Results 1 to 5 of 5
  1. #1
    Jan 2013
    Default Compact PC under Rs25000
    Ans: light gaming on medium settigs like assassins creed , fifa12 ,cs1.6, resident evil 5, nfs:mw and watching movies, school projects on ms office, internet browsing, light pic editing on picasa etc
    2. What is your overall budget? If you can extend a bit for a more balanced configuration, then mention this too.
    Ans: not more than 25K
    3. Planning to overclock?
    Ans:No
    4. Which Operating System are you planning to use?
    Ans:Windows 7 Pro
    5. How much hard drive space is needed?
    Ans:500Gb
    Ans:No, I'll use my 42" LG full hd tv
    Ans:speakers,monitor
    8. When are you planning to buy the system?
    Ans:may/june 2103 after my 10h results
    Ans:assembler
    Ans: Online if not avilable locally
    Ans: The rig should be at least 5 years no upgrade type.. m not intrested in a blue ray player a seperate graphic card that is the reason i have used an intel cpu instead of an AMD one.
    I have currently decieded on the following
    -CPU
    Intel Core i3 3220 @3.3GHz = Rs 7169
    __________________________________________________ _____________
    -MoBo:
    Intel DH67BL Motherboard = Rs 5960
    -RAM:
    Corsair ValueSelect 4gb DDR3 PC RAM (1600MHz) = Rs 1456
    -HDD:
    Toshiba 3.5” 500 Gb Hard disk drive (SATA 6.0 Gbps) = Rs 3279
    -Cabinet:
    Cooler Master Elite RC344 Mini Tower mATX Cabinet = Rs 2170
    __________________________________________________ ______________
    -PSU:
    Corsair VS450 450W PSU = Rs 2350
    -Keyboard&Mouse:
    MS Wireless Desktop 800 Keyboard and Mouse Combo = Rs 1487
    Total Cost = Rs 23871
    Any suggestions especially about the cabinet as i want to put it near my pcc are welcome.. thanks in advance!
  2. #2
    laborare est orare Cilus's Avatar
    Mar 2009
    Kolkata
    Default Re: Compact PC under Rs25000
    Get the following:-
    AMD A10-5800K Trinity APU (Quad Core, 3.8 GHz with 4.2 GHz Turbo Core, 4MB Cache) @ 8.2K
    Radeon HD 7660D Integrated DirectX 11 Class GPU (800 MHz Clock, 384 Stream processor)
    Asus F2A85-M-LE @ 4.7K
    Corsair Vengeance 1600 MHz 8GB X 1 DDR3 @ 2.7K
    Toshiba 1TB 7200RPM SATA Internal Desktop Hard Drive (DT01ACA100) @ 4.3K
    Normal Cabinet w/o SMPS @ 0.7K
    Corsair VS450 PSU @ 2.2K
    Logitech Mk100 Keyboard & Mouse Combo @ 0.4K
    Asus 24X SATA DVD R/W @ 1K
    AMD FX 8350 @ 4.5 GHz|16 GB RipjawX 1873 MHz CL10 @ 1.6V|1+2TB Seagate + 1 TB WD Green 64MB Cache|Sabertooth 990FX|Sapphire HD 7950 VApor-X OC with Boost|GT 240 1 GB GDDR5 PhysX|CM690II Advanced|LG D2342P Cinema 3D Display|TX850 V2|2 CM 1600RPM FAN|MX518|Razer Goliathus|Razer Arctosa|Razer Megalodon 7.1 Headset|CM Hyper 212 Plus|APC1.1KVA| Moto Defy Plus with CM 10.1 JB 4.1|HCL Me Y2 Tab (rooted)] XOLO Q800 with Ultimate V2 JB 4.2.1| Galaxy Tab 2 P3100
  3. #3
    I am the night...I am... vickybat's Avatar
    Aug 2009
    Gotham City
    @ op
    If you're plaaning to buy in may/june, then wait for Richland based apu's mainly A10 6800K.
    Haswell would also have been out by then and you'll have a plethora of choices.
    Core i5 750, biostar h55 A+ (X16+X4), 4gb 1333 ddr3, corsair vx450, cm elite 335,Asus EAH 5750 FORMULA , samsung 2033 sw plus, wd green 1tb , wd 1tb my book ,Seagate freeagent ext hdd 1tb , hp dvd writer,Apc 650 va, logitech z313 , Micromax Funbook , Klipsch image S3 (IEM).
  4. #4
    Parallel everything harshilsharma63's Avatar
    Jul 2012
    Jodhpur
    Start a thread a couple of weeks before you plan to buy to make sure you get the latest and the best components available then.
    Intel i3 2100 3.1GHz | 2x2 GB DDR3 RAM 1333 MHz | Intel DH61WW | Seagate Barracuda 500 GB | Corsair CX430v2 | Zebronics Oval | LG 22" HD | Logitech KB mouse combo | Seagate Extension 500 GB portable HDD | APC 600 VA UPS | Philips SHP 2000
    Join TDF IRC channel at
    http://webchat.freenode.net/?channels=krow or use client: server: irc.freenode.net port: 6667 channel: krow
  5. #5
    Super Moderator Skud's Avatar
    Jun 2004
    10 light years away
    All the best for your exams. See you in May/June.
    Gaming Rig:i7 2600K | N620 | P8Z68 Deluxe | 2x4GB RipjawsX DDR3 1600 | Vertex 3 120GB | Logitech G510 | Logitech G400 | Sapphire 6950 1GB | BenQ G2420HD | Corsair HX750 | Lancool K62
    HTPC Rig: C2D E7400 | EP45-DS3R | 2x2GB DDR2 800 | MS Wireless Desktop 2000 | Gigabyte 5770 | Samsung 32" | Seasonic SII 520W | Silverstone LC10
    Audio Gear: Altec Lansing VS2421 | ASUS Vulcan ANC | HiFiMan RE-0
    Storage: 2x250GB | 3x500GB | 3x1TB | 3x2TB
    Android: Galaxy R | Galaxy Y
Tags for this Thread
