Page 1 of 2 1 2 LastLast
Results 1 to 30 of 45
  1. #1
    Jun 2012
    Default Finishing my rig. Please help me
    hi guys, i got a i5-3450 and a MSI TF 7850 .. yaay !
    now going hunting for the other parts,
    mobo - Gigabyte B75m-d3h
    RAM - RipjawsX 4GB
    PSU - SeaSonic S12II 430
    CASE - NZXT Gamma
    monitor - g2222hdl
    Budget : 20k strict
    Crossfire : No
    Overclocking : GPU only
    Use : Gaming (BF3 multiplayer mainly, and all the good games out there)
    Please dont ask me to fill the form. I think i have given the necessary details.
    And thanku Shall i get the parts ? Feel free to make changes. And im low on budget.. so please dont suggest a very expensive motherboard.
    EDIT : i ll reuse my old HDD and DVD drive.. i want only psu,mobo,ram,case,monitor
    Last edited by digit1191; 21-07-2012 at 12:54 AM. Reason: missed out on a few details.
  2. #2
    Aug 2007
    Chinchwad Pune
    Default Re: Finishing my rig. Please help me
    Only thing I would recommend is getting a GS600or any 550W+ Model. 430W isn't exactly that future proof. Also Seasonic are good PSUs but may create RMA issue later due to scarcity.
    Phenom II 955 BE | Gigabyte GA-880 GM - USB3 | CM Hyper 212 EVO | Zotac GTX 560 Ti | RIPJAWS 2 x 2 GB DDR3 1600 | Cosair HX750W | Kingston v300 SSD 240 GB | Seagate : 1 TB | NZXT Phantom 410 | Sony Experia Neo V
  3. #3
    Wise Old Owl Sainatarajan's Avatar
    Apr 2012
    Santiago Bernabeu , Madrid , Spain
    Get a CORSAIR GS500 or GS600 .BTW , why you created A NEW thread.
    Intel Core I5 2400 | Intel DH67CL B3 | Corsair Value Select 2x 4 GB | Seagate Barracuda 500 GB HDD | Asus DVD RW | CM Elite 310 | Corsair GS600 | Logitech MK200 | Creative Speakers | Samsung S20B300 | V Guard UPS | Intel HD 2000 | Nokia Lumia 520 |
  4. #4
    Jun 2012
    actually sorry abt creating a new thread.. so u say everything is OK except PSU ? i m planning to get the parts in 3 - 4 days from ritchie street. and from my throrough research i found that 7850 with ivy bridge CPU requires only 300 watts max , even when the GPU is OC'd. So do i really need a 500w ? trying to save some cash man G2222HDL is around what ... 8k now ?
  5. #5
    Human Spambot saswat23's Avatar
    Jan 2011
    Bhubaneswar
    Yup, get a CX-500v2 or GS500 instead.
    Also look for Dell ST2220L, will cost around 8.5k
    GAMMA would be hard to find these days. If so, then get Source Elite 210 for 2.4k or CM Elite 430 for 2.75k.
    Check here
    My Blog :D
  6. #6
    Jun 2012
    hmmm isnt the seasonic 430w better than corsair cx 500 ? seasonic is 80 + Bronze.. And im surely not going to crossfire.. And why are u suggesting 500 when 430 is more than enough for a ivyB and 7850 ? If im making a mistake tell me.. i researched a lot about this and found 430w was more than enough.
    even if the 7850 is heavily OC'd, the system would require a total of 26 amps on +12v. (Maximum). seasonic 430w can do 30A
  7. #7
    Super Moderator Skud's Avatar
    Jun 2004
    10 light years away
    Get Corsair GS600 or Seasonic SII 520W. Rest seems fine, no idea about mobo though.
    Gaming Rig:i7 2600K | N620 | P8Z68 Deluxe | 2x4GB RipjawsX DDR3 1600 | Vertex 3 120GB | Logitech G510 | Logitech G400 | Sapphire 6950 1GB | BenQ G2420HD | Corsair HX750 | Lancool K62
    HTPC Rig: C2D E7400 | EP45-DS3R | 2x2GB DDR2 800 | MS Wireless Desktop 2000 | Gigabyte 5770 | Samsung 32" | Seasonic SII 520W | Silverstone LC10
    Audio Gear: Altec Lansing VS2421 | ASUS Vulcan ANC | HiFiMan RE-0
    Storage: 2x250GB | 3x500GB | 3x1TB | 3x2TB
    Android: Galaxy R | Galaxy Y
  8. #8
    Jun 2012
    Thank u very much for ur suggestion, put please can i have a solid reason to go for 520w ? i seriously dont see any reason
  9. #9
    Apr 2012
    Or Get CORSAIR CX500 V2 @ 3.5K
    Dont even think of buying CORSAIR GS500 from Ritchie Street , it is priced @ 4.3K .
  10. #10
    Jun 2012
    Quote Originally Posted by Sainatarajan View Post
    Yeah ok buddy. But why not a top quality seasonic 430w Bronze ? Its better than corsair cx series..
    And where can i buy BenQ G2222HDL ?
  11. #11
    Apr 2012
    Seasonic PSUs RMA are quite bad.
  12. #12
    Alpha Geek avichandana20000's Avatar
    Jan 2010
    India, City of Joy
    ^^ do you have any experience regarding this? pls share.
    NZXT PHANTOM WHITE+3INTAKE 2EXHST|GA990XA UD3|955BE 3.6(O.C.ed)|MX-2|HYPER EVO|SAPPHIRE 6670 1GB DDR5|DELL SP2309W|CORSAIR XMS 2X2GB 1333|450VX|SEAGATE 1+1 TB|LOGITECH G110|APC 650 VA|+WD MY PASSPORT 3.0 1 TB
  13. #13
    Jun 2012
    guys i think a 430w is already on the "safer side". so im going with the 430w . i ll change my mind if i get strong advice why the 430 is not suitable for an IvyB with HD 7850. I wont be upgrading this PC for a long time
    or the cx500v2 as it also costs about 3.5k
  14. #14
    Wise Old Owl Myth's Avatar
    Jun 2012
    Bhubaneswar / Kolkata
    You never know when you might want to add something more to your system. Requirements change and so will the power usage.
    Better safe than sorry. Take a 500w psu.
    Intel i7 2600k, Asus P8Z77-M Pro, Sapphire HD 7950 VaporX with Boost | Palit 9600GT, Corsair TX650v2, CM Hyper 212 Evo(push-pull), CM Elite 430, Altec Lansing ATP3 2.1, Samsung Syncmaster 2033, Corsair 2x2GB, Seagate 1TB + WD 1TB Black + Maxtor 300GB, Win7 Ultimatex64, CPU-Z , GPU-Z
    Need Help :
    * Looking to purchase Noctua NH-U12P SE2 :(
  15. #15
    Jun 2012
    corsair cx 500 v2 is fine right
  16. #16
    Jun 2012
    Yes, corsair cx 500 v2 is fine
    Need Help :
  17. #17
    Jun 2012
    It has 34A of +12V . just saw.. alright. i ll get that then
    and where can i get g2222hdl ? out of stock in flipkart
  18. #18
    Apr 2012
    Get DELL ST2220M or ST2220L
  19. #19
    Jun 2012
    Isnt the dell monitor more expensive for the same quality?
  20. #20
    7h3 Fr34k 933k Chaitanya's Avatar
    Jul 2011
    In your Thread
    Quote Originally Posted by digit1191 View Post
    BTW i suggest you to go for this one...
    GL2250HM @9.1k
    It got a best buy award from DIGIT in their monitors comparision test that i read in May '12 issue..
    Alternatively,
    you may have this one
    G2222HDAL @ 8.5k
  21. #21
    Apr 2012
    I meant that if you dont get the BENQ model , you can opt for the DELL.
  22. #22
    Jun 2012
    is the B75 board ok ?
  23. #23
    Human Spambot The Sorcerer's Avatar
    May 2008
    Stick with GS500 or GS600.
  24. #24
    Jun 2012
    whats wrong with cx500v2 ?
  25. #25
    May 2008
    ^^ Do point out where I said that .
    I would choose the GS series over Seasonic S12II counterparts. I still wish I could recommend Seasonic but unfortunately some of the people's experience during RMA and also confirmation from a reliable dealer that I know have confirmed it and started to decrease stocking Seasonic PSU.
  26. #26
    Jun 2012
    no buddy. i dint say u said that. i was planning to get cx 500 v2 thats why asked.
  27. #27
    Jun 2012
    GS is a better quality than the CX. CX is the entry level for corsair.
    GS has more connectors and little more amp on a few lines.
    Need Help :
  28. #28
    Jul 2011
    In your Thread
    Talking Re: Finishing my rig. Please help me
    Why ??
    what's the trouble??
  29. #29
    Jun 2012
    oh damn.. it just went out of stock on flipkart have to find it locally
  30. #30
    Jun 2012
    went to ritchie st today.
    GA-B75M-D3H - rs4500
    Corsair Vengeance - 1650
    GS500 - 3900
    Shall i buy ?
    Oasis :
    mobo - 4.5k
    RAM - 1750
    PSU corsair cx500v2 - 3.9k ! ( INSANE ) he is not reducing. he is saying "vela eri pochunga "
    Lotus: (opp to oasis)
    mobo - 4.5k
    RAM - 1650
    PSU GS500 - 3.9k / CX500v2 - 3750
    And those ppl dont have ripjaws X
