Ans: fps latest games with some civilization 5, cod latest, at low or mid display settings.
2. What is your overall budget? If you can extend a bit for a more balanced configuration, then mention this too.
Ans:10-15k
3. Planning to overclock?
Ans:no
4. Which Operating System are you planning to use?
Ansp sp3
5. How much hard drive space is needed?
Ans:500gb
Ans: i have Samsung 20 inch led.
Ans: keyboard, mouse, ups.
8. When are you planning to buy the system?
Ans:a month or so.
Ans:by an assembler.
Ans: I am staying at bhubaneswar. online option is open if found overal cheaper.
Ans: i want amd processor under 3k, am3 mobo under 3k, good graphix card under 5k, ddr3 ram.
