalink)
g_goyal2000's Avatar
Now that u have raised u'r budget, I think u should go for MSI Neo4 Platinum Board. It's got everything u can imagine of & is also future proof.
As for RAM, I think u should go for Transcend, Kingston or Corsair. Hynix is c_r_a_p.
For graphics card, check out the previous isssues of Digit as one of the issue (I don't remember which one) had done a test on various PCI-X16 graphics cards. U may get a fair idea on which one to buy.
And yeah, gor either Sony or Benq DVD-RW. They're both good.
Dell Studio 1558, Intel i5 M430 @ 2.27 Ghz, 4 GB RAM, 1 GB ATI 5470 Mobility, 500 GB HDD, IDT HD Audio with Creative X-Fi MB software
g_goyal2000 is offline
Old 11-11-2005, 07:00 PM   #38 (permalink)
Thanks to g_goyal2000, Aniruddh, Kniwor & others.
What is the price of MSI Neo4 Platinum Board. Is overclocking possible with this board ? Also give me details abt this board.
Tell me whether getting MSI Neo4 Platinum Board and a decent graphics card will come under my budget i.e.40,000.
navino87 is offline
Old 11-11-2005, 09:00 PM   #39 (permalink)
Aniruddh's Avatar
MSI K8N NEO 4 Platinum is bout 2k more then dat of ASUS A8NE.if u r gonna overclock then betta go for A8NE.NEO 4 Platinum is a very gud mobo but A8NE is betta and i m sure others will agree wid me.
Aniruddh is offline
Old 11-11-2005, 09:10 PM   #40 (permalink)
Default satisfied
I had gone through the spec of this mobo. I was satisfied a lot. But iam afraid whether this will come under my budget.
Please tell me price of all the components including MSI K8N NEO 4 Platinum & a decent low end graphics card.
navino87 is offline
Old 11-11-2005, 09:50 PM   #41 (permalink)
go for AMD 3000+ with A8NE. Its a great combo. There's no use spending 2000 bucks extra for 3200+ when with A8NE u can easily overclock your 3000+ to 3400+
if budget allows go for gfx6600 (non GT 128 MB, its for 6500 bucks) else 6200 is fine
AMD 64 3000+ Rs- 7300
A8NE Rs- 6700
harddisk 80 GB Rs- 3000
RAM 2*512 MB Rs- 5000
GFX 6200 Rs- 3500
Cabinet + PSU Rs- 3000
Monitor 17" Rs- 6000
Keyboard/ MOuse/Speaker Rs- 2000
TV Tuner Rs- 2000
DVD Writer Rs- 3000
Rs- 41,500
So its better to go for ATI chipset RS480 based motherboards that come with decent graphics + most of the features + PCI-E for future upgrades. And its around 5k....... That means u save around 5k if u go for it as u won't probably need a graphics card then...... if u aren't a gamer.
samanvya_ad is offline
Old 12-11-2005, 10:35 AM   #42 (permalink)
Default MSI K8N NEO 4 Platinum
I am fully satisfied with MSI K8N NEO 4 Platinum mobo I want to know the price of this mobo.
And the gfx card I decided is Gainward geforce 6200 256 mb or XFX geforce 6200 256 mb. Which will be best and have a great value for money?
Also tell me the price difference between Samsung SyncMaster793s & 793mb?
I think the price of all the components has come down. Please check the latest price @ http://www.deltapage.com
navino87 is offline
Old 12-11-2005, 10:45 AM   #43 (permalink)
AMD64 3000+ (Venice) 6000
Gigabyte K8N51GMF(nF51) 4500
BIG GeForce 6600 GT PCI-E 8500
Samsung 793s 6200
Transcend 2*512 DDR400 4800
Hdd 80GB SATA 2900
DVD Writer 3000
Keyboard+Mouse+FDD 1000
Cabinet + Powersafe 400W 2200
Compro VideoMate PVR/FM 2500
Total Rs. 41600/-
Education... has produced a vast population able to read but unable to distinguish what is worth reading
AGENT_SMITH is offline
Old 12-11-2005, 11:40 AM   #44 (permalink)
gxsaurav
Posts: n/a
Default Re: MSI K8N NEO 4 Platinum
6200 with 256 MB is not the best value for money, although it's 6600GT but if it's costly for U, then try to buy a 6600 non ultra with 256 MB with good cooling & overclock it to GT speeds
Old 12-11-2005, 12:04 PM   #45 (permalink)
Default enough
I dont want 2 spend more on graphics card since by budget is limited to 40,000.
Can v play all the latest games with this geforce 6200 256 mb?
What about the price of MSI K8N NEO 4 Platinum mobo.
Will this all come under my budget ?????????????????
navino87 is offline
Old 12-11-2005, 01:19 PM   #46 (permalink)
Samsung 793s 6200
Hdd 80GB SATA 2900
DVD Writer 3000
Total Rs. 41600/-
Where do u get AMD 3000+ in 6000 bucks
I don know the correct price...... www.computerwarehousepricelist.com says its 7050/-
Old 12-11-2005, 01:53 PM   #47 (permalink)
The Hardware Labs
mohit's Avatar
@navino87
I suggest the MSI K8NE04 PLATINUM if you have the budget ..just coz it has creative onbaord 7.1 sound and also looks much better .. its priced around 2k more than asus though.
mohit is offline
Old 12-11-2005, 02:24 PM   #48 (permalink)
Default Re: enough
Please reply for this.
navino87 is offline
Old 12-11-2005, 02:33 PM   #49 (permalink)
The Hardware Labs
mohit's Avatar
ya u can play all the latest games on a 6200 256 mb but at low settings only .. i suggest a 6600gt 128 mb instead .. save on the mobo and buy a asus a8n-e and use a 6600gt instead. that will be the best combo in your budget i suppose.
mohit is offline
Old 12-11-2005, 07:34 PM   #50 (permalink)
gxsaurav
Posts: n/a
u will be able to play quake 4 (reference here) only at 640X480 with a Geforce 6200 with 256 MB RAM, the extra RAM will not help the 6200, it's under powered,
mohit, he is already going over budget, i still suggest a 6600 non ultra with 128 MB or 256 MB RAM, & when playing games overclock it
Old 12-11-2005, 11:33 PM   #51 (permalink)
A MSI K8N Neo4 Platinum board along with AMD Athlon64 3200+ will cost u around Rs. 14500-15500.
As for graphics card, can't say cos haven't been inquiring about them much lately.
I live in Delhi. So my main source of info on availablbe h/w & their prices is Nehru Place.
As I said in my previous issue, u can check out the previous issues of Digit for graphics card prices.
Or better still, u can check out www.npithub.com .
U'll get latest prices there.
Old 13-11-2005, 12:32 AM   #52 (permalink)
my friend has 6600 gt 256 mb for only 4000 he buyed it on lamington road
roon294 is offline
Old 13-11-2005, 12:34 AM   #53 (permalink)
Aniruddh's Avatar
@roon man u must b kidding.i dun belive that sumone got 6600gt for juz 4k.it must b 6200 not 6600gt.
Aniruddh is offline
Old 14-11-2005, 07:18 PM   #54 (permalink)
Default Thanks
Ok. Let me go for geforce 6600 gfx cards Which gfx card to prefer? Big geforce 6600 or XFX geforce 6600 Non GT Video cards. Also tell me about Big geforce 6600GT.
I also planned not to get tuners and other accessories for now. So that I can go for a powerful configuration. Also tell me the price of MSI K8N Neo4 Platinum board.
navino87 is offline
Old 15-11-2005, 10:20 AM   #55 (permalink)
gxsaurav
Posts: n/a
XFX 6600 non Ultra with 256 MB DDR2 memory, overclocked to GT speeds, not only runs cool but it's also the best bang for buck right now
Old 17-11-2005, 12:06 PM   #56 (permalink)
Default price
Is the price mentioned in this site is currect? -->> http://www.deltapage.com/
All the components are very cheap than other dealers in chennai. I mailed them and asked the price of Benq 1640 DVD-Writer they said that it is Rs. 2900 & the rate of Sony DRU-810A DVD-Writer is Rs.3550. Is benq's price is less than sony?????????????????????????
Others :
AMD Athlon 64 3200+( 939 ) Venice core Rs. 7900
ASUS A8N-E Rs.5600
A8N-Sli - 8800
Hynix 512 MB DDR 400 MHz Rs.1900
Seagate 80 gb Sata hdd Rs.2950
Samsung SyncMaster 793s (black) Rs.5400
ANTEC 400 Watts (24 pins)Smartpower 400w Rs.3800
Please Check this prices
navino87 is offline
Old 18-11-2005, 02:28 PM   #57 (permalink)
Default BUY
Is all the prices mentioned above are currect ? Can i buy the new computer without any fear of being cheated ?
navino87 is offline
Old 20-11-2005, 03:23 PM   #58 (permalink)
Default Final configuraton
Here goes my final configuration :
ASUS A8N-E
BIG geforce 6600 256 mb
Hynix 512*2 MB DDR 400 MHz
Benq 1640 DVD-Writer 16x drive
Floppy Drive
Logitech Multimedia KB+M
Cabinet Antec SONATA True Power 380 W
Thanks a lot for all the digit members for helping me.
But still i have some query regarding this config.
1. Is overclocking is possible with BIG geforce 6600? If yes, till what extent it can be overclocked ? Can this card be overclocked to an BIG geforce 6600GT ?
2. Till what extent an 3200 processor can be overclocked ?
3. Is 256*2 MB DDR 400 MHz ram will be enough? What is the benefit of an 512*2 MB DDR 400 MHz Over 256*2 mb ram?
4. Is 380 watts power supply is enough for this config ?
5. Is there any difference between BIG geforce 6600 Non GT and BIG geforce 6600LE ? What is the difference ?
Also post your suggestion on this config.
I once again thank all the members.
navino87 is offline
Old 20-11-2005, 04:57 PM   #59 (permalink)
1. all 6600 cards can b clocked upto GT speeds.
2. that depends on ur board,cooling and ur bravery.
3 again if u want to run video editing softwares , maya, etc 1 gb ram is must fr everything else 512 ll b ok
4. should be enough because its antec.
longing for 7800gtx
hummer is offline
Old 21-11-2005, 02:22 PM   #60 (permalink)
navino87 is offline
