Results 1 to 7 of 7
  1. #1
    Aug 2012
    Default Build a gaming rig under 40k.
    I would like someone to help me in building my rig which i would mostly use for gaming purpose.
    My budget is 35000-40000rs.
  2. #2
    BMG ftw!! d6bmg's Avatar
    Aug 2011
    Kolkata
    Default Re: Build a gaming rig under 40k.
    Inactive in TDF.
  3. #3
    Aug 2012
    Quote Originally Posted by d6bmg View Post
    First of all my basic need is playing high graphics games like assassin's creed revelations,nfs hp3,fifa 12,prince of persia,just cause 1/2,skyrim,call of duty series etc.
    Secondly i would also use it for playing music & movies,for surfing the net,all types of huge and small downloads.
    My maximum budget is 42000Rs. 2000rs. up-down is agreeable.
    Right now i have no intention of overclocking but i may overclock after 5-6 years.
    Windows 7 would be my optimum need.
    I want to include a 1TB storage disk.
    I think a 20inch monitor would be enough.I dont know anything about their resolutions.
    I already have good quality keyboard,mouse,and speakers so i wont be purchasing new ones.
    A high rated cabinet is not my need,i can go on with a cheap one.
    My plan is to purchase it around diwali(November) this year itself.
    No i have never built a pc by my own before as i was a kid that time,but now i sure can assemble it by my own,currently doing engineering(B.tech.).
    I live in jaipur and would be buying the components locally.
    in case i dont get 1,then i'll order it online. Flipkart zindabaad!!
  4. #4
    d3p
    d3p is offline
    PowerHouse d3p's Avatar
    Jan 2010
    Bangalore
    we can have this discussion before two weeks to diwali. Time to close this thread.
    2600k|Maximus IV Ex-Z|Venomous X RT CM R4's Push Pull|RipjawX 16GB|Sapphire HD7970 CF [1250MHz]|OCZ Vertex 3 120GB|WD Black Raid 0|AX850w|Asus Xonar DX|Dell U2412M x 3 Eyefinity|HAF 932 Advanced|Sentry II| Logitech G27, G15, Attack II, C310 HD|Razer DeathAdder, Megalodon|Steelseries Ikari Optical|
    My Game Collection & Sapphire HD 7970 Unboxing
  5. #5
    Nov 2011
    Chennai
    Quote Originally Posted by d3p View Post
    Dont break this kiddo's heart dude
  6. #6
    xSorRoWx
    Jul 2012
    Hyderabad, A.P, IN
    Intel Rig:
    1) Intel Core i3 2120 - 7k
    2) Gigabyte GA-H61M-D2H - 3k
    3) G.Skill RipjawsX 4GB ddr3 1333mhz -1.6k
    4) 1TB 7200 RPM SATA3 HDD - 5k
    5) PSU Cosair CX430 V2 - 2.3k
    6) Cooler Master Elite 310 ATX - 1.8k
    7) Optical Drive - 1k
    8) Samsung S20B300B HD LED - 6.5k
    9) UPS - 1.5k
    10) GPU ATI/AMD Radeon HD 7770 - 9k
    ________________
    Total - 38.7k
    You can go for i5 2400 will cost you total 42.7k
  7. #7
    laborare est orare Cilus's Avatar
    Mar 2009
    Kolkata
    Closing the thread as there is no point of discussion if you wanna buy the rig at November. Start a new thread 2 or 3 weeks before the purchase.
    AMD FX 8350|16 GB RipjawX 1873 MHz CL10 @ 1.6V MHz|1+2TB Seagate + 1 TB WD Green 64MB Cache|Sabertooth 990FX|Sapphire HD 7950 VApor-X OC with Boost|GT 240 1 GB GDDR5 PhysX|CM690II Advanced|LG D2342P Cinema 3D Display|TX850 V2|2 CM 1600RPM FAN|MX518|Razer Goliathus|Razer Arctosa|Razer Megalodon 7.1 Headset|CM Hyper 212 Plus|APC1.1KVA| Moto Defy Plus|HCL Me Y2 Tab (rooted)
Tags for this Thread
