Results 1 to 11 of 11
03-12-2012, 02:55 PM #1
CPU + Motherboard + RAM + PSU + GFX Card in 30k
Ans: Games, May host minecraft server, Photoshop, Basic tasks(music, browsing, office)
2. What is your overall budget? If you can extend a bit for a more balanced configuration, then mention this too.
Ans: 30k. Not going to extend.
3. Planning to overclock?
Ans: Occasional
4. Which Operating System are you planning to use?
Ans: Win 7
5. How much hard drive space is needed?
Ans: N/A
Ans: Already having a 1080p monitor.
Ans: Reusing HDD, Cabinet(Zeb Bijli), Monitor, DVD Drive
8. When are you planning to buy the system?
Ans: ASAP
Ans: Does it matter?
Ans: Hyderabad. Open to online shopping.
Ans: This is for a friend who fried his PC, thanks to Zeb PSU. He prefers AMD, but not quite a problem. He has thought of:
MSI 970A-G46, Corsair CX500W, MSI R7770 PowerEdition OC, Vengeance 1866MHZ 4GB*2.
Should he select 8GB RAM or a better card? 8GB RAM may help when hosting server, but not sure how much will it be effected.The beauty of Indian roads is that one needs to look on both sides while crossing a one way road!
▒▒ ¯TF2 COMIC MAKER!_ ▒▒
Drive sensibly, please!
Educated Illiterates
03-12-2012, 08:06 PM #2
Re: CPU + Motherboard + RAM + PSU + GFX Card in 30k
Occasional overclock???
yah, it matters. we dont want to scrape you off the wall, after you blow yourself up, having inserted the plugs the wrong way.9. Have you ever built a desktop before or will this be done by an assembler?
[/QUOTE]Ans: This is for a friend who fried his PC, thanks to Zeb PSU. He prefers AMD, but not quite a problem. He has thought of:
nice choice. 7770 rules its range atm, so, stick with it, and go for 8 gb ram. what about CPU? which cpu? I suggest trying to get hold of the older phenom stocks (and try and get a discount that way) else, FX series, it is.Mmmphh-mphhhh-mmphh mhh!!!
03-12-2012, 08:45 PM #3
To quote his words: "I will only overclock in winters if I want. In summers, sun comes on a vacation in my room."
Its for my friend so I won't be exploding.yah, it matters. we dont want to scrape you off the wall, after you blow yourself up, having inserted the plugs the wrong way.
He said FX6100 I believe. How is it? Will GTA V and minecraft server (with minecraft client & 3 players from other computers) work smoothly on it?nice choice. 7770 rules its range atm, so, stick with it, and go for 8 gb ram. what about CPU? which cpu? I suggest trying to get hold of the older phenom stocks (and try and get a discount that way) else, FX series, it is.The beauty of Indian roads is that one needs to look on both sides while crossing a one way road!
03-12-2012, 10:04 PM #4
Need Help :Spoiler:
* Looking to purchase Noctua NH-U12P SE2 :(
03-12-2012, 10:16 PM #5
Nipun, have a look at the feedback in different forums about MSI Motherboard you've chosen. It's VRM design is considered as Catastrophic Disaster by the community and in fact couple of months back it was mentioned itself in the Motherboard Product page that the board isn't suitable for any kind of overclocking.
Better go with the Gigabyte GA-970A-DS3 @ 5.6K which offers better quality VRM design. For Processor, consider FX 8120 instead of FX6100.AMD FX 8350|16 GB RipjawX 1873 MHz CL10 @ 1.6V MHz|1+2TB Seagate + 1 TB WD Green 64MB Cache|Sabertooth 990FX|Sapphire HD 7950 VApor-X OC with Boost|GT 240 1 GB GDDR5 PhysX|CM690II Advanced|LG D2342P Cinema 3D Display|TX850 V2|2 CM 1600RPM FAN|MX518|Razer Goliathus|Razer Arctosa|Razer Megalodon 7.1 Headset|CM Hyper 212 Plus|APC1.1KVA| Moto Defy Plus|HCL Me Y2 Tab (rooted)
03-12-2012, 10:17 PM #6
fx 6100 is quite good, but compared to others, its a tiny bit slower.
04-12-2012, 12:47 PM #7Right Off the Assembly Line
- Join Date
- Dec 2012
- Posts
- 2
Hi Cilus
Yeah i am aware of the VRM issue on the MSI board. But i wouldnt be fiddling around with voltages so much so that it would cause an issue and also the FX6100 is rated at 95w max TDP which is quite low compared to 8120 and 8150 (both 125w). So do u think it would still be an issue? Cause the MSI is a better packaged mobo compared to Gigabyte apart from the VRM issue which i think wont affect me. Ohh btw 8120 is out of my range. I would rather go for a better GPU maybe 7850. Can i get a 7850 2gb for under 13k. Found this on flippy but its out of stock damn
Gigabyte AMD GV-R7850OC-2GD 2 GB GDDR5 Graphics Card | Graphics Card | Flipkart.comLast edited by krissh; 04-12-2012 at 03:54 PM.
05-12-2012, 03:10 PM #8
anyways avoid that msi.
u have a sata HDD or pata?
if pata, then u need new one as new mobos dont carry pata port.
and u need ups?
get this -
Component Model Price Processor AMD FX6300 7500 (Predicted) Motherboard Gigabyte GA-970A-UD3 6254 Ram G.Skill F3-12800CL9S-4GBXL 1568 Graphics Card Gigabyte HD 7850 2GB GDDR5 OC 13728 PSU Corsair CX500 V2 3445 Total 30121
if u can, get this in place of that 7850.
GIGABYTE GRAPHIC CARD GTX 660 2GB DDR5 OC
that 7850 price is from mdcomputers.in
psu - primeabgb.com
ram/mobo - flipkart.UPlay - Jas808, Steam ID - HD6950, TF2 Outpost - Link
Athlon II x4 635, CM Hyper 212 Evo, Gigabyte GA-880GM-UD2H, G.SKILL 6GB, Sapphire HD6950 1GB (Unlocked - HD6970), WDC 500GB Green, Corsair GS600, CM Elite 430, DELL ST2220L, X360 Controller, Logitech G400, Razor Goliathus Omega - Speed
HP Pavilion G6 2005AX - Genuine Windows 8 Pro, Samsung Galaxy Y Duos
05-12-2012, 04:40 PM #9Apprentice
- Join Date
- Oct 2012
- Posts
- 81
Ans: Occasional
i5-3570k, Asus P8-Z77 V-Pro, Asus 7870 2GB, G.Skill RipJaws 16GB, ST2410L, Phantom 410. Pics : http://imgur.com/a/rOi6x#0
Galaxy S2 : CM 10 4.1.2
05-12-2012, 04:51 PM #10
^ most overused smiley.... ever.
06-12-2012, 06:43 PM #11Right Off the Assembly Line
- Join Date
- Dec 2012
- Posts
- 2
Thank you guys for all your suggestions. I have purchased all the components. Eagerly waiting for them to arrive
Below are the specs along with the prices. Also i have decided not to OC
MOBO - MSI 970A-G46 Price : 5460 (flipkart.com)
CPU - AMD FX6100 Price : 7250 (smcinternational.in)
RAM - G.Skill Sniper DDR3 8 GB (2 x 4 GB) Price : 3100 (flipkart.com)
GPU - R7850 Power Edition 2GD5/OC Price : 14300 (smcinternational.in)
PSU - Corsair CX500 V2 Price : 3445 (primeabgb.com)
LinkBack URL
About LinkBacks
