Results 1 to 2 of 2
Thread: Razer Lycosa/Razer DeathAdder
15-09-2012, 05:25 PM #1Broken In
- Join Date
- Mar 2012
- Location
- Chennai, Tamil Nadu, India
- Posts
- 107
Hey. I'd like to know if any user here has got the arctosa and the deathadder? Are they worth the buck? Or do I go in for cyborg rat 3? Someone help me please! Are the macros and the multimedia buttons good in the keyboard? Any issues?
And how much do they cost?
16-09-2012, 12:58 AM #2Point Blanc
- Join Date
- Jan 2008
- Posts
- 1,890
Re: Razer Lycosa/Razer DeathAdder
I am using G300 logitech, after using it I certainly can say they truly are worth every penny I spent on them. death adder is really good
u can change arctosa to logitech G105
u should ask it urself, what u can hold good in your hands. i havent seen rat 3 it seems to be little bigger. moreover I prefer symmetric design. so u should ask yourself about what will be fine in your hands. deat adder is safer choice
http://www.flipkart.com/browse/gamin...e-18c0307e0c69
you can do the price check in flipkart
LinkBack URL
About LinkBacks
