Results 1 to 3 of 3
Thread: GRUB on starts
30-08-2012, 08:16 PM #1Right Off the Assembly Line
- Join Date
- Mar 2012
- Posts
- 6
GRUB on starts
I had windows 7 on my laptop.
I install ubuntu side by side with windows.
then i wnated to uninstall ubuntu.
i delete all the partion where ubuntu was there.
but when i start after removing ubuntu is show no such partition and GRUP command crompt.
Someone told me to use fixmbr or fixboot.
But both the command are not available in windows 7 instillation CD.
Now from the ubuntu instillation CD its showing u have several OSs.
i dont want to remove my windows .
30-08-2012, 09:25 PM #2
Re: GRUB on starts
Boot with win7 DVD -> Repair -> Fix start up.
30-08-2012, 10:40 PM #3In The Zone
- Join Date
- Aug 2012
- Location
- Delhi
- Posts
- 198
Re: GRUB on starts
Try booting into the Windows 7 DVD Repair console and run Startup Repair repeatedly until it starts up.
If this does not start it then try marking Windows 7 active first by booting into the Windows 7 DVD Repair Console>Recovery Tools to open a Command Line, then type:
DISKPART
LIST DISK
SELECT DISK # (for Windows 7 disk)
LIST PARTITION
select partition # (for Windows 7 partition)
active
exit
or you can use easyBCD
Restore the Windows bootloader to MBR after dual-booting with Linux
LinkBack URL
About LinkBacks
