Results 1 to 8 of 8
  1. #1
    make.believe Ayuclack's Avatar
    Jul 2011
    Ahmedabad
    Default New HTPC Build Using Old Parts
    Ans: HTPC USE For XMBC and DVR Stuff
    2. What is your overall budget? If you can extend a bit for a more balanced configuration, then mention this too.
    Ans: 5k
    3. Planning to overclock?
    Ans: NOPE
    4. Which Operating System are you planning to use?
    Ans: Windows 7 or MAC or XBMCbuntu
    5. How much hard drive space is needed?
    Ans: I have 250 currently will upgrade to 2 TB
    Ans:NOPE Using MY Bravia
    Ans: CPU +MB + RAM + HDD
    8. When are you planning to buy the system?
    Ans: AFTER 15th this month
    Ans: yes
    Ans: Ahmedabad Open to online
    Ans: Just Using Old C2D PC as for a htpc
    What I Currently have in OLD PC
    Need To Change the Cabinet + PSU
    New MINI Wireless Keyboard Mouse
    If Needed Can Extend the budget and Please suggest more components if needed.
    Some Of The Cabinets I Am Thinking of
    iBall Baby 315
    Zebronics Flair
    One Question Will They Fitt the GPU Without Low Profile
    I am Also Looking for this type of keyboard
  2. #2
    Alpha Geek reniarahim1's Avatar
    Jan 2008
    Bangalore(KA) / Cochin(KL) , IND
    Default Re: New HTPC Build Using Old Parts
    You can look for Cooler Master Elite 100
    Whats your mother board size? is it mini atx, micro atx or atx? Cross check if the small form factor cabinets can accomodate your CPU.
    You may also need to get an entry level GPU. Whats your mother board model?
    Dell Studio 1555 - Intel Core 2 Duo P8600 @ 2.40 GHz, 3 GB RAM, 500 GB HDD, ATI Mobility Radeon HD 4500 | PC - Intel Pentium G620 @ 2.60 GHz, Intel DH67CL, 4 GB RAM, 500 GB HDD | Samsung Galaxy S Plus - 1.4 Ghz, 512 MB RAM, 16 GB Internal, 8 GB SD
  3. #3
    Jun 2012
    why would he need a GPU ? 9600GT is more than enough for HTPC
  4. #4
    Jul 2011
    Ahmedabad
    No GPU Needed 9600 GT is more than enough and the motherboard I am using is micro atx board .
    I don't need that much slim form factor but the case should have full gpu expansion slot ...
    Don't know about the iBall One!!!
  5. #5
    Jan 2008
    oops...i missed the graphics card..saw only cpu and the mother board..my bad
  6. #6
    Jul 2011
    Ahmedabad
    ***BUMP****
    Mother Of Bump!!!!
  7. #7
    Jul 2011
    Ahmedabad
    Bump................
  8. #8
    In The Zone CarlonSamuels's Avatar
    May 2012
    Bangalore,Karnataka
  1. HTPC Build
    By Aj12 in forum PC Components / Configurations
    Last Post: 30-09-2012, 09:52 PM
  2. Help me build an HTPC for 30k
    By ashish1224 in forum Hardware Q&A
    Last Post: 11-06-2010, 05:41 PM
  3. help me to build a htpc in (25 - 30 k)
    By vishal_2032 in forum QnA (read only)
    Last Post: 10-04-2009, 02:10 PM
  4. help to build a htpc for lg jazz 42" 80fr lcd tv
    By vishal_2032 in forum Hardware Q&A
    Last Post: 04-04-2009, 06:31 AM
  5. HTPC build- Help
    By harrissonford in forum Hardware Q&A
    Last Post: 02-04-2009, 04:29 PM
