Results 1 to 13 of 13
05-08-2012, 11:34 PM #1
Suggestion for low budget gamming pc!!!!
Ans: Gaming (fifa 12, bf3, maxpayne 3, gta4)
2. What is your overall budget? If you can extend a bit for a more balanced configuration, then mention this too.
Ans: strictly 15000rs
3. Planning to overclock?
Ans: No
4. Which Operating System are you planning to use?
Ans: windows 7
5. How much hard drive space is needed?
Ans: 250GB (500GB if in any case can accomodate in the price tag)
Ans: yes, 1280x1024
Ans: exclude case ,monitor and psu
8. When are you planning to buy the system?
Ans: This week
Ans: Yes , Myself
Ans: Locally, Kerala (open to buy online if couldnt find locally)
This pc is for my friend i have a config in consideration want to know your suggestions,
CPU: AMD A8-3870K
MB : ASUS F1A55-M LX PLUS
RAM:CORSAIR XMS3 1600MHZ DDR3
HDD:250 GB SEAGATE
I guess a generic psu can suffice the power requirement of ths system very well. pls comment and suggest.
05-08-2012, 11:49 PM #2
Re: Suggestion for low budget gamming pc!!!!
I guess you'll be needing a Monitor too and I don't think all of these components can be accomodate within 15K budget. Still, trying my best:-
Intel Pentium G620 @ 3.3K
Gigabyte H61-D3 Motherboard @ 3.2K
Corsair Value Series 4GB 1333 MHz DDR3 @ 1.3K
Seagate 500 GB SATA II HDD @ 4K (Price diff between 500 GB and 250 GB is very less)
Sapphire/MSI HD 6670 1 GB GDDR5 @ 5.4K
Acer 20" LCD Display @ 5.3K (Check Deltapage.com)AMD FX 8350|16 GB RipjawX 1873 MHz CL10 @ 1.6V MHz|1+2TB Seagate + 1 TB WD Green 64MB Cache|Sabertooth 990FX|Sapphire HD 7950 VApor-X OC with Boost|GT 240 1 GB GDDR5 PhysX|CM690II Advanced|LG D2342P Cinema 3D Display|TX850 V2|2 CM 1600RPM FAN|MX518|Razer Goliathus|Razer Arctosa|Razer Megalodon 7.1 Headset|CM Hyper 212 Plus|APC1.1KVA| Moto Defy Plus|HCL Me Y2 Tab (rooted)
06-08-2012, 05:41 AM #3
cilus no need of monitor thread edited , sry my mistake. budget should come within 15k. Cannot be extended.
Can the config suggested work on a generic psu , or will it need branded one.Last edited by zacfx05; 06-08-2012 at 05:46 AM.
06-08-2012, 04:22 PM #4
IF you dont need a monitor , then get a PSU for that money .
Get CORSAIR VS450 for 2.3K or Corsair CX430 V2 @ 2.7K .Intel Core I5 2400 | Intel DH67CL B3 | Corsair Value Select 2x 4 GB | Seagate Barracuda 500 GB HDD | Asus DVD RW | CM Elite 310 | Corsair GS600 | Logitech MK200 | Creative Speakers | Samsung S20B300 | V Guard UPS | Intel HD 2000 | Nokia Lumia 520 |
06-08-2012, 04:55 PM #5
^^ but the overall cost will be approx 19000rs, and the maximu he can go is 16000rs. I kno it is hard, that's why I taught of going liano path even though it may not have upgrade path. I taught by doing that a generic psu can do the job without worry. Later he can buy a good psu.
Dedicated gpu plus corsair psu will cost more that for the time he cannot afford.
Pls suggest some method probabily a tricky one.
06-08-2012, 09:22 PM #6Broken In
- Join Date
- Jun 2012
- Location
- Lucknow, Uttar Pradesh
- Posts
- 159
AMD A6 3650: 5.5k
Gigabyte A55M-DS2: 3.2k
GSkill RipJawsX 4GB 1600MHz: 1.5k
Seagate 500GB: 3.8k
LG 22x SATA DVD writer: 0.9k
Intex 600VA: 1.3k(optional)
Total: 15k(without UPS)
16.3k(with UPS)
07-08-2012, 09:39 PM #7In The Zone
- Join Date
- Feb 2012
- Location
- New Delhi
- Posts
- 371
amd a4 3400-rs 3604
Gigabyte A55M-DS2 Motherboard-rs3200
Corsair XMS3 DDR3 4 GB (1 x 4 GB) PC RAM -rs 1733 (ram is expensive because the igpu benefits from faster ram)
WD Caviar Blue 500 GB HDD Internal Hard Drive-rs 3969
asus dvd drive-rs 1200
total-rs 13706
08-08-2012, 09:58 PM #8Broken In
- Join Date
- Jun 2012
- Location
- Posts
- 159
@OP Go with the A6. Better than the A4 in every aspect. A4 is a dual core while the A6 is a quad core. And the A6 has better Graphics too.
08-08-2012, 10:06 PM #9In The Zone
- Join Date
- Feb 2012
- Location
- New Delhi
- Posts
- 371
but op is on budget
he can buy a hd 6450 and cfx it and it would be better than a6 inte graphicsSpoiler:
10-08-2012, 05:42 PM #10
thnks guys
10-08-2012, 08:14 PM #11Broken In
- Join Date
- Jun 2012
- Location
- Posts
- 159
@panwala95 So what? He can do the same with A6 and though OP is on a budget, the rig suggest by me is in his budget. So by shelling out 1 or 2k gives him an awesome rig so why not?
10-08-2012, 08:15 PM #12Right Off the Assembly Line
- Join Date
- May 2012
- Location
- Pune
- Posts
- 17
10-08-2012, 08:30 PM #13Broken In
- Join Date
- Jun 2012
- Location
- Posts
- 159
^+1 @OP get the A6 eyes closed. Value for money.
Need suggestion for gamming headsets ~5k
By dalepraneeth in forum AudioReplies: 10Last Post: 07-06-2012, 05:03 PM -
Gamming laptop budget 65-70K
By zacfx05 in forum Laptops and NetbooksReplies: 6Last Post: 30-12-2011, 08:39 PM -
PC Upgrade suggestion budget 25K
By Arcturus in forum PC Components / ConfigurationsReplies: 5Last Post: 05-06-2011, 04:32 AM -
Laptop suggestion Max budget 35k
By Ronnie11 in forum Hardware Q&AReplies: 8Last Post: 23-08-2009, 04:47 PM -
configuration suggestion budget 1.25
By deepakd in forum QnA (read only)Replies: 15Last Post: 09-06-2005, 10:22 AM
LinkBack URL
About LinkBacks
