Results 1 to 3 of 3
Thread: suggestions??
  1. #1
    Aug 2012
    Default suggestions??
    Ans: assassins creed 3 , hitman absolution, la noire, nfs run (i wish them to run on medium level)
    2. What is your overall budget? If you can extend a bit for a more balanced configuration, then mention this too.
    Ans: 18000 (for processor, motherboard, ram, graphics card, cabinate, psu)
    3. Planning to overclock?
    Ans: No
    4. Which Operating System are you planning to use?
    Ans: Win 7
    5. How much hard drive space is needed?
    Ans: 500gb
    Ans: No
    Ans: keyboard mouse speakers monitor
    8. When are you planning to buy the system?
    Ans: nov-dec 2012
    Ans: yes
    Ans: ajmer,rajasthan and yes i am available for online shopping
    Ans:
    my budget is a bit low,around 18000 rs just for the tower(not including monitor,mouse,keyboard,speakers)
    (i know the budget is really low as i want to build an entry-level gaming desktop but i can't really help it)
    what i've configured till now for me is-
    #intel i3 540 lga 1156 (around 5450rs)
    #wd/seagate 500 gb hardisk (around 4000rs)
    #transcend 4gb DDR3 ram (around 1200rs)
    now i want you to suggest a good motherboard costing around 5000rs which supports lga 1156 socket and is compatiable with my processor,
    and must have good graphics memory inbuilt(intel integrated hd graphics) as im planning to buy my graphics card AMD HD radeon 6670 (6500rs) a bit later
    Recently one of my friends bought a basic rig (not much interested in plyaing virtually) -dual core 2nd generation,a 'FOXCONN' motherboard which just had 1700mb inbuilt graphics (4,500rs) and no graphics card
    and that guy is able to play assassins creed 2 at full graphic settings and LA NOIRE at low both at an ok frame rate.
    so please suggest something like that to me as having an i3 with 700mb inbuilt graphics and a good graphics motherboard with good inbuilt graphics memory and later on my amd graphics card will do the work.
    you can also advise if i can get any better component in this price range.
    also tell me what amount of power supply unit will be sufficient for my config.
    thank you.. !!
    and please tell me does the DDR of the graphic cards effect on the game quallty. i mean is ddr5 will make the game quality better than compared to ddr3 ??
  2. #2
    Human Spambot thetechfreak's Avatar
    Nov 2008
    Guwahati
    Default Re: suggestions??
    You will build rig in November or December? No use recommending now. You are still around 4 months away. There might be new product launches and price changes by then.
    Follow me on Twitter: http://twitter.com/wuodland
  3. #3
    making future better Vyom's Avatar
    May 2009
    New Delhi
    ^^ yeah... Like Trinity processors!
    I am holding my purchase for it..
