Results 1 to 17 of 17
  1. #1
    * bajaj151's Avatar
    May 2006
    India
    Default 2.1 Audio System for Single Room
    1) Includes woofer
    2) Good Bass
    3) Within 2k
    Phenom x6 1055T 3.36 GHz | MSI 890GXM G65 | Corsair XMS3 2*4GB 1600mhz | BenQ E2200HD | Xbox 360 Controller | Seagate 500GB | Seagate GoFlex 3.0 2TB | WD My Book Essential 3.0 1TB | CM HAF 922 | Corsair VX 550 | Logitech MX 518 | Logitech Wireless Keyboard | Sapphire 7850 OC | APC 1kVA | Razer Goliathus Control | Logitech C270H | Hyper 212EVO (Push Pull) | Asus RT N13U on DD-WRT |
  2. #2
    L33+ P$yCh0 Chaitanya's Avatar
    Jul 2011
    Paradise City
    Cool Re: 2.1 Audio System for Single Room
    Altec Classic Audio VS2621 @ 2k
    Perfect 2.1 ...
    Best speakers @ 4k range & absolute VFM..
    I've been using it for 2 yrs straight
  3. #3
    Human Spambot MegaMind's Avatar
    Nov 2010
    Perambalur, TN
    Default Re: 2.1 Audio System for Single Room
    Quote Originally Posted by Chaitanya View Post
    Not exactly..
    @OP, Try to get creative t3100 ~2.2k.. with some bargaining u should be able to get it for 2k..
    i5 2500K - P8Z68-V - Venomous X - RipjawsX 8GB 1600Mhz CL8 - Plextor M3 PRO 128GB - 1TB 7200.12 - GTX 570 sonic platinum - CM M600 - HAF X - XONAR DX + VS4121/XB500 - OptX AW2210 - DSL 2750U - Micro 800va
  4. #4
    Jul 2011
    Paradise City
    LINK
    LINK 2
    Decide yourself..
  5. #5
    Nov 2010
    Perambalur, TN
    LINK
    LINK 2
    Decide yourself..
    I believe my ears more than any comments/reviews, so i still recommend a T3100 for 2k..
    Also the link 2 is misleading... Its like saying AMD is better than intel/nvidia is better than AMD..
  6. #6
    Jul 2011
    Paradise City
    @OP test the speakers suggested & get one you like.
  7. #7
    Jun 2012
    Perfect 2.1 ...
    Me too using same for 1.5 years its vfm go for it
  8. #8
    Alpha Geek funskar's Avatar
    Sep 2011
    India
    F&D A-520 is also good.
    Bt u shud try first for creative t3100
    ||i5-2500K|Ga Z68xp-Ud4|Ripwas X 8gb|Vx550|Seagate 1Tb+500Gb+250gb|Asus Xonar Dx 7.1|Logitech Z906|Xbox 360 Controller|Haf 922|Ps3|No Gpu-Sub 20k Gpu Cuming Soon
    If you Don't have a UID card Then Visit Bangladesh Once n buy it for 100 Inr..
  9. #9
    Live.To.RISE. rajatGod512's Avatar
    Aug 2011
    Kanpur,India
    +1 for F&D A-520 , I have them, the BASS is just brilliant and the sound is also quite clear at full bass and volume
    The Final Avenger
    Core i7 2600k|ASUS P8Z77-V LX|G.Skill Ripjaws X 1600 Mhz 8GB (4x2)|Gigabyte HD 7850 2GB OC|WDC Blue SATA III 500 GB +160GB |Asus DRW-24B5ST|Seasonic S12II-520|CM 690 II Advanced USB 3.0 (Transparent Side Panel)|Logitech G300|Logitech K100|F&D A-520|Razer Goliathus Speed|Compaq 510|Samsung Galaxy Y GT-S5360|
    “Today, at the edge of our hope, at the end of our time, we have chosen to believe in each other. Today, we face the monsters that are at our door. Today, we are canceling the apocalypse!”
  10. #10
    Nov 2011
    Chennai
    I will vote for T3100/T3130 too as @MegaMind suggested.. I have heard both F&D A520 and T3100 definitely creative's bass is good compare to F&D..Personally i didnt get satisfied with F&D A520..
    AMD 970BE,880GM-USB3,2*2GB,Gkill Ripjaws 1600mhz,1tb Hdd,MSI 6850 Cyclone Edition,TX650 v2,NZXT Gamma,Dell ST2220L,M115+Razer Goliathus,SB 5.1VX,Edifier HCS2330,APC 1.1KV
  11. #11
    Jul 2011
    Paradise City
    Quote Originally Posted by kbganesh View Post
    Have you tested V2621??
  12. #12
    Nov 2011
    Chennai
    ^No that model i havent heard in it buddy but altec time is over after MX5021 hearing lot of bad reviews about it recently..
  13. #13
    Jul 2011
    Paradise City
    Might be ....
    See it is not necessary that one or 10 bad products from a brand mean the 11th ought to be bad
  14. #14
    Nov 2010
    Perambalur, TN
    when it comes to VS2621 vs T3100, the latter will blow off the former..
    -True story..
    I have checked these speakers myself..
  15. #15
    Jul 2012
    Kanpur
    F&D A555U is the best choice.
    +56watt rms
    +SD card/pendrive slot
    + Remote
    +FM radio
    +great sound.
    +2.1k price
  16. #16
    Jun 2012
    Quote Originally Posted by MegaMind View Post
    -True story..
    What is the output of t3100 ?
  17. #17
    BMG ftw!! d6bmg's Avatar
    Aug 2011
    Kolkata
    Go for F&D A555U. It is a good multimedia 2.1 speaker.
  1. Car audio system @ 5k
    By ArjunKiller in forum Audio
    Last Post: 21-02-2012, 10:28 PM
  2. Replies: 4
    Last Post: 08-11-2010, 11:12 PM
  3. can i use single monitor with multiple system
    By Hsakarp_kahtap in forum Hardware Q&A
    Last Post: 14-07-2010, 12:07 AM
  4. How to configure SATA and ATA HDD in a single system
    By dmbabu_9@yahoo.com in forum PC Components / Configurations
    Last Post: 25-08-2008, 04:28 PM
  5. Room security system
    By vedant_15 in forum QnA (read only)
    Last Post: 01-09-2004, 09:03 PM
