Results 1 to 23 of 23
Thread: want to upgrade pc in 30k
28-08-2012, 09:25 PM #1Right Off the Assembly Line
- Join Date
- Aug 2012
- Location
- Bangalore
- Posts
- 17
my configuration is:
motherboard: asus p5k-vm
processor: core 2 duo 4400
ram : kingston 800mhz 2gb
Ans:cod(all), battlefield 3, crysis 2, dues ex human revolution
2. What is your overall budget? If you can extend a bit for a more balanced configuration, then mention this too.
Ans:30k
3. Planning to overclock?
Ans:no(don't know how to)
4. Which Operating System are you planning to use?
Ans: x p
5. How much hard drive space is needed?
Ans:no need
Ans:42" full LED full HD
Ans: only want to upgrade cpu nothing else
8. When are you planning to buy the system?
Ans:JANUARY
Ans:any
Ans:Bangalore (can buy localy or on internet)
Ans: noLast edited by sidhelper; 29-08-2012 at 06:01 PM. Reason: change in que
28-08-2012, 09:37 PM #2
Re: want to upgrade pc in 30k
First go through this:-
Asking for new PC help? ANSWER THESE QUESTIONS FIRST
And answer.Gaming Rig:i7 2600K | N620 | P8Z68 Deluxe | 2x4GB RipjawsX DDR3 1600 | Vertex 3 120GB | Logitech G510 | Logitech G400 | Sapphire 6950 1GB | BenQ G2420HD | Corsair HX750 | Lancool K62
HTPC Rig: C2D E7400 | EP45-DS3R | 2x2GB DDR2 800 | MS Wireless Desktop 2000 | Gigabyte 5770 | Samsung 32" | Seasonic SII 520W | Silverstone LC10
Audio Gear: Altec Lansing VS2421 | ASUS Vulcan ANC | HiFiMan RE-0
Storage: 2x250GB | 3x500GB | 3x1TB | 3x2TB
Android: Galaxy R | Galaxy Y
28-08-2012, 09:52 PM #3In The Zone
- Join Date
- Aug 2012
- Location
- Delhi
- Posts
- 198
either fill this..
or give as much as info you can related to the build you want to create and its usage... so that we can help you
the way it's intended...
29-08-2012, 09:10 PM #4Right Off the Assembly Line
- Join Date
- Aug 2012
- Location
- Bangalore
- Posts
- 17
Ans:30k
Ans: x p
Ans:no need
Ans:JANUARY
Ans:any
Ans: no
29-08-2012, 11:31 PM #5In The Zone
- Join Date
- Aug 2012
- Location
- Delhi
- Posts
- 198
first of all if you are going to buy in jan next year then wait don't plan now cause tech changes pretty quick simillarly their prices...
so what ever build you are going to think now will most likely be not at the same point then.
secondly ... if i'm not wrong then this 42" full Led full hd monitor is - 24" LED full hd;
and why are you still using win XP...
30-08-2012, 07:01 PM #6Right Off the Assembly Line
- Join Date
- Aug 2012
- Location
- Bangalore
- Posts
- 17
30-08-2012, 10:59 PM #7In The Zone
- Join Date
- Aug 2012
- Location
- Delhi
- Posts
- 198
31-08-2012, 07:52 AM #8Right Off the Assembly Line
- Join Date
- Aug 2012
- Location
- Bangalore
- Posts
- 17
31-08-2012, 09:38 AM #9
What are the parts you need? My guess is CPU, mobo, RAM & GPU. Do you need keyboard/mouse too or planning to reuse your old parts?
31-08-2012, 10:44 AM #10In The Zone
- Join Date
- Aug 2012
- Location
- Delhi
- Posts
- 198
if my understanding is not wrong you only want to upgrade whatever in you cabinet..
so here you go...
cpu: i3-2120 @3.3GHz - 6.9K
mobo: GIGABYTE GA-H61M-DS2 - 3K
psu: CORSAIR SMPS-450 VS - 2.1K
RAM: Corsair DDR3 value 4 GB - 1.2K
hdd: wd carviar blue 500gb - 3.8K
gfx: hd 6870 - 11.6K
caby: cooler master elite 343 - 1.9K
total 30.5K
cheers!
31-08-2012, 11:04 AM #11
He doesn't need a HDD. Read again.
31-08-2012, 11:07 AM #12Right Off the Assembly Line
- Join Date
- Aug 2012
- Location
- Bangalore
- Posts
- 17
31-08-2012, 11:09 AM #13
Replace the graphics card with a 7850 in the above config. Rest are fine.
31-08-2012, 11:30 AM #14In The Zone
- Join Date
- Aug 2012
- Location
- Delhi
- Posts
- 198
31-08-2012, 12:52 PM #15
He doesn't need a HDD, that plus the budget of 6870, can easily bought a 7850.
31-08-2012, 02:42 PM #16In The Zone
- Join Date
- Aug 2012
- Location
- Delhi
- Posts
- 198
31-08-2012, 03:38 PM #17Right Off the Assembly Line
- Join Date
- Aug 2012
- Location
- Bangalore
- Posts
- 17
PLUS I dont need a cabby sorry forgot to mention
31-08-2012, 04:28 PM #18
Your processor is old and ram is slow, it will bottleneck your gpu.
If you are going to keep your
a) HDD
b) cabinet
c) keyboard and mouse
Intel 3.3 GHz FCLGA1155 Core i3 2120 Processor @ 7.3k
ASRock H61M-HVGS Motherboard @ 2.8k
G.Skill RipjawsX DDR3 4 GB PC RAM (F3-10666CL9S-4GBXL) @ 1.6k
Asus AMD HD 7850 2 GB GDDR5 Graphics Card @ 18.8k
Corsair VS450 450 Watts PSU @ 2.5k
total = 32k approx ( you should manage about 30.5k in the local market )Steam : noasarcangel
Steelseries : Winning Is Everything.
31-08-2012, 06:24 PM #19
A OCed 7850 with custom cooler from HIS, Sapphire, GBT, MSI can be purchased at around 16k. For mobo, I would suggest sticking with the Gigabyte one.
31-08-2012, 06:32 PM #20In The Zone
- Join Date
- Aug 2012
- Location
- Delhi
- Posts
- 198
12-09-2012, 03:47 PM #21Right Off the Assembly Line
- Join Date
- Aug 2012
- Location
- Bangalore
- Posts
- 17
i have bought i3 2120
ram 4 gb 1600mhz
motherboard z77 for future proofing
i need a new gpu i was thinking about hd 7850 tell me which make should i buy asus etcand from india or us??
12-09-2012, 10:40 PM #22
Where do you stay/live?
14-09-2012, 06:31 PM #23Right Off the Assembly Line
- Join Date
- Aug 2012
- Location
- Bangalore
- Posts
- 17
LinkBack URL
About LinkBacks
