Results 1 to 30 of 34
08-02-2013, 09:30 PM #1
Rig for friend...configuration required
Hi guys, please provide a PC configuration for my friend,
Required info are mentioned below
1. What is the purpose of the computer? What all applications and games are you going to run?
Ans:
1>HD movies
2>Games (He loves Prototype...so that kinda games and probably all latest titles)
3>Downloading.
I know him very well. He's going to do exactly these three things only with his PC.
2. What is your overall budget? If you can extend a bit for a more balanced configuration, then mention this too.
Ans:
Not more than 40K.
3. Planning to overclock?
Ans:
No
4. Which Operating System are you planning to use?
Ans:
Win7/8
5. How much hard drive space is needed?
Ans:
1TB
Ans:
He likes my DELLU2312HM and gonna get that. But, while calculating the price count its price too.
Ans:
Speakers.
8. When are you planning to buy the system?
Ans:
ASAP
Ans:
No and assembler would do this.
Ans:
Kolkata.
Buying locally (Please refer good shops, if you know)
Ans:
Need all components of a normal PC. All bole to all including UPS.
Thanks guys."My opinions may have changed, but not the fact that I am right."
"Its easy being atheist than secular"
08-02-2013, 09:38 PM #2
Re: Rig for friend...configuration required
SUB 40k -
Component Model Price Processor Intel Core i3 3220 7287 Motherboard Gigabyte GA-B75M-D3H 4346 Ram G.Skill F3-10666CL9S-4GBXL 1513 Graphic Card MSI R7770-2PMD1GD5 8848 HDD WD 1TB Caviar Green WD10EARX 4150 DVD Drive Asus DRW-24B5ST DVD 1146 PSU Corsair CX430 V2 2703 Cabinet Zebronics Bijli 1000 Monitor Dell ST2220L 8800 Keyboard-Mouse Combo Logitech MK100 450 Speakers Logitech Z110 550 UPS APC BR600VA-IN 1900 Total 42748 Last edited by Gaurav Bhattacharjee; 08-02-2013 at 09:47 PM.
Athlon II X2 260 | Gigabyte GA-78LMT-S2P | HIS IceQ Radeon HD5670 1GB GDDR5 | Corsair Value 1x4GB 1333MHz | Cooler Master Elite 311 | Corsair CX430V2 | WD Caviar Blue 160GB | Viewsonic VA503m | Logitech Z110 | Sony DVD-RW AD-7240S | Generic Keyboard & Mouse | Zebronics 700VA
SteamID
09-02-2013, 12:40 AM #3
The above configuration is really very good and properly balanced. Just get Toshiba 1TB 7200RPM SATA Internal Desktop Hard Drive (DT01ACA100) (LINK) instead of the WD Caviar Green HDD. WD Green HDDs are not of good build quality and perform slower than the normal 7200 rpm HDD. The Toshiba one is a true 7200 RPM HDD and comes with 3 years of warranty.
AMD FX 8350|16 GB RipjawX 1873 MHz CL10 @ 1.6V MHz|1+2TB Seagate + 1 TB WD Green 64MB Cache|Sabertooth 990FX|Sapphire HD 7950 VApor-X OC with Boost|GT 240 1 GB GDDR5 PhysX|CM690II Advanced|LG D2342P Cinema 3D Display|TX850 V2|2 CM 1600RPM FAN|MX518|Razer Goliathus|Razer Arctosa|Razer Megalodon 7.1 Headset|CM Hyper 212 Plus|APC1.1KVA| Moto Defy Plus|HCL Me Y2 Tab (rooted)
09-03-2013, 01:13 AM #4Right Off the Assembly Line
- Join Date
- Feb 2013
- Location
- Newtown, Rajarhat, Kolkata
- Posts
- 15
I am new to this forum and need ur help !!!
I am also going to buy a gaming PC. My bugget is around 50k and I have found the belo config. Please suggest me how is this config?
There are more than one option also which I have selected and I need ur help to sort it out for the best.
It will be very helpful if u guys ca provide an estimate for the below config also.
Thanks in advance for ur help.
Component Model number
Processor: Intel Core i5 3470 OR AMD FX 8350 (8 Core, 4 GHz with 4.2 GHz Turbo, 8 MB L2 + 8 MB L3 Cache)
Motherboard: Gigabyte GA-B75M-D3H OR Asus M5A97
RAM: Corsair Vengeance DDR3 8 GB (2 x 4 GB) PC RAM (CMZ8GX3M2A1600C9R) OR G-Skill RipjawX 1600 MHz CL9 4GB X 2
Graphics card: Sapphire HD7770 or MSI R7770-2PMD1GD5 OR Sapphire Radeon HD 7850 2GB GDDR5 Graphics Card
HDD: Toshiba DT01ACA200 2 TB
PSU: Corsair CX430V2
Monitor: Dell 22" S2240L IPS Panel 1080P Display
DVD Drive: Asus DVD-RW Black
Chassis: NZXT Source 210 OR Corsair 200r OR 300r
KB & Mouse: Logitch MK200
UPS: APC BR600VA-IN
Speaker: Logitech Z103
Also suggest if I have missed something in above config.....
09-03-2013, 09:40 AM #5Broken In
- Join Date
- Dec 2012
- Posts
- 180
For full hd resolution you should take a 7850 as minimum. And dont waste your money at vengeance when you most probably wont overclock it with a b75 mobo. Get corsair's 1600mhz value ram. And you might wanna get a better psu, if you dont want to buy a new one next time, its sufficient for hd 7850 but anything above that I will be doubtful
09-03-2013, 10:07 AM #6
@amibisu
start a new thread...
+1 to Gaurav's config . .. The Cost Go more than 5K If he buys HD 7850....
So that is a Perfect Rig for OP...Intel Core I5 2400 | Intel DH67CL B3 | Corsair Value Select 2x 4 GB | Seagate Barracuda 500 GB HDD | Asus DVD RW | CM Elite 310 | Corsair GS600 | Logitech MK200 | Creative Speakers | Samsung S20B300 | V Guard UPS | Intel HD 2000 | Nokia Lumia 520 |
09-03-2013, 10:11 AM #7
My recommendation would be replacing Corsair PSU with Seasonic SII 620/520.
Using it for one year and its a bliss.
Guys @amibisu is "THE" friend for whom this thread was created
Seems, he could not resist the temptation and registered here...welcome mate, have a nice stay"My opinions may have changed, but not the fact that I am right."
09-03-2013, 03:27 PM #8Dragon...Dragon...Dragon.
- Join Date
- Jan 2013
- Location
- Bhubaneswar
- Posts
- 328
Lol...
anyways is ur budget 40 or 50k??
Lol...
12-03-2013, 10:31 PM #9Right Off the Assembly Line
- Join Date
- Feb 2013
- Location
- Posts
- 15
My budget is 50k..
13-03-2013, 12:40 AM #10
Though the config looks balance for a HTPC, its not so much for gaming.
1080p gaming, add a HD 7850 at min.
Take 500GB & add 2TB later. No big deal with HDD's
Corsair GS600 will be a resonable PSU here rather than CX430 v2 for HD 7850.
Lastly, Why Ripjaws or Vengeance kits for a non-OC config ??
Get those Corsair Value DDR3 1333Mhz 8GB [4GB x 2]. Saves a lot end of the day.
Also don't forget you pay 5% for vat on the total. So keep a check dude....
All the best.Last edited by d3p; 13-03-2013 at 09:01 PM.
2600k|Maximus IV Ex-Z|Venomous X RT CM R4's Push Pull|RipjawX 16GB|Sapphire HD7970 CF [1250MHz]|OCZ Vertex 3 120GB|WD Black Raid 0|AX850w|Asus Xonar DX|Dell U2412M x 3 Eyefinity|HAF 932 Advanced|Sentry II| Logitech G27, G15, Attack II, C310 HD|Razer DeathAdder, Megalodon|Steelseries Ikari Optical|
My Game Collection & Sapphire HD 7970 Unboxing
13-03-2013, 08:19 PM #11
Please stick to the HD 7850 as bare minimum for Full HD gaming. The HD 7850 is budget priced and is worth the premium over the HD 7700.
Strictly gaming? Stick to a quad core by Intel (any Ivy Bridge)About me:
http://about.me/preetam_nath
13-03-2013, 09:07 PM #12
"Stupid People has two main parts from their brains, the left and the right, like normal people. But the problem is that there is nothing right in their left brain and there is nothing left in their right brain!"
13-03-2013, 09:52 PM #13
Please change your cabinet from Zebronics to any entry level cabinet from reputable brand. I doubt if it can house a Radeon 7850.
You can opt for NZXT CABINET SOURCE 210 ELITE / BitFenix Merc Alpha as per your choice. Corsair will be a bit costly though and may not suit your budget.
13-03-2013, 10:11 PM #14Right Off the Assembly Line
- Join Date
- Feb 2013
- Posts
- 26
13-03-2013, 10:47 PM #15
zeby cabi is fine.hd 7850 will fit in it
13-03-2013, 11:22 PM #16
Well cabinets are something which people generally don't change while upgrading their pc. Reputed brands like NZXT/Bitfenix/Corsair etc take care about the functional aspects and features that the end consumer will be getting. You get decent space which can accommodate most of the Graphics card, clean layout, ample connectivity options & some cable management too. Plus the build quality is superior too.
Go, through the review of Zebronics Bijli. You'll understand the design / functional aspects m talking about.
Zebronics Bijli cabinet review
A more standard review of Zebronics Bijli....
http://hardwarebbq.com/2011/11/zebronics-bijli-2/all/1/
The point is, when you are spending 50K for an entire rig, spend 1K more to get a decent Chassis. You won't regret it..
14-03-2013, 12:07 AM #17
The config looks great but would just ask you to get a ASUS GTX650Ti for Rs 10300 over the HD7770,that is keeping gaming in mind. And change the monitor to a Dell S2240L an IPS LED full HD panel for Rs 8900.
Q : One of the most over rated useless gadget ever built in the Human History?
A : The Tablet.(give me a pill instead!)
14-03-2013, 12:20 PM #18Right Off the Assembly Line
- Join Date
- Feb 2013
- Location
- Posts
- 15
Thanks to all u guys ....
This Rig is strictly for gaming and 1080P movies (as I mentioned earlier)
After reviewing all ur comments, I have sort out a new config below. Please suggest it..
Component Model Number
Processor: Intel Core i3 3220
Motherboard: Gigabyte GA-B75M-D3H (OR) Asus M5A97
Graphics Card: Sapphire HD7770 (OR) ASUS GTX650Ti (Preferred) (Suggest)
HDD: Toshiba DT01ACA100 1 TB
PSU: Corsair GS600
Chassis: (Suggest)
UPS: APC BR600VA-IN
Once again thank u all....
14-03-2013, 12:32 PM #19
14-03-2013, 12:59 PM #20
I think OP should stick with a 500W PSU and save some money. 600W PSU is way overkill for the configuration.
14-03-2013, 02:49 PM #21
Even 500w seems like a lot. Locked i5s and 7850s can do with less.
The Corsair 430w can easily power the i3 and the 650ti.Need Help :Spoiler:
* Looking to purchase Noctua NH-U12P SE2 :(
14-03-2013, 02:55 PM #22
Intel i3 3225 - Rs 7100
Gigabyte GA-B75M-D3H - Rs 4150
Corsair Value Select Ram 4 GB - Rs 1350
GPU - Asus GTX 650Ti - Rs 10300
HDD - Toshiba 1TB - Rs 4150
SMPS - CORSAIR SMPS-CX430V2 - Rs 2550
Cabinet - NZXT Gamma - Rs 2300
Display - Dell S2240L - Rs 8900
OPD - Samsung SH-S223F - Rs 975
KB/Mouse - Logitech - Rs 600
UPS - Beetel Saviour 700VA - Rs 1325
I think you are good to go with this one. And the M5A97 mainboard is for an AMD processor.You are fine with B75 here.Q : One of the most over rated useless gadget ever built in the Human History?
19-03-2013, 02:09 PM #23Right Off the Assembly Line
- Join Date
- Feb 2013
- Location
- Posts
- 15
Thanks to all for ur helps .....
Finally I have found the best (as per requirement) Rig config as below.
Component: Model Number: Price
Processor : Intel Core i3 3225 : Rs. 7100
Motherboard: Gigabyte GA-B75M-D3H : Rs. 4150
RAM: Corsair Vengeance DDR3 8 GB (2 x 4 GB) PC RAM (CMZ8GX3M2A1600C9R) : Rs. 3584
Graphics Card: ASUS GTX650Ti : Rs. 10300
HDD: Toshiba DT01ACA100 1 TB : Rs. 4150
PSU: Corsair GS600 : Rs. 5366
Monitor: Dell 22" S2240L : Rs. 8900
DVD Drive" Asus DVD-RW Black : Rs. 1200
Chassis: NZXT Gamma : Rs. 2300
KB & Mouse: Logitch MK200 : Rs. 925
UPS: APC BR600VA-IN : Rs. 1900
Total : Rs. 49875 + VAT/TAX
Still only one confusion for PSU: Corsair GS600 / 500W ? Don't know if there is any noise problem with 500W. Going for GS600 as of now, but if there is no noise prob with 500W, will go for it.
19-03-2013, 02:33 PM #24
Are you buying from Flipkart? The PSU price is actually high.
19-03-2013, 02:37 PM #25
19-03-2013, 04:15 PM #26
The PSU price is way higher than local. You could get a 750w PSU from Seasonic for that amount. Corsair GS500 @ 4k is perfect for your rig.Also the price of GTX 650 Ti is 9.8k.....
19-03-2013, 08:51 PM #27Right Off the Assembly Line
- Join Date
- Feb 2013
- Location
- Posts
- 15
@ASHISH65: For i3 3220 and 3225, I can only see one difference between the two and that's the integrated graphics. HD2500 vs HD4000. So what's the difference and which one will be best for my rig (gaming)?
@Sainatarajan: Are you suggeting me Corsair GS500 for my rig? I heard about some noise issue for this during pick load/pressure.
Please suggest...
I am not buying from flipcart, though I have got the price from flipcart. Will go to Chandni Market...
19-03-2013, 09:44 PM #28
Get the i3 3220... The igp of both would be as good as useless as you are buying a discrete gpu...
19-03-2013, 10:01 PM #29Right Off the Assembly Line
- Join Date
- Feb 2013
- Location
- Posts
- 15
Thanx @sbnaul
22-03-2013, 06:09 PM #30Right Off the Assembly Line
- Join Date
- Feb 2013
- Location
- Posts
- 15
Hey guys pls recomend some good shops in Chandni, Kolkata....
Gonna buy my rig tomorrow there...
Thanks in advance !!!
Also need ur help here..
1. Want to watch TV from through my system (buying Dell 23" LED - U2312HM Monitor). What to do for that? I mean to say, should I go for TV tuner card or there is any other way around?
2. We are currently using RYB type cable for TV with setup box (not HDMI, I suppose). So any compatible way to use it? One of my friend suggest me to buy an RYB cable splitter. Can I go for it?
3. Also got suggested for buying Creative 3-in-1 bluster card for good sound controller. Can I go for it?
LinkBack URL
About LinkBacks
