Results 1 to 8 of 8
  1. #1
    Dec 2012
    Default Multimonitors!! help!
    So i decided to get a desktop instead of spending 1.9 lakh on an alienware laptop.I finalized on a rig with an i7,gtx 690 or 680 and other components which are good enough to run nvidia surround.The thing is that I don't know what brand or model to buy.I just checked out the monitor list and found that 10k monitors have full hd support with 2ms response time but I also saw similar(very similar) monitors which costed 20k or so,so i wondered if i was missing something.If you guys can recommend a few budget full Hd monitors with 2ms response time or even telling me how to go about selecting a monitor ,that would be great.The size can be anywahere from 21 to 24 inches,I'd prefer a 2ms response time and it should be suited for a multimonitor setup.However,3D is not necessary as that would just increase the prices and it wont fit in my budget.Thanks in advance!
  2. #2
    SIC PARVIS MAGNA anirbandd's Avatar
    Oct 2012
    Kolkata
    Default Re: Multimonitors!! help!
    if you want only hard core gaming then i5 is more than enough. and the HD7950/7970 with new beta drivers are ripping apart nvidia benchmarks. also they are highly OCable. want extra juice? go for CF.
    hope you are not falling for the 'Physx' gimmick from nvidia. incase you have, go thorugh this thread: Info/Discussion : How to configure a Graphics Card dedicated for Phyx, Baseline and Aux
    as for surround, AMD gpus too support them. Eyefinity: AMD Eyefinity Technology
    and incase you haev not bought your rig, consider telling the config. the experts here will help you get a better config if possible.
    the_pwnzerschrek: Core i5-2400||Asus P8H67M-LE||2x2GB Kingston 1333MHz||MSI R7770-2PMD1GD5||Corsair CX430V2||Seagate 1TB||NZXT Gamma||APC RC600 350W||Dell IN2030M||Win7 x64++++PlayStation 3
    Audio: Signature Acoustics C-12 Wooden IEM||SONY MDR-G45
    Canon EOS 1000D||18-55mm non-IS||Desi Tripod||Photography Link: Flickr!!
  3. #3
    Dec 2012
    Yeah man,will do,though I picked up most of the components from the ultra high end rig config in Digit.And no,I don't care about physx.I already have a id range Amd with ati gpu desktop,thought I'd try nvidia's high end gpus for a change...still need help regarding the monitors!
  4. #4
    Dragon...Dragon...Dragon.
    Jan 2013
    Bhubaneswar
    Dell UltraSharp U2211H 54.6cm (21.5) Monitor Details | Dell India
    cost effective with latest ips panel
    GTX 690 is king of hill undisputed so go with it
  5. #5
    I am the night...I am... vickybat's Avatar
    Aug 2009
    Gotham City
    Stick with SLI instead of crossfire. For multimonitor, try to get your hands on two gtx 680's instead of a single 690.
    You should try to get the 4gb variant of gtx 680. The extra vram will be very helpful at those resolutions.
    Core i5 750, biostar h55 A+ (X16+X4), 4gb 1333 ddr3, corsair vx450, cm elite 335,Asus EAH 5750 FORMULA , samsung 2033 sw plus, wd green 1tb , wd 1tb my book ,Seagate freeagent ext hdd 1tb , hp dvd writer,Apc 650 va, logitech z313 , Micromax Funbook , Klipsch image S3 (IEM).
  6. #6
    Dec 2012
    Quote Originally Posted by draco21 View Post
    Thanks man,i don't think that it has a hdmi port and i really want one,care to comment on any of these monitors?
    Grabmore India - Online Shopping of Electronics India : Buy Monitors at our Online Electronics Store. Shop online and Get the Cheapest price.
  7. #7
    Jan 2013
    Bhubaneswar
    http://www.amazon.com/AOC-i2367Fh-23.../dp/B009V8F700
    Very pleasing to look at,2 HDMI support,cost effective,IPS panel,50,000,000:1 dynamic contrast
    Also see this
    http://www.overclock3d.net/reviews/g...d7990_review/9
    As u see 7990 over powers even 690 SLI in some cases (Crysis 2,DIRT3,Mafia 2033,Resident evil 5 etc)
  8. #8
    In The Zone hitman4's Avatar
    Dec 2012
    Dil Waaloon ki Dilli :P
    y u have two threads...?
    Getting ready for BATTLEFIELD..... :P
    Mobile & Tablet: Samsung Galaxy Note, Sony Xperia Tipo Dual, Apple IPad 2, Apple IPod Touch 8Gb, Apple Ipod 16Gb (1st Gen).
    Computers: Macbook White 13inch, Dell 13R,
    Gaming Pc comming Soooonnnee..
Tags for this Thread
