Results 1 to 4 of 4
  1. #1
    Dec 2005
    bangalore
    Question 2 PC configs for around 50-60k and 70-80k
    Hi,
    I need 2 PC configs for around 50-60k and 70-80k.
    First (50-60K) requirements:
    1. CPU - for gaming, INTEL
    2. MOBO - Suggest a good z77 one with is futureproof like maybe asus ASUS P8Z77-V
    3. FAST RAM, which budget permits.
    4. GPU - suggest
    5. HDD - >= 1TB
    6. SSD - only if budget allows, not a primary need.
    7.CABINET- GOOD GAMING ONE, without PSU
    8. PSU - based on above requirements and keeping in mind for future 2nd GPU (bronze+, if possible).
    9. LCD - Suggest
    SECOND (70-80K) requirements:
    1. CPU - 3770K
    2. MOBO - ASUS P8Z77-V deluxe is what i have chosen, suggest if other is better option
    4. GPU - i want gt 670, but if budget exceeds then maybe i'll go for 660ti
    5. HDD - >= 1TB
    9. LCD - Suggest
    Ans:GAMING FOR BOTH.
    2. What is your overall budget? If you can extend a bit for a more balanced configuration, then mention this too.
    Ans: Mentioned Above
    3. Planning to overclock?
    Ans: MAYBE / NOT SURE
    4. Which Operating System are you planning to use?
    Ans: WINDOWS 7/8
    5. How much hard drive space is needed?
    Ans: 1/2 TB. Though more the merrier
    Ans: HD capable IPS MONITOR, if possible
    Ans: I need all basic mentioned above
    8. When are you planning to buy the system?
    Ans: in 1-2 months
    Ans: can do myself
    Ans: Bangalore
    Ans: Please help me get best for money!
    Thanks in advance for suggestions
  2. #2
    defeating my fears..... the_conqueror's Avatar
    Mar 2012
    Kanpur
    Default Re: 2 PC configs for around 50-60k and 70-80k
    The Dark Knight :
    Core i5 2500, Intel DH67CL, WD 1 TB SATA III, Corsair Vengeance 2x4 GB, Sapphire HD 7850, Carbide 400R, Corsair GS600
  3. #3
    Wise Old Owl Myth's Avatar
    Jun 2012
    Bhubaneswar / Kolkata
    Might be easier to create two separate threads for the budgets mentioned. Easier to follow and helpful to those who want something in a particular budget range.
    Intel i7 2600k, Asus P8Z77-M Pro, Sapphire HD 7950 VaporX with Boost | Palit 9600GT, Corsair TX650v2, CM Hyper 212 Evo(push-pull), CM Elite 430, Altec Lansing ATP3 2.1, Samsung Syncmaster 2033, Corsair 2x2GB, Seagate 1TB + WD 1TB Black + Maxtor 300GB, Win7 Ultimatex64, CPU-Z , GPU-Z
    Need Help :
    * Looking to purchase Noctua NH-U12P SE2 :(
  4. #4
    Dec 2005
    bangalore
    OK, done
Tags for this Thread
