Results 1 to 30 of 33
13-07-2012, 08:22 PM #1Right Off the Assembly Line
- Join Date
- Jul 2012
- Posts
- 21
need to build a gaming pc under 50,000 rs
i just need to get the cpu ... i have all other components like speakers, monitor,keyboard, mouse etc.
Ans: i'll need to play gta4 , battlefield3 , and COD MW3 , AC series , crysis2 , nfs the run at 1600 X 900 res
2. What is your overall budget? If you can extend a bit for a more balanced configuration, then mention this too.
Ans:50 k...yes i can extend my budget a little more for a balanced configuration.
3. Planning to overclock?
Ans: maybe in the future if it cant take on the latest games.... definetly not now
4. Which Operating System are you planning to use?
Ans: windows 7
5. How much hard drive space is needed?
Ans:1 tb.
Ans: i dont want a monitor.i already have a lg e2040t at 1600X900 res.
Ans:i dont want keyboard, mouse , speakers, monitor etc because i already have them
8. When are you planning to buy the system?
Ans:this week.
Ans:it will be assembled by a local retailer
Ans:i live in coimbatore, tamil nadu , i'll check out the the prices from the local retailer...is there any site that i shouldn't buy from onine?? if so pls tell me .
Ans: i did some research and i need advice on the following
Intel 3.3 GHz LGA 1155 Core i5-2500K Processor
Intel DH67CL 32GB DDR3 Desktop Board
WD Caviar Blue 1 TB HDD Internal Hard Drive (WD10EALX)
or
Seagate Barracuda 1 TB HDD Internal Hard Drive (ST1000DM003)
Gigabyte AMD GV-R7850OC-2GD 2 GB GDDR5 Graphics Card
Corsair DDR3 4 GB (1 x 4 GB) PC RAM (CMV4GX3M1A1333C9) X2
Seasonic 520W Power Supply (S12II-520)
Corsair Carbide Series 400R Mid-Tower Case (CC-9011011-WW)
Asus DRW-24B3ST Internal Optical Drive (Black)
it comes to a total of 54 k...have i missed something or is there a better config for this price ??
also pls suggest me the better HDD
thanks in advanceLast edited by sarveshrokz; 16-07-2012 at 12:32 PM.
13-07-2012, 09:14 PM #2Super Moderator
- Join Date
- Apr 2012
- Posts
- 799
Re: need to build a gaming pc under 50,000 rs
Processor:Intel i5 2100 @6.5k
Motherboard:Intel DH67CL @5.5k
Ram:Corsair value ram(1333MHz) 4GB@1.3k
HDD:WD Cavair Blue 1TB @5.2k
Optical drive: Asus DRW-24B3ST @1.1k
Cabinet:NZXT Source 210 elite:2.5k
Graphic card:Gigabyte AMD GV-R7850OC-2GD@16.5k
PSU:Seasonic S12-II-520 @3.9k
Monitor:Benq G2222HDL @7.5k
Mouse&KB:Logitech MK200 @0.7k
Total=50.7k
If you can extend your budget to 55k then you can go for i5 2400 in place of
i3 2100Last edited by vkl; 13-07-2012 at 11:35 PM.
13-07-2012, 09:40 PM #3
Not Clear .
Fill This Question and Post Here .
Asking for new PC help? ANSWER THESE QUESTIONS FIRSTIntel Core I5 2400 | Intel DH67CL B3 | Corsair Value Select 2x 4 GB | Seagate Barracuda 500 GB HDD | Asus DVD RW | CM Elite 310 | Corsair GS600 | Logitech MK200 | Creative Speakers | Samsung S20B300 | V Guard UPS | Intel HD 2000 | Nokia Lumia 520 |
13-07-2012, 11:59 PM #4
14-07-2012, 11:52 PM #5
EDIT- I just figured out the errors in your questionnaire, please rectify them first so that we could better help you by suggesting config suitable to your budget and requirements.
14-07-2012, 11:58 PM #6
Yeah probably AMD quad makes more sense.
15-07-2012, 12:12 AM #7
Yes, but if he doesn't need speakers, monitor, UPS, KB mouse, then he can probably get an i5 2500k + z77 + HD7850 based rig. But let's first wait for him to confirm.
15-07-2012, 12:19 AM #8Super Moderator
- Join Date
- Apr 2012
- Posts
- 799
^^Yeah,right.
Suggested him i3 2100 instead of phenomII 960t because of better gaming performance by i3 2100 which is OP's priority.
Let's wait for OP to clarify his post.
15-07-2012, 06:59 AM #9
I3 2100 is a very good Option .But most of the coming games Require a Quad Core Processor . So , in this Case AMD 960T or AMD 970 is a good Option.
15-07-2012, 08:48 AM #10Super Moderator
- Join Date
- Apr 2012
- Posts
- 799
^^i3 2100 can handle them well because it has 4 logical cores with the help of hyperthreading and it has quite high IPC as well so that it can churn out enough instructions to the GPU.
Moreover in many multi-threaded tasks it is very close to 960t
and beats it many cases as well.
15-07-2012, 10:42 AM #11Right Off the Assembly Line
- Join Date
- Jul 2012
- Posts
- 21
hi all. . .thanks for your replies. . .
i just need the cpu and the innards. . .pls tel me the finalized components
i'm not much aware of stuffs like this so pls help
15-07-2012, 11:45 AM #12
@sarveshrokz
i think you have 4gotten that u started a thread l
l
Enjoying Life
I never think of the future - it comes soon enough. :P
15-07-2012, 12:13 PM #13
15-07-2012, 12:49 PM #14Super Moderator
- Join Date
- Apr 2012
- Posts
- 799
@sarveshrokz
Processor:Intel i5 2400 @10.8k
Ram:Corsair value ram(1333MHz) 4GBx2 @2.5k
Cabinet:Corsair Carbide 400R:5k
Graphic card:Gigabyte AMD GV-R7850OC-2GD @16.5k
PSU:Seasonic S12-II-620 @4.8k
Total=51.4k
Optional upgrade:GIGABYTE GV-R787OC-2GD @22k
As you would be using 1600x900 so hd7850 is more than enough for gaming.
EDIT:OP can also opt for Seasonic S12-II-520 for 4k.Last edited by vkl; 16-07-2012 at 02:07 PM.
15-07-2012, 02:09 PM #15
I think HD 7850 would be overkill. GTX 560 would be more than enough.
15-07-2012, 02:49 PM #16Super Moderator
- Join Date
- Apr 2012
- Posts
- 799
^^HD 7850 would be more future proof considering newer titles that would be released in coming years.
Also if OP upgrades to a full hd monitor in future then hd7850 might be handy.
15-07-2012, 04:50 PM #17
It is better to buy a HD 7850 and Also it Fits in OPs Budget .
15-07-2012, 05:24 PM #18Right Off the Assembly Line
- Join Date
- Jul 2012
- Posts
- 21
the local retailer does not have all the parts specified here. . .can u suggest a good online store or a nearby city which has all the necessary parts mentioned here...
15-07-2012, 08:37 PM #19Super Moderator
- Join Date
- Apr 2012
- Posts
- 799
Primeabgb.com flipkart.com smcinternational.in theitdepot.com
theitwares.com
Properly check for actual prices(product price+shipping charges).In some sites some products are shipped free.
Flipkart price is inclusive of shipping but some of the products are over priced there.Last edited by vkl; 15-07-2012 at 08:45 PM.
15-07-2012, 11:31 PM #20Right Off the Assembly Line
- Join Date
- Jul 2012
- Posts
- 21
can i go for the Western Digital Green WD20EARX 2TB 64MB as hard drive ?
16-07-2012, 12:07 AM #21Super Moderator
- Join Date
- Apr 2012
- Posts
- 799
^^You can but opting for caviar blue 1TB is preferable
as WD GREEN HDDs have high failure rate plus they have only one year warranty.
Their performance is also lesser than corresponding caviar blue HDDs.
WD caviar blue comes with 2 years of warranty.
16-07-2012, 12:57 AM #22Right Off the Assembly Line
- Join Date
- Jul 2012
- Posts
- 21
theitdepot.com
Intel Core i5-2400 3.10GHz Processor 11380.00
Seasonic 520W Power Supply (S12II-520) 4305.00
Corsair Carbide Series 400R Mid-Tower Case (CC-9011011-WW) 5010.00
flipkart.com
Corsair DDR3 4 GB (1 x 4 GB) PC RAM (CMV4GX3M1A1333C9) X2 2710.00
Intel DH67CL 32GB DDR3 Desktop Board 5751.00
Gigabyte AMD GV-R7850OC-2GD 2 GB GDDR5 Graphics Card 16830.00
WD Caviar Blue 1 TB HDD Internal Hard Drive (WD10EALX) 5352.00
Asus DRW-24B3ST Internal Optical Drive (Black) 1176.00
total = 52514.00
im thinking of buying these parts in the above mentioned websites
is this the best rig i can get for this price or can it be better ??
16-07-2012, 12:28 PM #23Alpha Geek
- Join Date
- Nov 2011
- Location
- Chennai
- Posts
- 927
if u plan to come to Chennai buy things Delta peripherals u ll see 300 to 500 rupees difference. also u can try their site
16-07-2012, 12:42 PM #24Right Off the Assembly Line
- Join Date
- Jul 2012
- Posts
- 21
Ans: windows 7
Ans:1 tb.
Ans:this week.
or
thanks in advance
thanks amjath, i'll think over it
16-07-2012, 02:07 PM #25Super Moderator
- Join Date
- Apr 2012
- Posts
- 799
No point in pairing a K(unlocked) processor with an H67 motherboard.
READ THIS:the Intel LGA 1155 motherboard thread
Online prices are generally higher than local market prices.
Go for this:
Intel 3.3 GHz LGA 1155 Core i5-2400/2500 Processor
Intel DH67CL Motherboard
Price difference between i5 2400 and i5 2500 is about 1k and i5 2500 is clocked 0.2GHz higher than i5 2400.
Go for WD caviar blue instead of Seagate Barracuda 1 TB HDD as the caviar blue has
2 years warranty compared to Barracuda's 1 year.
With i5 2400 the total price of the config in local market would be around 50k.
With i5 2500 it would be around 1k higher.
If you buy most components online then price would be somewhat higher.
You can also opt for corsair cx500v2 which is available for around 3.5kLast edited by vkl; 16-07-2012 at 02:44 PM.
16-07-2012, 10:57 PM #26Right Off the Assembly Line
- Join Date
- Jul 2012
- Posts
- 21
is going for the i5 2500 processor worth the extra 1k ?
17-07-2012, 06:20 AM #27
imo NO
17-07-2012, 12:03 PM #28
Yes, as it is a locked processor, a 200 MHz hike in Clock Speed will turn out to be favorable for you. In gaming, it won't really matter, but in other applications, it might. But the thing is, 1k is a bit of steep. So it's your choice if you want to spend another 1k. If you can, then it's not a bad option.
Review : Samsung Galaxy S3 I9300
How well will this game run on my Graphics Card
Gaming Rig
AMD Phenom X4 960T | Gigabyte GA970A-UD3 | Corsair XMS3 4GB | Gigabyte HD7850 OC | Caviar Blue 500GB | Seasonic S12II 520W | Dell ST2320L | Corsair 300R
17-07-2012, 12:59 PM #29
2400 is vfm
Need Help :Spoiler:
* Looking to purchase Noctua NH-U12P SE2 :(
17-07-2012, 01:26 PM #30The Pirate King
- Join Date
- Feb 2012
- Posts
- 157
If u live in chennai then there is only one place. DELTAPAGE. COM
check the site for addressThe Pirate king !
Rs 50K Gaming Build !!!
By tnranganathan in forum PC Components / ConfigurationsReplies: 9Last Post: 10-06-2012, 09:35 AM -
Help me to build a new gaming rig under 70k/75k
By devx in forum PC Components / ConfigurationsReplies: 83Last Post: 10-01-2012, 12:37 AM -
Gaming\Dev Build around 40k ?
By gamekraze in forum PC Components / ConfigurationsReplies: 18Last Post: 10-08-2011, 07:59 AM -
need help to build up a gaming rig @ 70k
By Arnab boss in forum Hardware Q&AReplies: 142Last Post: 25-06-2009, 07:55 AM -
build a gaming rig
By FLAWLESS VICTORY in forum Hardware Q&AReplies: 11Last Post: 11-07-2008, 07:38 AM
LinkBack URL
About LinkBacks
