Page 1 of 3 1 2 3 LastLast
Results 1 to 30 of 82
  1. #1
    Jul 2011
    Default Suggest me a Gaming system
    Ans:1.First purpose is gaming games like Witchcraft 2, Assassin creed 3, Crysis 3 etc. 2. Android and Linux kernel and ROM Compilation.
    2. What is your overall budget? If you can extend a bit for a more balanced configuration, then mention this too.
    Ans:30-32K
    3. Planning to overclock?
    Ans:Yes
    4. Which Operating System are you planning to use?
    Ans: Windows 7 64bit and ubuntu 12.04 64bit those two will be in different partitions and some other distros in VM.
    5. How much hard drive space is needed?
    Ans:Now no hd is required will upgrade later. having 720gb
    Ans:No , already having benq 2210 eco full hd monitor
    Ans:Monitor, Speaker (f & D 520) Keyboard & mouse (logitech bundle, upgrade it later), Hard Disk
    8. When are you planning to buy the system?
    Ans: In September Mid
    Ans: I will build it.
    Ans:Kannur, kerala. I don't think i will we geting all things in Kannur so will go to Calicut. If somebody is there from Calicut can help me.
    I am also skeptical about purchasing online because Flipkart and others will deliver it 2 hours away from my residence( Banking Branches Sucks)
    so tell me some reasonable options.
    Ans: I am thinking to Purchase an ATI 7850 in october so also suggest a good one.(Price not included in budget)
    As I am having a transfereble job so suggest a good and strong cabinet so that it can handle
    and keep safe my pc internal components safe on the go(My old one is almost crushed while coming from Bokaro Steel City to Kannur)
    I am also having a wifi pci card and an internal TV tuner So suggest me motherboard with sufficient PCI slots.
    And tell me a trust or NGO where I Can Donate My old Working PC
    I have sorted these components;-
    intel i5 2500k
    ASUS P8Z77- M motherboard
    others i have not checked.
  2. #2
    Aug 2012
    Delhi
    Default Re: Suggest me a Gaming system
    this is my suggestion..
    cpu: i5-2500K - 13K
    mobo: msi z68A-G45 - 8K
    ram: corsair value ram 4GB - 1.3K
    gfx: hd7770 - 8k
    psu: corsair CX500 - 3k
    total : - 33.3K
    still few things i want to mention
    you cabinet should have good air flow for overclocking and intel stock heatsink is not good when overclocking so think of upgrading it too.
    cheers!
  3. #3
    Jul 2011
    please exclude GFX in this configuration as i have already mentioned i will purchase
    hd7850 next month.
  4. #4
    Right Off the Assembly Line rahulonmars's Avatar
    Aug 2012
    Noida
    Lightbulb Re: Suggest me a Gaming system
    Quote Originally Posted by nikku_hot123 View Post
    hd7850 next month.
    You can exclude the GFX card and can upgrade to i7.
    \m/
  5. #5
    damnbadman666 damngoodman999's Avatar
    Nov 2008
    Coimbatore
    Intel Core i5 3570KK - 15K
    mobo: ASRock Z77 Pro4 - 10K
    Corsair CMPSU-650TX -6.5K
    its 1K or 2K high , but its best for gaming
    DEATH IS OUR BIRTH RIGHT - SO Y FEAR DEATH ???
  6. #6
    Jul 2011
    Please include cabinet as per my requirement mentioned in first post and a cpu cooler.
    MY RIG : Intel i5 3570K | Asrock Z77 Pro 4 | Corsair 400R | Corsair HX650 | Sapphire HD 7870 GHZ |
    Cooler Master 212 EVo | Gskill Sniper 4GbX2 | Logitech G400 | Benq 2220 Eco
  7. #7
    Nov 2008
    Coimbatore
    Cooler Master Hyper 212 EVO
    cabinet - Antec DF-35-AP or CM 690
  8. #8
    Aug 2012
    Delhi
    hd7850 next month.
    sorry some how i missed that...
    what about this one...
    i5-3570K - 15k / i5 - 2500k - 13K
    mobo: asrock z77 extreme 4 - 10.4K / GIGABYTE GA Z68AP D3 - 9.7
    ram: corsair value ram 4gb - 1.5K
    cooler: cm hyper 212 evo - 2.2K
    Corsair 650TXv2 - 6.5K
    caby: Nzxt source 210 - 3.1k
    total = 38.7 / 36K
  9. #9
    Feb 2012
    New Delhi
    or
    i5 3570k-14.6k
    gigabyte ga -z77p-d3 -8.3k
    corsair hx 650-6k
    corsair carbide 400r-4.5k
    corsair xms3 4x2gb-2.6k
    deepcool iceblade pro-3k
    total-34.6k
    also @ akky89 i dont think asrock mobos must be recommended
    they usually have capacitor problems+ their rma service in bharat desh ( ) is crap
    POCKET MONEY RIG-Intel Core i5 2500|Intel DH61WW|2*2gb DDR3 1333mhz |SAPPHIRE Hd 6770| Lg E2060 @1080p|Iball Piano 18 CASE| Corsair CX 500 |WD CAVIAR BLUE 500GB|ASUS 24X DVD DRIVE|SEAGATE 1TB EXPANSION DRIVE|SKULLCANDY HESH RASTA |X360 WIRELESS CONTROLLER |IBALL PREMIUM COMBO|LG p500 ] ICySnap v1.6 LG UI 3.0 ICS
    straight from tom's- http://www.tomshardware.com/forum/profile-989398.htm
  10. #10
    Aug 2012
    Delhi
    Quote Originally Posted by panwala95 View Post
    i'll remember that...
    just the thing is they give pretty features for the price they ask... and are generally have good price to feature ratio...
  11. #11
    Why So Serious ??? mandarpalshikar's Avatar
    Aug 2012
    Pune
    ASRock is good if your budget is somewhat restricted not reaching to the level of Asus and if you are not thinking of overclocking. Like ASRock Extreme6 is a good bargain at 12k price point if you want a feature reach mobo and are not planning to overclock.
    I have an extreme6 with me which I've RMAd last week (since one of my friends disturbed the pins in CPU socket and now memory wont get detected) to Digicare here in Pune. They have said that the board is now in their Mumbai office this week... they'll try to change the socket and see if that solves the problem. So far no complaints from my side about their RMA process.
    Config : i5 3570K | Corsair H80 | Maximus V Formula | 2x8GB TridentX 2400 CL10 | Corsair 3 60GB | Barracuda 1TB | Razer DeathAdder 3.5G | Logitech G110 | Asus DC II HD7950 + Sapphire HD7950 Dual-X CrossFireX | AOC e2352Phz | Corsair AX850 | Raven RV03
    Audio : JBL Creature III 2.1 | Razer Megalodon 7.1
    Others : HTC Once X | Galaxy Tab P1000 | HP Pavilion 14-b104au Sleekbook | XBOX 360
  12. #12
    Jul 2011
    guys i am confused between i5 2500k and i5 3570k can you please help me out
    choosing best one as this system is going to run for next 5-6 years.
    i was looking for asus p8 z77m or m pro i am not sure about gigabyte.
    what are the pros and cons between them.
  13. #13
    Feb 2012
    New Delhi
    gigabyte mobos are great but if you are one of the unfortunate ones who get a broken mobo then you are in for a ride......
    also you should go for the i5 3570k cause it has a higher ipc than the i5 2500k ,supports pcie3 and 1600mhz ram natively
  14. #14
    Aug 2012
    Pune
    Boss... very very debatable doubt you have... it can spark world wars right now... he he he. Price difference would be around 2k max. Basically its same boubt we'll have when deciding between BMW 3 Series 2010 model and BMW 3 Series 2012 model... both are absolutely fantastic. You need to think which one you want new gen or old gen.
    Anyways have a look at this thread - Badass Gaming PC for 80K
    Here are some coclusions from some reviews.
    Despite the higher-than-expected cost and higher operating temperatures, the Core i5-3570K is a worthy successor to the Core i5-2500K. It's noticeably faster, more power efficient, has a more powerful IGP and combined with a Z77 chipset motherboard, will offer far more features too.
    Bit-tech.com review
    The Intel Core i5-3570K processor represents a logical replacement for the popular Core i5-2500K that's found a home in many an enthusiast and system integrator system.
    Run the Core i5-3570K at stock speeds/voltages and it provides the best bang-for-buck in the £150 space.
    hexus.net review
    The new Intel Core i5 3570K has everything that made its Core i5 2500K such a winning CPU. Per core performance is the best you can buy.
    A great chip, but Core i5 2550K and i5 2500K owners have nothing to worry about.
    techradar.com review
    Unfortunately, the unusually high temperatures found during overclocking beyond 1.3V is most likely partly caused by this new process. This doesn't pose too much of a concern as a decent CPU air cooler can still handle overclocks within the 1.2-1.3V range with decent results and those who wish to push Ivy Bridge CPUs much further will be experienced extreme overclockers with LN2 cooling. Average performance tuners also don't really need to adjust secondary voltages as much anymore, compared to previous generation CPUs, since the memory controller can handle higher clocks.
    hightechlegion review
    Bottom line is....
    1. If you have a 2500K already dont see 3570K as competition but as a worthy succesor and hold on to 2500K till next gen CPUs come.
    2. If you are building a new rig go for 3570K as it is the successor to 2500K.
    3. 3570K consumes less power at idle
    4. Temperature factors in only in case of overclocking with Higer voltages.
    5. If software support gets available in next 6 months it would be really awsome to see a video of say BD quality being ripped for your phone in just a matter of 10 minutes with use of Quicksync.
  15. #15
    Jul 2011
    so i am finalizing i5 3570k for processor. And i cannot go frequently for RMA and Service center due
    to geographical barriers so i want a good mobo with peace of mind.
  16. #16
    Alpha Geek sharang.d's Avatar
    May 2012
    Pune
    asus p8z77m-pro, p8z77v-pro, p8z77v
    Intel Core i5-2500k ASUS P8Z77-V PRO CM Hyper 212 EVO G.Skill 1600Mhz 4G X 2 Sapphire HD 7870 Seasonic S12II 620W Corsair Carbide 400R Microsoft Sidewinder X6 Logitech G400 LG E2381VR Razer Goliathus Control Edition (Small)
    Additional Cabinet Fans CM Blue LED silent fan 140mm Silverstone AP121 120mm
  17. #17
    Aug 2012
    Pune
    or even Maximus V Gene... if you are building a gaming rig
  18. #18
    Aug 2012
    Delhi
    well you can go with any of the above suggested mobo.
    and don't worry mobo don't broke that easily if you are not
    doing something funny with it
  19. #19
    Feb 2012
    New Delhi
  20. #20
    Jul 2011
    ^^ price will go out of my budget. so i think i should go with
    micro ATX form factor whithin 10-11k
  21. #21
    Aug 2012
    Delhi
    you told me not to recommend ASRock boards and you recommended them....
  22. #22
    May 2012
    Pune
    Check p8z77-m pro price with local vendors then..
  23. #23
    Aug 2012
    Delhi
    check for asus p8z77-m it can easily be find around 10K
    here's an online link...
    ASUS P8Z77-M Motherboard | Motherboard | Flipkart.com
    cheers!
  24. #24
    Jul 2011
    This is my wishlist from flipkart it is going beyond 42k
    i will check local market but i don't think there will be a difference of 10k.
    Please bring it down to max 34k
  25. #25
    Feb 2012
    New Delhi
    Quote Originally Posted by akky89 View Post
    features bro features......
    i5 3570k-14.6k
    corsair hx 650-6k
    total-34.6k
  26. #26
    Jul 2011
    again i am confused should i go for gigabyte full atx mobo
    or asus p8z77 m. which is better and vfm???
  27. #27
    Feb 2012
    New Delhi
    gigabyte one is cheaper and thier feature set is similar so go for the gigabyte
  28. #28
    Jul 2011
    ^^i am not sure about gigabyte OC capabilities, performance and after sale service as there is a
    thread regarding gigabyte RMA issue.
  29. #29
    Feb 2012
    New Delhi
    then go for asus
  30. #30
    Nov 2008
    Coimbatore
    @ nikku_hot123
    Let me clear it for you , I've already suggested the config , Reg proccy : 3rd gen i5 proccy have much OCing capabilities since 22nm still runs hot ! but still in future u can go for water cooler then OC .Always choose latest one . Only 1.7K more than 2500K
    As for Motherboard : Asrock has very good build quality , Asus & Gigabyte you may face RMA issues since ASUS belongs to Rashi & gigabyte i dono since now many r facing issues with RMA , either you can go MSI if u have option in the mobo .
    Cabinet : corsair carbide 400R gives u better look & Antec DF-35-AP is also same with looks as well as cooling u can put lot of fans
