Results 1 to 6 of 6
Thread: Budget Rig 24K
  1. #1
    Wise Old Owl Nerevarine's Avatar
    Feb 2011
    Bhubaneshwar, Orissa, India
    Default Budget Rig 22K
    Ans: Gaming - Skyrim, MW3, Diablo 3 and the like
    2. What is your overall budget? If you can extend a bit for a more balanced configuration, then mention this too.
    Ans:22K for now
    3. Planning to overclock?
    Ans: No
    4. Which Operating System are you planning to use?
    Ans: Win7 64 Bit
    5. How much hard drive space is needed?
    Ans: None, using old one
    Ans:20 inch
    Ans:Mouse, Keyboard , Headset, Hard Disk, GRAPHICS CARD
    8. When are you planning to buy the system?
    Ans: This Week.
    Ans: Il be assembling it on my own!
    Bhubaneswar, Can only order from Flipkart or Ebay
    I need All the components EXCEPT THE graphics card which I will add in october.. i plan to purchase HD 6850/HD 7770 then.
    I need to find a GOOD PSU for under Rs 2300.. I have found a Gigabyte 550 watt with 80 Plus rating
    Gigabyte PoweRock Power Supply, 80Plus Certified, True 550W 550 Watt SMPS i5 i7 | eBay
    Is this a good deal ??
    What i have decided for rest of the config
    Price from local store
    i3 2100 Rs 6800
    Asus P8H61 Rs 2800
    LG DVD RW Rs 900
    Case El cheapo Iball Rs 500
    Monitor: Dell IN2030M Rs 6200
    Frontech UPS 600va : 1450
    Ram : Transcend 4 GB DDR3 Rs 1289 Will order this from flipkart.. (Cant buy
    corsair as there is no service center in bhubaneswar)
    Unfortunately, local stores are littered with crap iball/zebronics/intex/frontech psus, so ill have to order online.. Plz make the PSU under Rs 2300.. As i will be adding a HD 6850 later, i will need atleast 430 watt
    Total Rs 22239
    Suggest ASAP plz
    Come on, one day and no reply.. please suggest ASAP.. time is running out
    Should I order that Gigabyte PSU or not ??
    My Speedtest results
    i3 2120|Transcend 4GB DDR3|ASUS P8H61 M LX|ASUS DRW5ST DVD RW|Corsair VS450|Zebronics Ronak Cabinet|Dell IN2030M|Phillips SHP1900|Seagate Barracuda 250GB + WD Scorpio Blue 160 GB + Iomega external HDD 500 GB|Dell Wireless Mouse/KB combo|Intex Protector 600va UPS| ASUS HD 7770
    Life's a glitch, deal with it :P
  2. #2
    Jun 2012
    Lucknow, Uttar Pradesh
    Default Re: Budget Rig 24K
    If you cant buy corsair then buy it from any other brand. Near my home 4GB RAM sells for 1k.
    Intel Core i3 2120: 7k
    Gigabyte H61M-D2H: 3k
    4GB DDR3 1333MHz: 1k
    Dell IN2030M: 6k
    LG 22x DVD writer: 0.9k
    Case IBall: 0.5k
    APC 600Va: 1.4k
    FSP Saga II 500w: 2.2k
    Total: 21.5k
    It is better than any other PSU available at this price point and Gigabyte uses FSP as their OEM. If you are unable to get this one then you can opt for Corsair CX430 V2 for 2.4k which is also very good you can get it for under 2.2k.
  3. #3
    Feb 2011
    There IS a Gigabyte Service center near my location but no FSP no corsair service center.. Thats y i m confused whether i should get the Gigabyte PoweRock 550w.. On paper it seems really good as it is 80+ certified.. Im confused on what i should do, please reply asap
  4. #4
    Talk to the hand!!! warfreak's Avatar
    Jan 2007
    Gigabyte would be good enough bro. Might I also suggest a 7770 over 6850? It performs better and consumes less power.
    BTW "Nerevarine"! Good to see another Morrowind fan
    "Forget peace for now. We have to show them we are strong" - Prime Minister Golda Meir ( from the film "Munich")
  5. #5
    Wise Old Owl Sainatarajan's Avatar
    Apr 2012
    Santiago Bernabeu , Madrid , Spain
    +1 to HD 7770
    Intel Core I5 2400 | Intel DH67CL B3 | Corsair Value Select 2x 4 GB | Seagate Barracuda 500 GB HDD | Asus DVD RW | CM Elite 310 | Corsair GS600 | Logitech MK200 | Creative Speakers | Samsung S20B300 | V Guard UPS | Intel HD 2000 | Nokia Lumia 520 |
  6. #6
    Feb 2011
    Thanks for the reply guys, I will buy HD 7770/HD 6850 only and ONLY if it is between 7K and 8K - the cheapest i could find from Gigabyte OR MSI..
    However, if i can get GTX 560 for 9k, i will go for it..
    Currently gTX 560 from ebay is only 9.5 k after applying coupon
    However, that particular PSU's oem is CWT which is the OEM of Corsair.. It kinda gives me a sigh of relief
    PS : Morrowind is a gem in the pc gaming industry .. its kinda sad that when skyrim launched, many jumped into the bandwagon without giving a crap about oblivion and morrowind
  1. Need budget pc @25-30k
    By Jripper in forum PC Components / Configurations
    Last Post: 16-06-2012, 10:23 PM
  2. Budget Gaming PC(Budget-35k)
    By Scorrel in forum PC Components / Configurations
    Last Post: 24-04-2012, 05:25 PM
  3. Budget = 25k Rig with UPS
    By sammy9492 in forum PC Components / Configurations
    Last Post: 21-10-2011, 11:24 AM
  4. Replies: 21
    Last Post: 25-04-2011, 10:56 PM
  5. Low budget upgrade needed .. 10K Budget
    By k_v in forum PC Components / Configurations
    Last Post: 04-01-2011, 05:33 PM
