Results 1 to 30 of 30
  1. #1
    Jul 2012
    Grove Street, Los Santos
    Talking I need a fool proof PC configuration
    Hi all gurus
    I need a mid level configuration. Don't need UPS, Monitor, peripherals, mouse...etc. I just need a fool proof configuration for the "box"
    Ans: Photoshop, Illustrator, video editing softwares (rendering jobs etc). Games like GTA 4 at mid level details, if possible.
    2. What is your overall budget? If you can extend a bit for a more balanced configuration, then mention this too.
    Ans: 15 - 20k
    3. Planning to overclock?
    Ans: No
    4. Which Operating System are you planning to use?
    Ans: Win 7
    5. How much hard drive space is needed?
    Ans: 250 gb
    Ans: Dont need monitor.
    Ans: UPS, Mouse, Key board, peripherals. Just need a configuration for the "box"
    8. When are you planning to buy the system?
    Ans: within a month
    Ans: Yes but here is a catch. I have assembled PCs in the past but I have little idea of latest cabinet and how they fit. I can take the help of an assembler but the configuration should be "fool proof" as I am going to buy most of the parts from online stores.
    Ans: NE India. Mostly online.
    Ans: I would really appreciate any help
  2. #2
    xSorRoWx
    Jul 2012
    Hyderabad, A.P, IN
    Intel core i3 2120 - 7k
    Gigabyte GA-H61M-D2H - 3.3k
    G.Skill RipjawsX 4GB DDR3 1333Mhz RAM - 1.6k
    500GB @ 7200rpm SATA 2 Hard Disk capacity - 3.9k
    Cosair CX430 V2 430Watts PSU - 2.7k
    Cooler Master Elite 310 ATX - 2.0k
    Total - around 21k(flipkart)
    With a good graphic card later, like gigabyte hd 7770 it'll cost 30k
    {your talking about a mid gaming rig hope you understand.}
    Configuration above is somewhere between entry level gaming and mid gaming rig. If you already have a cabinet i.e what you call "the box" then remove cooler master elite 310 atx from the list.
  3. #3
    Jul 2012
    Default Re: I need a fool proof PC configuration
    I was more inclined towards this processor:
    AMD 3.6 GHz AM3+ FX4100 Processor ,
    any comments on this?
  4. #4
    Jul 2012
    Smile Re: I need a fool proof PC configuration
    Thanks for the info.
    Can Anyone throw some light on the FX 4100 processor... I think it will be cheaper couple with an Asus M5A78L-M LX MB.
  5. #5
    Wise Old Owl Sainatarajan's Avatar
    Apr 2012
    Santiago Bernabeu , Madrid , Spain
    I3 Can trash the FX 4100 . But you can also go for Phenom 960T @ 7K
    Intel Core I5 2400 | Intel DH67CL B3 | Corsair Value Select 2x 4 GB | Seagate Barracuda 500 GB HDD | Asus DVD RW | CM Elite 310 | Corsair GS600 | Logitech MK200 | Creative Speakers | Samsung S20B300 | V Guard UPS | Intel HD 2000 | Nokia Lumia 520 |
  6. #6
    Jul 2012
    Question Re: I need a fool proof PC configuration
    Quote Originally Posted by Sainatarajan View Post
    Hi Sai,
    Thanks for the reply
    So which one should I go for - i3 or Phenom 960t?
    btw one more noob question, is it possible to take out the smps from my older wipro cabinet (came with an inbuilt type SMPS) and fit a new corsair 450w?
  7. #7
    Requiscat in Pace Gearbox's Avatar
    Jul 2012
    \home\office\
    Radeon HD 6670 DDR5 will cost you around 5.5, with some midlevel gaming.
    Reality is always controlled by the people who are the most insane.
  8. #8
    Jul 2012
    ps I saw that the FX 4100 is one of the most popular processors in Flipkart plus better specs than 960t. So why the price difference?
  9. #9
    Jun 2012
    Lucknow, Uttar Pradesh
    because it has some issues regarding windows 7. But it is a great overclocker. Many reviewers oc'ed it up to 1GHz with the stock cooler.
  10. #10
    L33+ P$yCh0 Chaitanya's Avatar
    Jul 2011
    Paradise City
    Cool Re: I need a fool proof PC configuration
    Quote Originally Posted by lonewolf View Post
    If the older one was ATX compliant then Corsair will fit in..
    Else pick up ruler measure for yourself by checking dimensions @ corsair website
    Quote Originally Posted by Utkarsh Sharma View Post
    I agree & also mind that Bulldozer architecture is failure @ Windows..
    You have to use some other OS ( linux etc...) to use it to fullest..
  11. #11
    Jul 2012
    Many thanks for the replies Really helps.
    I am a little inclined towards AMD this time (never used it before).
    How does the phenom 960t compare against i3?
    btw Any views / comments on this MB - ASUS M5A78L-M LE?
  12. #12
    xSorRoWx
    Jul 2012
    Hyderabad, A.P, IN
    intel i3 2120 beats unclocked phenom 960t. If plan to go for 960t then you'll should have to plan for a good motherboard which may cost 2-3k extra.
  13. #13
    Apr 2012
    AMD Phenom 960T + ASUS M4A88M LE @ 11K . This Should be your Choice if you going with AMD .
  14. #14
    BMG ftw!! d6bmg's Avatar
    Aug 2011
    Kolkata
    ^^ Using M4A88M-LE have the only disadvantage of sacrificing the OC'ing ability of 960T due to lower power phase.
  15. #15
    Jul 2012
    Couldn't find the 960t anywhere online, is it discontinued??
    Actually I was referring to this MB - ASUS M5A78M LE and not ASUS M4A88M LE. The second one will go beyond my budget
  16. #16
    xSorRoWx
    Jul 2012
    Hyderabad, A.P, IN
    i think so, along with all 9xx series including black editions. I was told by my local dealer
  17. #17
    Apr 2012
    @D6bmg
    You are Right . But everything should be between 15 to 20K .
    @ OP
    When games start to use More than 2 or 3 Cores Phenom 960T would benefit and it is also a Overclocker .
  18. #18
    Aug 2011
    Kolkata
    Ah! Now I can see that too.
    Now you can either buy FX6100 or go for APU based config. Don't ever think of FX4100. Really.
  19. #19
    Jul 2012
    I could find a Phenom 955t black edition from the local dealer. But he is charging Rs. 6900 for it.
    I wonder how the FX 4100 became a best seller in FK with tons of good reviews.
  20. #20
    Apr 2012
    It Must Be Phenom 2 X4 955 BE .
  21. #21
    Jul 2012
    one other thing I noticed: ASUS M5A78L-M LX / LE will support upto 95W CPU so 9xx series is out of question I guess...
  22. #22
    Aug 2011
    Kolkata
    FX4100 is cr@p. Just see some reviews from good websites and you will see. Those reviews at flipkart are mostly from self-boasting customers who don't have any idea about processors. If you really want to go for FX processors, FX6100 should be the minimum choice.
  23. #23
    Jul 2012
    Quote Originally Posted by d6bmg View Post
    Will this SMPS - Corsair CX430 support the FX 6100 (on a ASUS M5A78L-M LE Mother Board) with a mid level GFX card (like 550Ti or hd 7770) added later?
  24. #24
    Aug 2007
    Chinchwad Pune
    Yeah FX 4100 is epic fail for enthusiastic people. I also wanted to upgrade to a BD and bought 955 BE for the time being and ended up keeping it as it trashes the FX4100 in most cases. Waiting for PileDriver now :S
    Phenom II 955 BE | Gigabyte GA-880 GM - USB3 | CM Hyper 212 EVO | Zotac GTX 560 Ti | RIPJAWS 2 x 2 GB DDR3 1600 | Cosair HX750W | Kingston v300 SSD 240 GB | Seagate : 1 TB | NZXT Phantom 410 | Sony Experia Neo V
  25. #25
    Jul 2011
    Paradise City
    I have no idea of whether it will run FX6100 + 550ti
    But it can run 7770+FX6100 without any hiccups
  26. #26
    Aug 2007
    Chinchwad Pune
    Off Topic @ OP Nothing in this world is "FOOL" proof.
  27. #27
    Jul 2012
    Quote Originally Posted by Chaitanya View Post
    Thanks for the input.
  28. #28
    Jul 2012
    Hi guys...the noob is back!!
    I got this built -
    Fx 6100,
    MB - ASUS M5A78L-M LX V2 - ASUS M5A78L-M LX V2 Motherboard: Flipkart.com
    PSU - COOLER MASTER ELITE POWER 460W regular (Newer model. not listed on Flipkart)
    CORSAIR 1600MHZ 4 GB
    SEAGATE 500GB
    Total - 17.7 k (local market)
    Well now I need a graphic card. I have zeroed in on two models -
    Sapphire AMD/ATI HD 7750 1 GB GDDR5 Graphics Card
    or
    Gigabyte AMD/ATI Radeon HD 6670 2 GB DDR3 GV-R667D3-2GI Graphics Card (cheaper)
    I know that my MB and PSU can support the latter card but I need some help with the other one (hd 7750).
    My question is - will the hd 7750 work properly on my system???
    Specs here: SAPPHIRE HD 7750 1GB GDDR5
    Any help will be much appreciated.
  29. #29
    laborare est orare Cilus's Avatar
    Mar 2009
    Kolkata
    This is a really noob question, to be honest. try to understand this, Any PCI Express X16 Video Card can be used with any motherboard with a PCIe X16 slot.
    Have a read here: Basic information regarding graphic cards for newbies
    What is your budget for the Graphics card?
    AMD FX 8350|16 GB RipjawX 1873 MHz CL10 @ 1.6V MHz|1+2TB Seagate + 1 TB WD Green 64MB Cache|Sabertooth 990FX|Sapphire HD 7950 VApor-X OC with Boost|GT 240 1 GB GDDR5 PhysX|CM690II Advanced|LG D2342P Cinema 3D Display|TX850 V2|2 CM 1600RPM FAN|MX518|Razer Goliathus|Razer Arctosa|Razer Megalodon 7.1 Headset|CM Hyper 212 Plus|APC1.1KVA| Moto Defy Plus|HCL Me Y2 Tab (rooted)
  30. #30
    Jul 2012
    Thanks for the reply and the link.
    Budget is 7k. Should I go for this (hd7750)?
  1. Replies: 3
    Last Post: 29-11-2011, 07:04 PM
  2. How can i fool websense ??
    By raksrules in forum QnA (read only)
    Last Post: 16-07-2008, 10:40 AM
  3. April Fool Ad!
    By Kiran.dks in forum Chit-Chat
    Last Post: 01-04-2008, 08:24 AM
  4. Need Help: How to fool Windows???
    By subratabera in forum Software Q&A
    Last Post: 22-12-2006, 06:38 PM
  5. Cd writer: trying to fool
    By agm_1052001 in forum Hardware Q&A
    Last Post: 11-08-2006, 07:54 PM
