Results 1 to 6 of 6
  1. #1
    Apr 2012
    Default mid-range rig help
    Ans:gaming. mw 12,brddrlnds 2,absolution
    2.What is your overall budget? If you can extend a bit for a more balanced configuration, then mention this too.
    Ans:50 -52k
    3. Planning to overclock?Ans:no
    4. Which Operating System are you planning to use?Ans:win 7 64
    5. How much hard drive space is needed?Ans:500 gb
    Ans:want to buy a new one.21 inches.1600x900
    Ans:ram,hdd,dvd rom
    8. When are you planning to buy the system?Ans:mostly 9|2|13
    9. Have you ever built a desktop before or will this be done by an assembler?Ans:no.assembler
    Ans:hyderabad.i am buying locally.i can buy online
    *I have listed the following parts. Please make some suggestions (any cheaper and better alternatives). And is everything okay(all sizes and form factors).*Processor – i5 3550*Mobo- intel db75en*Monitor – (suggest a 1600x900 one below 6000)*Gpu-asus engtx 560*Cabinet – suggest something below 4000(mostly cooler master )PSU-corsair gs 600(or shud I opt for a *seasonic 600W one)Speaker- mostly altec lansing v2621
    Ans:****
  2. #2
    Live.To.RISE. rajatGod512's Avatar
    Aug 2011
    Kanpur,India
    Default Re: mid-range rig help
    Processor: Intel Core i5 3550 @ 12.4k
    Motherboard : MSI ZH77A-G41 @6k
    PSU : Seasonic S12II 620 @ 5.4k
    Cabinet :Crosair 400R @ 4.6k
    Monitor: Dell IN2030M @6.8k
    GPU:MSI HD 7850 PE 2GB @15K
    Total-50.5k
    Now you can buy any speaker you want by the money left with you . You can get a FULL HD Display if you cut on the cabinet and get a NZXT source 210 elite for 2.6k then you can buy a BENQ GW2250HM for 8.6k.
    Please tell what RAM do you have Name of manufacturer , DDR Version , size .
    The Final Avenger
    Core i7 2600k|ASUS P8Z77-V LX|G.Skill Ripjaws X 1600 Mhz 8GB (4x2)|Gigabyte HD 7850 2GB OC|WDC Blue SATA III 500 GB +160GB |Asus DRW-24B5ST|Seasonic S12II-520|CM 690 II Advanced USB 3.0 (Transparent Side Panel)|Logitech G300|Logitech K100|F&D A-520|Razer Goliathus Speed|Compaq 510|Samsung Galaxy Y GT-S5360|
    “Today, at the edge of our hope, at the end of our time, we have chosen to believe in each other. Today, we face the monsters that are at our door. Today, we are canceling the apocalypse!”
  3. #3
    Wise Old Owl Sainatarajan's Avatar
    Apr 2012
    Santiago Bernabeu , Madrid , Spain
    Gigabyte GA-H77M-D3H - Rs 5500
    This would be a good mobo in my opinion........
    Intel Core I5 2400 | Intel DH67CL B3 | Corsair Value Select 2x 4 GB | Seagate Barracuda 500 GB HDD | Asus DVD RW | CM Elite 310 | Corsair GS600 | Logitech MK200 | Creative Speakers | Samsung S20B300 | V Guard UPS | Intel HD 2000 | Nokia Lumia 520 |
  4. #4
    Wise Old Owl harshilsharma63's Avatar
    Jul 2012
    Jodhpur
    cpu: i5 3450 rs.11180
    Mobo: Gigabyte b75 mh3 rs.4134
    Cabinet: cooler master 430 rs.2800
    Gpu: saphire hd7850 2 GB rs.13800
    Kb & mouse: logitech mk200 rs.700
    Monitor: lg s22b370h rs.8800
    Ram: gskill ripjawx 1600 MHz 2 GB x2 rs.2000
    Psu: corsair cx600v2 rs.3900
    Total: 48315
    Intel i3 2100 3.1GHz | 2x2 GB DDR3 RAM 1333 MHz | Intel DH61WW | Seagate Barracuda 500 GB | Corsair CX430v2 | Zebronics Oval | LG 22" HD | Logitech KB mouse combo | Seagate Extension 500 GB portable HDD | APC 600 VA UPS | Philips SHP 2000
    Join TDF IRC channel at
    http://webchat.freenode.net/?channels=krow or use client: server: irc.freenode.net port: 6667 channel: krow
  5. #5
    laborare est orare Cilus's Avatar
    Mar 2009
    Kolkata
    Buddy, there is no point of gpoing for 2X2 GB Ram kit now. Get 4GB X2 instead. Also try to squeeze a Sapphire HD 7870 @ 16.7K within the budget. It will be a more future proof solution. Current generation games like Far Cry 3, Hitman Absolution or the upcoming Crysis 3 can easily stress the highest end GPU at the highest settings. So getting a better GPU always help in gaming.
    AMD FX 8350|16 GB RipjawX 1873 MHz CL10 @ 1.6V MHz|1+2TB Seagate + 1 TB WD Green 64MB Cache|Sabertooth 990FX|Sapphire HD 7950 VApor-X OC with Boost|GT 240 1 GB GDDR5 PhysX|CM690II Advanced|LG D2342P Cinema 3D Display|TX850 V2|2 CM 1600RPM FAN|MX518|Razer Goliathus|Razer Arctosa|Razer Megalodon 7.1 Headset|CM Hyper 212 Plus|APC1.1KVA| Moto Defy Plus|HCL Me Y2 Tab (rooted)
  6. #6
    Tensor Gaurav Bhattacharjee's Avatar
    Feb 2010
    Guwahati
    Component Model Price
    Processor Intel Core i5 3550 12400
    Motherboard Gigabyte GA-B75M-D3H 4346
    Graphic Card Sapphire HD7870 GHz Edition 17000
    PSU Corsair CX600V2 4050
    Cabinet NZXT Source 210 Elite 2900
    Monitor Dell IN2030M 6300
    Keyboard-Mouse Combo Logitech MK100 450
    Speakers Altec Lansing BXR1221 1299
    UPS APC BR1100VA-IN 4900
    Total 53645
    Athlon II X2 260 | Gigabyte GA-78LMT-S2P | HIS IceQ Radeon HD5670 1GB GDDR5 | Corsair Value 1x4GB 1333MHz | Cooler Master Elite 311 | Corsair CX430V2 | WD Caviar Blue 160GB | Viewsonic VA503m | Logitech Z110 | Sony DVD-RW AD-7240S | Generic Keyboard & Mouse | Zebronics 700VA
    SteamID
