Results 1 to 9 of 9
  1. #1
    Sep 2008
    Default 20k PC excluding monitor, speakers,Gfx Card.
    1. What is the purpose of the
    computer? What all applications
    and games are you going to
    run?
    Ans:
    HD Movies, MS Expression Web, Low End Gaming - Lowest settings will do
    2. What is your overall budget?
    Ans:
    20,000
    3. Planning to overclock?
    Ans:
    Maybe
    4. Which Operating System are
    you planning to use?
    Ans:
    Win Vista, 7 or 8
    5. How much hard drive space
    is needed?
    Ans:
    Already got 1TB ext HDD, so only want lowest size HDD for Win,app installations.
    6. Do you want to buy a
    monitor?
    Ans:
    No, I will be using LG 23" Full HD Monitor at 1920x1080
    7. Which components you
    DON'T want to buy or which
    components you already have
    and plan on reusing?
    Ans:
    Monitor, Speakers
    . Also ignoring GFX Card for the time being due to budget limitations.
    8. When are you planning to
    buy the system?
    Ans:
    As soon as I can make my mind
    9. Have you ever built a
    desktop before or will this be
    done by an assembler?
    Ans:
    No but I will be doing myself this time with the help of youtube or friends.
    10. Where do you live? Are you
    buying locally? Are you open to
    buying stuff from online shops
    if you don't get locally?
    Ans:
    Chandigarh, India
    Yes, Locally or Flipkart where price is right.
    11. Anything else which you
    would like to say?
    My current build open for your suggestions and plz also check the compatability
    1. Processor
    AMD FX 4100 3.6Ghz Quad Core Rs 6,900
    There is lot of negativity in forums toward this processor but is otherwise top selling processor at least on flipkart !
    i3 2120 beats FX in benchmarks but only marginally
    , everything else seems to be in FX's favour.
    2. MOBO
    Asus M5A88-M
    Rs 5,600
    HDMI,DVI,USB 3.0,SATA 6Gbps and last but not least on board Radeon HD4250 as I am postponing GFX card purchase for few months for budget limitations. One of the website marked this whole config green for Max Payne 3. So will I be able to play most of the games on at least lowest settings/reso? If not I can wait until I buy gfx card. I have Xbox 360 for the time being.
    3. RAM
    Corsair Vengeance 4GB RAM 1600 Mhz
    Rs 1,800
    4. Cabinet
    CM Elite 310 Rs 2,000
    5. 160/250 GB HDD
    6. Cheap Keyboard, Mouse
    7. PSU
    How much wattage SMPS will be good for the above config?
    Nokia N79
    SE K310i
    Xbox 360 Elite
    P4 2.67 GhZ, 512 MB RAM, 1 TB HDD, Geforce 5200 (VRAM 128 MB), LG 23" Full HD Monitor.
  2. #2
    xSorRoWx
    Jul 2012
    Hyderabad, A.P, IN
    Default Re: 20k PC excluding monitor, speakers,Gfx Card.
    No doubt, intel core i3 2120 is best when it comes to budget gaming. I advise you not to go for amd fx 4100. You can fix your mind on i3 2120 or you can go for amd phenom ii x4 960t. Cosair cx430v2 will be more than enough for core i3, get a 450-500 watts for amd 960t or amd fx 4100.
  3. #3
    Wise Old Owl Sainatarajan's Avatar
    Apr 2012
    Santiago Bernabeu , Madrid , Spain
    Also go for Corsair Value Select 4 GB 1333 DDR3 RAM .
    Intel Core I5 2400 | Intel DH67CL B3 | Corsair Value Select 2x 4 GB | Seagate Barracuda 500 GB HDD | Asus DVD RW | CM Elite 310 | Corsair GS600 | Logitech MK200 | Creative Speakers | Samsung S20B300 | V Guard UPS | Intel HD 2000 | Nokia Lumia 520 |
  4. #4
    Broken In rockfella's Avatar
    Jan 2008
    Gurgaon
    Op should go with gigabyte motherboard. Gigas have less failure %.
    AMD Phenom II 560-Gigabyte GA78LMT USB3-Corsair Vengeance 4GB DDR3-ASUS Xonar DX-1250GB-DELL SP2208WFP-VX450-Corsair Carbide 400R
  5. #5
    Human Spambot saswat23's Avatar
    Jan 2011
    Bhubaneswar
    For 20k:
    * AMD Phenom-II X4 960T -- 6.8k
    * Asus M4A88-M LX -- 4k
    * Corsair 4GB DDR3 Value RAM -- 1.3k
    * WDC Blue 500GB HDD -- 3.8k
    * Corsair CX-430v2 -- 2.5k
    * CM Elite 310 -- 1.8k
    * Local kb+mouse -- 0.4k
    Total ---- 20.2k
    Check here
    My Blog :D
  6. #6
    Sep 2008
    Thank you all for your quick replies.
    Phenom 960T will be my first preference.
    Quote Originally Posted by saswat23 View Post
    For 20k:
    Total ---- 20.2k
    The new problem, Phenom 960T has disappeared from shops including 965,970 etc. I guess I am out of luck
    Nokia N79
    SE K310i
    Xbox 360 Elite
  7. #7
    Jun 2012
    Lucknow, Uttar Pradesh
    Intel rig
    Intel Core i3 2120: 7k
    Gigabyte H61M-D2H: 3.3k
    4GB DDR3 1333MHz: 1.2k
    250GB HDD: 3k
    Cooler Master Elite 310: 1.8k
    Logitech combo: 0.5k
    FSP Saga II 400W: 2k
    LG 22x SATA DVD writer
    Total: 19.7k
  8. #8
    BMG ftw!! d6bmg's Avatar
    Aug 2011
    Kolkata
    Quote Originally Posted by karamvirk View Post
    Really? Look at flipkart.
    Neah! Not anymore.
    Now you have option to go with FX6100.
  9. #9
    Jan 2011
    Bhubaneswar
    Smile Re: 20k PC excluding monitor, speakers,Gfx Card.
    Then replace mobo and proccy with:
    * Intel i3-2100 -- 6.4k
    * Gigabyte GA-B75M-D3H -- 4.6k
    And this a better performer than Phenom-II X4 960T
    Check here
    My Blog :D
  1. PC for gaming under 18k [Excluding monitor, HDD etc]
    By Nipun in forum PC Components / Configurations
    Last Post: 06-01-2012, 04:59 AM
  2. Making a very cheap rig excluding monitor: urgent
    By Saurav2007 in forum Hardware Q&A
    Last Post: 23-08-2010, 02:45 PM
  3. Which is the Best Monitor and speakers
    By abhisubscribe in forum Audio
    Last Post: 14-04-2009, 12:29 AM
  4. Replies: 6
    Last Post: 05-01-2009, 06:41 AM
  5. Ques: Monitor,Speakers,Liteon
    By bajaj151 in forum Audio
    Last Post: 26-04-2008, 05:24 PM
