Results 1 to 2 of 2
21-08-2012, 03:28 PM #1Right Off the Assembly Line
- Join Date
- Aug 2012
- Posts
- 1
Gaming PC - Budget 35-45k, Please suggest (without monitor & graphic card)
1. What is the purpose of the computer? (Note: If you are planning to say multimedia, you will have to be more specific as all types of systems are capable of doing that)
A:Gaming - BF3, GTA4, 5 in future etc, Adobe CS5, web designing, graphic designing
2. Are you open to alternate ideas/products giving similar better performance but offering more VFM/ sellers? If not- why?
A: Yes
3. What is your MAX budget?
A: 40k
4. Planning to overclock?
A:not now but might be in future
A: win7 or 8
A: 1TB or more
7. What resolution will the screen run at & whats the size of the screen you want? If you already want have one and want to use it, mention its resolution and size.
A: Do not want to buy any moniter
A: 5
A: yes
A: this weekend
A: yes
A: Yes its monitor, graphic card, keyboard-mouse & dvd writer
A: Delhi/nehru place
A: Please tell me the best of best config.
Thanks in advance
22-08-2012, 05:38 PM #2
Re: Gaming PC - Budget 35-45k, Please suggest (without monitor & graphic card)
Do you already have a monitor ?? If yes, then post the model & make.
Same way, Do you already have the Graphics Card ?? If yes, post the model & make.
If not, then mention which Graphics card you wanted to buy in future. Mainly this will be helpful to decide the Power Supply Unit.
For the rest, here goes your Config.
Component Product Price Processor Intel i5 2500k 12000 Motherboard Asus P8Z77-V LX 11000 RAM Gskill RipjawsX 8GB (4GBx2) 1600MHz CL9 3000 HDD Seagate Baracuda 1TB 7200 64MB cache 5400 PSU Corsair CMPSU-650TXV2 5800 Cabinet NZXT Source Elite 210 2400 Keyboard & Mice Logitech MM Combo 700 UPS APC 700va 2400
Total : 43k2600k|Maximus IV Ex-Z|Venomous X RT CM R4's Push Pull|RipjawX 16GB|Sapphire HD7970 CF [1250MHz]|OCZ Vertex 3 120GB|WD Black Raid 0|AX850w|Asus Xonar DX|Dell U2412M x 3 Eyefinity|HAF 932 Advanced|Sentry II| Logitech G27, G15, Attack II, C310 HD|Razer DeathAdder, Megalodon|Steelseries Ikari Optical|
My Game Collection & Sapphire HD 7970 Unboxing
LinkBack URL
About LinkBacks
