Results 1 to 30 of 38
Thread: Gaming Rig for 65k
21-08-2012, 11:02 AM #1
Gaming Rig for 65k
Ans:Apps- MS Office,PS ;Games- GTA IV, BF3, Crysis, ETC.
2. What is your overall budget? If you can extend a bit for a more balanced configuration, then mention this too.
Ans:63k..Max 65k
3. Planning to overclock?
Ans:Yup .when I feel system is weak
4. Which Operating System are you planning to use?
Ans:Windows 7 UL 64 bit and Windows 8
5. How much hard drive space is needed?
Ans:500 GB will do if budget is overshot!
Ans:Yes, But if budget overshot ..will use my TV as Monitor
Ans:I want to buy everything
8. When are you planning to buy the system?
Ans:1 MOnth
Ans:I will try it out
Ans:I may get some components from either Delhi or Jaipur...if prices seems good then Flipkart too
Ans:I prefer I5 2500k n good ASUS MoBo.and want atleast 7850 OC'ed in my Rig
21-08-2012, 12:05 PM #2
Re: Gaming Rig for 65k
do you have a CRT TV or LCD / LED TV ?? If yes, then is it a HD Ready or Full HD ?? Provide the Model details of your TV.
Here goes your Config.
Component Product Price Processor Intel i5 2500k 12000 Motherboard ASRock Z77 Extreme4 10000 RAM Gskill RipjawsX 8GB (4GBx2) 1600MHz CL9 3000 GPU Sapphire HD7850 Dual Fan Active 16000 HDD Seagate Baracuda 1TB 7200 64MB cache 5400 Optical Drive Asus DRW-24B5ST 1100 PSU Corsair CMPSU-650TXV2 5800 Cabinet NZXT Source Elite 210 2400 Keyboard Logitech Media K200 400 Mice Logitech G400 1800 UPS APC 700va 2400
Total : 60k
The Stock intel cooler bundled along with the intel i5 2500k processor is just waste. Get an after market cooler like Cooler Master Hyper 212 @ 2.1k.
Note : Monitor is not included in the above config.2600k|Maximus IV Ex-Z|Venomous X RT CM R4's Push Pull|RipjawX 16GB|Sapphire HD7970 CF [1250MHz]|OCZ Vertex 3 120GB|WD Black Raid 0|AX850w|Asus Xonar DX|Dell U2412M x 3 Eyefinity|HAF 932 Advanced|Sentry II| Logitech G27, G15, Attack II, C310 HD|Razer DeathAdder, Megalodon|Steelseries Ikari Optical|
My Game Collection & Sapphire HD 7970 Unboxing
21-08-2012, 12:38 PM #3
If you want Asus mobo, pick one of the following.
ASUS P8Z77-M
ASUS P8Z77-V LX
ASUS P8Z77-M PRO
Heatsink suggested by d3p: Cooler Master Hyper 212 EVO
The NZXT Source Elite 210 comes with 2 fans, a 120mm(rear) and a 140mm(top).
Add a 120mm front intake : Cooler Master 90 CFM Blue LEDNeed Help :Spoiler:
* Looking to purchase Noctua NH-U12P SE2 :(
21-08-2012, 12:51 PM #4
@D3P :- Will asrock good for OC'ing...Many users faced issues w/ that!
and Cabinet !!!--NZXT Gamma!
BBTW @MYTH :- I will get aftermarket Heatsink. i.e Cooler Master Hyper 212 EVO Cooler @ 2.2k
Can u Guyz Adjust Monitor within 65k?? I Can Compromise in Keyboard,Mouse,PSU
21-08-2012, 02:27 PM #5
switch mobo with P8Z77 M pro..and yer all set...
2500K|3570K|FX-8150|FX-8350|965BE|E7500
MVF|P8Z77-V Deluxe|P8Z68 Deluxe|CHV|880GM-USB3|M4A785T-M|G31M-ES2L
HD7850|GTX660Ti|HD6870|HD6670|HD5450|9400GT
HyperX Blu|HyperX Predator|RipjawsX|Value Select|CGM2X2|
21-08-2012, 02:57 PM #6
Dont compromise with the psu. You put everything in the cabinet at risk.
650w is on the safe side. The Corsair Builder Series CX600 saves you money and might just work unless I am missing something in your config requirements.
Give some details about your monitor requirements.Need Help :Spoiler:
21-08-2012, 03:17 PM #7
TX series is better than the builder series....
21-08-2012, 03:24 PM #8
I understand tx is better. (AX > HX > TX > GS > CX)
I suggested the cheaper cx600 because OP wanted to purchase a monitor by compromising on the psu.
Knowing if cx600 can work with the current setup would have been more helpful.Need Help :Spoiler:
21-08-2012, 03:26 PM #9
better=suggested....CX has lower efficiency than the TX...and i think a basic 20 incher can be included in 65K...
http://www.theitdepot.com/details-Ac...9_C7P6056.html
Cx600 would hurt him on the long run....Last edited by sumonpathak; 21-08-2012 at 03:35 PM.
21-08-2012, 04:52 PM #10
What about this?? Will it fix in 65k?
21-08-2012, 05:07 PM #11
With few changes...
Component Product Price Processor Intel i5 2500k 12000 Motherboard ASRock Z77 Extreme4 10000 RAM Gskill RipjawsX 4GB (4GBx2) 1600MHz CL9 1600 GPU Sapphire HD7850 Dual Fan Active 16000 HDD Seagate Baracuda 500GB 3800 Optical Drive Asus DRW-24B5ST 1100 PSU Corsair CMPSU-650TXV2 5800 Monitor Benq G2222HDL LED monitor 7500 Cabinet NZXT Source Elite 210 2400 Keyboard Logitech Media K200 400 Mice Logitech G400 1800 UPS APC 700va 2400
Total : 64.8k
Changes : 500GB + only 4GB instead of 8GB. You can upgrade to 8GB whenever you have enough dough.
Its better to get a ATX board with enough PCIe Slots rather than getting an uATX board & cry forever. Specially when they are priced in the same range & also with future upgrade-ability.
Secondly, if gaming is the only concern then also give a second thought about getting an i3 2nd Gen [ignoring OC-capability] or AMD Phenom II 960T, instead of Intel i5 2500k.
AMD Quad Core + HD 7850 will save enough to get you a 24inch monitor with the same budget range.Last edited by d3p; 21-08-2012 at 05:18 PM.
21-08-2012, 05:19 PM #12
^^ Do you really think that getting a ATX motherboard does have a difference when user is using only one graphics card and (may be) a sound card?
Suggesting OP to avoid Asrock z77 extreme4 because it have problems although many people rate it 5 out of 5.Inactive in TDF.
21-08-2012, 05:21 PM #13
21-08-2012, 05:37 PM #14
Not the extreme 4 again....guys do u really read any user feedback's? it has issues with ram slots....sometimes the cpu socket is f***ed up..do you really think its worth it? time to look elsewhere guys...
21-08-2012, 05:40 PM #15
21-08-2012, 05:46 PM #16
@d3p
i5 2500k is nowhere lower then 13k dude.. please check again.. I am a Pune based dealer thats why correcting youHavok Rig : Core i7 950 4Ghz on H100i, MSI X58 ProE, 24GB Gskill ripjaws 1600Mhz ram, Zotac GTX680 OC, Phantom820, Creative Xfi titanium, Seagate 10tb HDD, Roccat Isku FX, Razer Death adder on goliathus, BenQ GW2750HM, Tagan BZ800W Modular, JVC HA-RX900, M6
Gadgets : Motorola Xoom 32GB Wifi, HTC Titan, Galaxy Nexus, Sony DSC HX20V, Swift Lxi
www.havoknation.in
21-08-2012, 05:48 PM #17
21-08-2012, 05:56 PM #18
21-08-2012, 06:03 PM #19
Even Corsair AX1200 PSU has got enough customer complaints. But is it something we avoid ??
Thing is ; Extreme4 is a cheaper Z77 ATX board & packed with good features, where Asus failed to deliver.
As you have already mentioned, You are Pune based dealer. Search in google for a city named "Cuttack". Locally those dealers sells it at a price of 12.5k.
Now coming to OP, OP is buying from Delhi. I'm sure he will get a good deal, even lesser than 12k.2600k|Maximus IV Ex-Z|Venomous X RT CM R4's Push Pull|RipjawX 16GB|Sapphire HD7970 CF [1250MHz]|OCZ Vertex 3 120GB|WD Black Raid 0|AX850w|Asus Xonar DX|Dell U2412M x 3 Eyefinity|HAF 932 Advanced|Sentry II| Logitech G27, G15, Attack II, C310 HD|Razer DeathAdder, Megalodon|Steelseries Ikari Optical|
21-08-2012, 06:07 PM #20
so you will take a board which has a habit of having bent socket pins and faulty ram slots?
even when you have better options?
even the P8Z77 VLX is better than the Extreme 4....sadly GB has no intention of taking the mobo market here that's why board like this with bad bios and faulty parts are getting revered....2500K|3570K|FX-8150|FX-8350|965BE|E7500
21-08-2012, 06:13 PM #21
21-08-2012, 06:17 PM #22
21-08-2012, 06:25 PM #23
21-08-2012, 07:11 PM #24
21-08-2012, 08:48 PM #25
21-08-2012, 08:57 PM #26
Could have....but they don't give out samples.....and they aren't worth buying and reviewing...tried to like em...couldn't...too many probs.
Ontopic:the Extreme 4 has too many issues....over at E a member bought it and found damaged cpu socket....and there are various issues found all over the net...so i would suggest stay away from it.....lose the mouse....2500K|3570K|FX-8150|FX-8350|965BE|E7500
21-08-2012, 09:48 PM #27
21-08-2012, 10:46 PM #28
21-08-2012, 11:04 PM #29
Dude don't take it on heart but do check the below links :
Theitdepot - Intel Core I5-2500K 6MB 3.30GHz Processor (Chennai based dealer)
Intel Core i5-2500k Quad Core CPU (Mumbai based)
INTEL CORE I5 -2500K 3.30GHZ (Kolkata based)
Intel 3.3 GHz LGA 1155 Core i5-2500K Processor | Processor | Flipkart.com
http://www.smcinternational.in/index...mart&Itemid=72 (Delhi based dealer)Havok Rig : Core i7 950 4Ghz on H100i, MSI X58 ProE, 24GB Gskill ripjaws 1600Mhz ram, Zotac GTX680 OC, Phantom820, Creative Xfi titanium, Seagate 10tb HDD, Roccat Isku FX, Razer Death adder on goliathus, BenQ GW2750HM, Tagan BZ800W Modular, JVC HA-RX900, M6
www.havoknation.in
21-08-2012, 11:14 PM #30
I dont know if d3p "took is on his heart" or not, but he is right.
Prices vary a lot and for a lot of reasons ( not just for rise in dollar value).
3 weeks ago, I was quoted less than 12.5k for i5 2500k and asus p8z77m pro, separately, in bhubaneswar (30kms from cuttack). Prices in bhubaneswar and cuttack are somewhat similar.Need Help :Spoiler:
LinkBack URL
About LinkBacks
