Results 1 to 3 of 3
Thread: Laptop under 40k
06-08-2012, 10:15 PM #1Right Off the Assembly Line
- Join Date
- Aug 2006
- Posts
- 34
Laptop under 40k
Hi,
I want to buy a new laptop & my budget is around 40k.
My requirements are:
High priority:
1) Hardcore programming = processing power must be high. I shall run Java IDE, Databases, App and Web Server + 10 other apps running simultaneously
2) Enough RAM to make my work as swift as possible. Maybe 6GB or 8GB would be enough, I think.
3) Connectivity options: the more the better
4) Battery life
5) Screen size: 15 or bigger
Medium priority:
1) Screen - good if supports HD
2) graphics
Low priority:
1) Speakers
2) looks
Can you kindly suggest the best that matches these requirements.
07-08-2012, 12:58 AM #2
07-08-2012, 01:42 PM #3Right Off the Assembly Line
- Join Date
- Aug 2006
- Posts
- 34
LinkBack URL
About LinkBacks
