Results 1 to 3 of 3
  1. #1
    Playing The Game mrinmoy's Avatar
    Feb 2012
    Kolkata, India
    Default Gaming pc at 25k
    I need a gaming pc configuration for my friend. Please suggest any intel or amd based rig. Thanks in advance.
    Ans:Games like fifa 12, nfs run, cod etc
    2. What is your overall budget? If you can extend a bit for a more balanced configuration, then mention this too.
    Ans:25k
    3. Planning to overclock?
    Ans:no
    4. Which Operating System are you planning to use?
    Ans:Windows 7
    5. How much hard drive space is needed?
    Ans:250-500gb
    Ans:yes, 17"-20", greater or equals to 1280x720
    Ans:UPS,keyboard mouse.
    8. When are you planning to buy the system?
    Ans:Within 2-3weeks
    Ans:Myself
    Ans: kolkata, yes I am buying locally.
    Ans: Asus+AMD combo preferred.
    "Anyone who is not shocked by quantum theory has not understood it."
    Niels Bohr
  2. #2
    laborare est orare Cilus's Avatar
    Mar 2009
    Kolkata
    Default Re: Gaming pc at 25k
    Intel Pentium G630 @ 3.6K
    Gigabyte GA-H61-D2H @ 3.1K
    Corsair Value 4 GB X 1 1333 MHz DDR3 @ 1.2K
    WD Caviar Blue 500 GB SATA II @ 4K
    Corsair CX 430V2 @ 2.7K
    17" AOC/BenQ LED @ 4K
    Sapphire HD 6670 1 GB GDDR5 5.2K
    Normal Cabinet w/o SMPS @ 0.8K
    AMD FX 8350|16 GB RipjawX 1873 MHz CL10 @ 1.6V MHz|1+2TB Seagate + 1 TB WD Green 64MB Cache|Sabertooth 990FX|Sapphire HD 7950 VApor-X OC with Boost|GT 240 1 GB GDDR5 PhysX|CM690II Advanced|LG D2342P Cinema 3D Display|TX850 V2|2 CM 1600RPM FAN|MX518|Razer Goliathus|Razer Arctosa|Razer Megalodon 7.1 Headset|CM Hyper 212 Plus|APC1.1KVA| Moto Defy Plus|HCL Me Y2 Tab (rooted)
  3. #3
    Point Blanc
    Jan 2008
    make it 18.5 inch monitor, you can buy Zebby cabinet and PSU though zebby PSU are not the best rated but still are decent performers. no no to iball (well I do not like iBall personal prejudice n bad experience)
    or u can get
    Cooler Master eXtreme Power Plus 350W - 1.6-17K as well
    and maybe cilus can suggest AMD config as well
