Results 1 to 7 of 7
09-08-2012, 02:59 PM #1Right Off the Assembly Line
- Join Date
- Aug 2012
- Location
- Delhi
- Posts
- 8
Help needed building up a Gaming PC
1. What is the purpose of the computer? What all applications and games are you going to run?
Ans: Heavy gaming, Battlefield 3, NFS MW, MP3, GTA V, COD MW3, Skyrim, Metro 2033, crysis 2 at ultra settings HD resolutions 1080p. Besides that i'll be using these softwares for my work - Photoshop cs 6, Adobe premiere pro, coral draw, Final cut pro and many more software's i forgot the names
2. What is your overall budget? If you can extend a bit for a more balanced configuration, then mention this too.
Ans: Around 80-85 k , can extend till 90k but if the total stays in 80-85 then it will be awesome cuz i'll be buying games too
3. Planning to overclock?
Ans: Yes, beside gaming i'll be doing some other heavy stuff too so i guess it's required.
4. Which Operating System are you planning to use?
Ans: Windows 7, Which one is best ultimate or home premium cuz im buying it so i need my money to be put in right place.
5. How much hard drive space is needed?
Ans: 500 gb is okay for now, i'll be adding the 1TBs and the ssd's later.
Ans: Yes. Anywhere around 22-24 inches,resolution of 1920*1080.
Ans: Keyboard, mouse and speakers.
8. When are you planning to buy the system?
Ans: Next month 1st week. Or if i get the desired money before that then in this month only
Ans: Haven't built one, but shouldn't be a problem.
Ans: New Delhi. Yes from Nehru Place. If they don't have the stuff that i need then i can go for online shopping.
Ans: I need some clarification on the cpu coolers, as i'm going to overclock my cpu to 4.2 to 4.5 GHz so should i go for a liquid cpu cooler or air cooler ?
This is what i've came up with till now by reading the forums.
Processor :- Intel core i5 2500k
Motherboard :- Asus P8Z68 M Pro
Cpu Cooler :- Antec Kuhler h20 620
GPU :- Zotac GTX 670 amp edition
RAM :- Gskill Ripjaws X F3-12800CL9D-8GBXL
HDD :- WD Caviar Blue 500gb
DVD writer :- ASUS 24X Sata Black DVD
PSU :- Corsair CMPSU-650TXV2UK
Case :- NZXT Switch 810
UPS :- apc 1.1kva
Monitor :- Dell 22inch LED - ST2220L
I know the build that i have made it overshoots my budget
Please tell me if i'm going wrong somewhere.
09-08-2012, 04:04 PM #2
Re: Help needed building up a Gaming PC
Get a Cheaper Cabinet Like Cooler Master HAF 922 @ 7K or Get Corsair Carbide 400R @ 5K .
Get a Cooler Master Hyper 212+ @ 2K . That will Easily Hit 4.5 GHZ . Rest is Fine .
Dont expect to OC the CPU Like Crazy . It can easily do 4.2 GHZ to 4.5 GHZ.Intel Core I5 2400 | Intel DH67CL B3 | Corsair Value Select 2x 4 GB | Seagate Barracuda 500 GB HDD | Asus DVD RW | CM Elite 310 | Corsair GS600 | Logitech MK200 | Creative Speakers | Samsung S20B300 | V Guard UPS | Intel HD 2000 | Nokia Lumia 520 |
09-08-2012, 06:18 PM #3Right Off the Assembly Line
- Join Date
- Aug 2012
- Location
- Delhi
- Posts
- 8
The thing is i want a classy looking full tower case, carbide is out of my league
and how's the motherboard is it a good overclocker ?
09-08-2012, 09:35 PM #4
Yes , it is a good OCer . What about HAF 922 ??
09-08-2012, 09:57 PM #5In The Zone
- Join Date
- Feb 2012
- Location
- New Delhi
- Posts
- 371
why are you going for a zotac gtx 670
its a horrible brand with even worse cooling
you should consider this one-
Asus NVIDIA GTX 670 DC2 2 GB GDDR5 Graphics Card | Graphics Card | Flipkart.comSpoiler:
09-08-2012, 09:59 PM #6Right Off the Assembly Line
- Join Date
- Aug 2012
- Location
- Delhi
- Posts
- 8
10-08-2012, 11:52 AM #7
Who said it is horrible brand??
BTW the cooler on Zotac Amp! edition is best custom cooler for GTX 670
ZOTAC GeForce GTX 670 AMP! Edition 2 GB Review | techPowerUp
Here I can clearly see that the ASUS card runs 3C hotter thn the OCed Asus card.
@op
Don't go by full tower/mid tower kinda things
But this might help
Three Giants: Cooler Master Cosmos 1000, Corsair Obsidian 800D and Lian Li PC-X2000 - X-bit labs:P
LinkBack URL
About LinkBacks
